Question about InFocus LP 735 Multimedia Projector
Bad Color Wheel
The color wheel in my X1a is gone bad, I believe. The high pitch screeching noise I hear when I turn it on is due to the color wheel is what I have read on similar blogs. If I could purchase a matching product so I can replace it myself that would be great. Thanks dynoh
  • 2,239 Answers
Try av solutions in ny. they're an infocus service center. www.avsolutionsny.com
Posted on Dec 29, 2009
SOURCE:
Samsung dlp tv HLP5663W makes loud noise
Yes, the set uses a color wheel and the lamp faces it.
The wheel turns at over 8,000 rpm and is well known for this problem=bearings in the tiny motor go bad.
The high pitched or fan like noise (classic description) is this part.
Sooner or later the wheel (plastic colored segments) will shatter and set will shut down lamp and not operate---set monitors the speed of the wheel so if it slows down or stops it knows.
The part is readily available on the internet (Google the model number with "color wheel").
This can be a do it yourself repair and You Tube has video instructions for replacing the wheel by model number.
There are two common pitfalls to avoid which the instructions that come with the replacement part usually do not mention---if you decide to do this repair let me know and I will explain.
SD TECH
May 26, 2012 | Televison & Video
Replaced the lamp in Samsung hl-s5086w and now T.V. won`t turn on but has a high pitch noise coming from back of set.
The high pitch noise is the color wheel that needs replace the noise is coming from a bad bushing that goes to the color wheel and is a common problem.
Dec 13, 2010 | Samsung HL-S5086W 50" HDTV
My Samsung HL-S5065W will turn on, it makes a humming noise. The picture comes on after a 1 minute or so the screen will go black and the tv shuts down. What could this be?
Hi,It sounds like you might be
experimenting a color wheel problem.The
color wheel is a rotating disc that has a
gamma of colors it spins at high rpms.The
light of the lamp goes through it to create
the colors on your tv.When it starts to go
bad you will hear ,humming,buzzing,high
pitch noises ,you might also experiment
color distortion ,black and white
picture.Here's a link that will help you
replace it:
http://www.fixyourdlp.com/guides/samsun
g/bp96-01579a.php Part # is BP96-01579A and you can find it here: http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?Click=48173 Have a blessed one!
Apr 29, 2010 | Samsung HLN5065W 50" Rear Projection...
Wont turn on ,bulb ok what next
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php Any buzzing,humming,or high pitch sounds? If you do it could be an issue with the color wheel.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.
Apr 07, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
The fan intermittenly makes a noise and the color changes on the tv
You need to give model #. Most likely you have a dlp tv and its not the fan but the color wheel that spins at very high speed and creates correct colors on your screen. This color wheel makes noise when its bad and colors go off when its running at slower speeds. Its going to fail sooner or later as its going bad now. Its a professional job to change the color wheel and could cost you $280-320 depending on the model. Fan generally never make anoise that is loud enoug to be heard unless its blades are hitting some obstru ction. Color wheels make whining or in worst case screeching noise when bad. check out www.fixurtvs.com for more FAQs. Thanks if you voted for me.
Mar 21, 2010 | Televison & Video
Color wheel or did i break something else?
Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some sets may actually shut down if the wheel is bad or shattered.
To determine if you have a bad color wheel:
  1. Turn set off and wait for main fan to shut off.
  2. Unplug the set.
  3. Remove the lamp door and then remove the lamp.
  4. In the direction the lamp faces you will see a round opening; the color wheel is facing this opening. It is a round plastic wheel with colored segments—we want to look to see if any of the segments are missing; a shattered wheel should be clear to see.
I have also posted the general instructions for Do it yourself replacement of this part in the TIPS AND TRICKS section of this site.
I will attach a photo of the color wheel for you to know what you are looking for----
If you have any questions feel free to respond to this posting.
If this has helped you rate this solution as I do this here for free.
SD TECH
Jan 01, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
X1A DLP No picture no buttons work only get white light
possibly the colorwheel. remove the lamp and see if the colorwheel is still there (colored glass through the hole). if it is, replace the lamp and turn the projector on. if you hear a high pitched whir, the colorwheel motor is ok. if not, it's one of 2 things: the main board has come loose from the dmd chip board, or the main board (eca controller) is bad. if the board is bad, you'll need to replace it, but it's over $500.
Oct 19, 2009 | InFocus X1a DLP Projector Multimedia...
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Loud high pitch humming noise over powering sound from TV
Yes you can repair this your self it is the color wheel also keep in mind that if set does not play after replacing color wheel and lamp lights,color wheel working with all 3 fans running and set shuts off within 30secs of turn on BAD LIGHT ENGINE!!!!!!!! also they are NO LONGER Available cost of that part was 1,000.00
May 30, 2009 | Samsung HLN5065W 50" Rear Projection...
High pitched whine when the motor starts
Had the same problem. It quit within about 5 seconds after turning the TV off. Replaced the color wheel and the whine is gone. The picture also looks brighter, which may be due to dusting the projection lens with lens-cleaning compressed air (from a can). The color wheel was about $100 from Samsung parts and it took less than 3 hours to replace. See http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ for good info, and be sure to read the cautions.
Aug 07, 2008 | Samsung DLP HL-P5663W 56" TV
InFocus LP 735 Multimedia Projector Logo
160 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
