Question about Casablanca Fan 6373T Victorian® Oil Rubbed Bronze Ceiling
Casa Blanca Fan Installation
I am installing a Casa Blanca Fan directly on a wood beam, The screws that hold the assembly to the bracket can't be screwed in, the beam doesn't offer clearance
  • 9 Answers
After installing the mounting bracket use a drill a bit smaller than the 4-holes that will the holding the canopy to the bracket and make 1-1/2-inch deep holes so the bracket can accomodate the 4-canopy screws.
Posted on Jul 09, 2008
  • 625 Answers
How wide is the beam - be more specific please.
Posted on Sep 10, 2007
SOURCE:
Want to install on wood beam, what size drill bit needed for included wood screws
Look at the wood screw threads and hold a drill bit against it. Choose a drill bit that is smaller in diameter than the threads on the screw. Works for any size wood screw.
Mar 11, 2016 | Drills
The lights suddenly stopped working. It is only about 2 years old. When you turn the switch on they will briefly come on and then go off.
Hello Lisa Gray James,
I had the luxury of having a couple of old Casa Blanca fans in the house when ours went kaput (but the point I will try to make
is quite portable... between MANUFACTURERS.
Typically most wall controlled fans are designed to work over a standard light-switch circuit. the ADDITIONAL functions are accomplish through EACH vendors own proprietary switch-fan interface... (in the Casa Blanca case I am attaching below) they use their "RF" signals from their switch... and the control boards emit audible tone to make the user confident something is working.
I had NOT yet discovered the availability of the replacement unit below... but by swapping the living-room switch with the bedroom switch I was able to prove the trouble to Casa Blanca's 21Z2 control board (inside the fan)
Old style 21Z2: no longer available
Inteli Touch Circuit Board RMM 9901120 or 7801240
is manufacture discontinued (Inteli-Touch & Inteli-Touch II)
but the replacement units (Inteli-Touch 3) will work nicely...
Casa Blanca recommended that BOTH the switch (W32)
and control board should be changed... I complied.
(saved my good W12 switch as a spare)
BUT DO NOT hesitate to call the FAN MAN to discuss your options and needs... it looks like a multi vendor site... and I have also seen them on AMAZON.COM
New Inteli Touch 3 System
Jan 17, 2016 | Dryers
I have 2 wires plus ground going from switch to fan at fan there are several wires I can not figure out a hook up
if single speed fan you have 3 wires and ground
if 3 speed fan you have 5 wires
if 1 speed 2 wires are are the power and the other one is a capacitor wire at 1.3uF 1.5uF 330v you need to have the wiring chart for the motor or you could work it out with a ohm meter or seek the help of a sparky
Dec 29, 2015 | Dryers
Where to get parts for casa blanca ceiling fan?
are you referring to the light globe? You can go to any home decor or home depot/lowes and find replacement covers, and the make sure the screws the hold it in are not stripped and need to be replaced as well
Jul 20, 2014 | Casablanca Fan Mykonos MyKM45 Ceiling Fan
Can't assemble the push handle in little tikes 3 in 1 purple
Hi Blanca,
We'd recommend you contact Little Tikes direct for assistance -
Mar 05, 2014 | Little Tikes 3 in 1 Trike Purple
Hampton bay ceiling fan broke. How to screw it back up
It already looks like it's "screwed up". ( LOL) BEFORE BEGINNING READ ALL OF THIS FIRST< PLEASE> First turn off the breaker that supplies power to the fan. Take down the whole unit up to the ceiling mounts. It looks like the wood is broken that the screw bracket used to mount the fan is on. If it is you will need to reinforce the wood and rescrew the fan mounting bracket on it. THe ball carrier from the bracket should now be secure and ready to mount the swing ball of the fan at the top of the fan unit motor. Next rewire the fan to the wires in the ceiling with the wire nuts you removed. Tighten the ball screw and push the cover plate up to the ceiling, fastening it in place with the screws provided to the ceiling plate...Done!
Jan 01, 2013 | Heating & Cooling
I own a Samsung DLP 56" TV for which I purchased a swivel wall mounting bracket that holds up to 160 Lbs of weight. However when looking at the back of the tv set and the such smal size screws that...
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
Jun 30, 2011 | Samsung HL-T5676S Television
Er FF. Have replacement fan. How to access
Unplug the refrigerator from power. Remove the rear cover in the freezer. You may have to remove shelf brackets or the ice maker. Pull the rear cover forward and out of the way and disconnect the wire harness to the fan. Should be 2 screws holding the fan bracket in place. Remove these screws and pull the fan assembly out. You now have access to fan.
Feb 20, 2010 | LG LRSC-26922 Side by Side Refrigerator
Need to adjust front headllight Somebody ran into my front bumper and cracked the grill and moved the headlight out of adjustment
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
Aug 20, 2009 | 1998 Dodge Dakota
Casa blanca fan motor speed control
www.casablancafanco.com
Jul 28, 2008 | Dryers
Casablanca Fan 6373T Victorian® Oil Rubbed Bronze Ceiling Logo
128 people viewed this question
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
