Question about Legacy Audio Blue Diamond LA580 Car Audio Amplifier
No Power My amp appears to have no power as the Green LED and the Blue light on the top of the amp do not come on and the subs don't work. The red LED is not on either. I have 14.05 volts DC input and 12.71 volts DC to the remote terminal. The fuse on the unit is good.
  • jasper100 Sep 12, 2007
    Thanks for the quick response. The amp was still under warrenty, but my son did not have the receipt. I was a little hesitant to open it up, but your response gave me the second opinion I needed. Right away found that the circuit board was messed up. I sodered a jumper in, but it still didn't work. Looked a lot closer and found another small flaw in the circuit board that kept power from getting to an IC chip. Sodered that and the amp powered up. Also found an open in one of the wires coming from the radio. Working great now. I'm glad the problem was more obvious than you thought cause I wasn't having any luck finding a schematic. Thanks again for your advice. Take care.
    Genius:
  • 1,139 Answers
Hello jasper100, Have you opened the unit to take a look inside? Since you dont have a blown fuse we cans assue the a short has not occured. Now I would chect to see if the voltage regulator in the amp has voltage coming from it. It may not in that case you may have to remover the old regulator and put in a new one just to get to the point of properly troubleshooting this amp. I would suggest that you get a schematic for this unit and use a multimeter to look at the voltages in the power supply section and see which sections have no rail voltage (12v supply voltage). I would also advise checking the remote to for regulator failure.
Posted on Sep 10, 2007
3 Suggested Answers
bumpinjls
  • 13 Answers
SOURCE: amp problem
Make sure the amplifier setting "disable" is off then turn off remote power and turn back on.
Posted on Dec 24, 2007
SOURCE: ps 52 kx power supply will not hold load
thank you for your help . I have already fixed the power supply I double checked the transisters and found three bad so I replaced all the power transisters and it is fine . thanks again bob
Posted on Nov 19, 2008
Cadence 400 watt active sub green light on, no sound from the sub. whats wrong?
proceed according and fix it. However yi\ou must read the diode LED for diagnose. God bless you
Mar 26, 2013 | Exercise & Fitness
Samsung 1080 picture glitching on model # HL61A750a1fx2c Versionre01
If it's all colors (Red, Blue, Green) doing the same thing at the same time, there are (unfortunately) multiple possibilities:
1) the AC to DC power supplies
2) the LED Driver Board
3) DLP driver, or DLP itself
The most likely problem is the DC-DC power supplies, which are known to have capacitors that go bad after several years of operation.
Due to this, there are many sources for either re-capacitor kits (DIY), or rebuilt power supplies with upgraded capacitors.
WARNING - Dangerous, and even lethal voltages are present inside your TV set. Do not attempt this unless you are trained in these kinds of repairs. Leave the TV unplugged for several hours (or preferably a full day) before attempting such.
DIAGNOSIS for bad capacitors: If you inspect the large capacitors on the power supply boards, and they are not totally FLAT across the top surface (if bulged at all), then you need a new power supply or new cap's. Likewise, if there is any leakage from the capacitors (usually a light-yellowish crusty appearing substance), they are BAD.
Sub-power supply:
BP96-01726B ASSY PCB P-SMPS Aquamarin,LED DLP TV,DC2
Main power supply:
BP44-01001A SMPS-DLP TV PN082DPS-VF(A),AC/DC,90V-132
A quick Google search for these part number (BP96-01726B & BP44-01001A) will reveal many sources, and pictures to verify it's what your set has.
Jan 12, 2013 | Samsung HL61A750A 61" HDTV
I have a power acoustik bamf 1600/4. not working 5 hours later
use a multimeter to see if the amp has good power wire and remote turn on voltage. then check the ground and make sure its a good strong ground. check the sub to make sure its not bad. make sure it reads whatever ohm its supposed to. anything less than 4 ohms will clip the amp if bridged. if alll that is good then the only thing left is the amp. it sounds like the power supply is bad but check everything else just to make sure. good luck.
Dec 29, 2009 | Power Acoustik BAMF1600/4 Car Amp
Kicker 250.2 amp, I have green power led, but the red led on top of the unit does not come on, nor does the red protection led, hear a click out of the subs on occation but nothing else, looked inside and...
Sometimes clicking, or popping sounds from subs are caused by over excursion of the subwoofer, wich can be caused by ultra low frequency, or going below the tuned frequency of your enclosure.
Aug 12, 2009 | Car Audio & Video
Kicker zx750.1 Amp in Protection Mode (Red LED)
My kicker amp zx1500.1 keep going in protection mode I unhooked the sub speak wires and put the ACR cords back in and it didn't go in protection mode what next
Mar 18, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
RED Port light on AMP?
are you sure its not PROT?
the amplifier is protecting itself from fire because of something.
Disconnect the subs. and turn on.
if it comes on normally, the subs are at fault and will need attention. If the light still stays on, you hafe probably blown an output on the amplifier and it will need repair.
Dec 24, 2008 | Sony XM-2200GTX Car Audio Amplifier
Protect led light
It appears that the amp is going into protect mode. To eliminate external causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 10, 2008 | Car Audio & Video
Amp has Red LED light on.
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 05, 2007 | Soundstorm F2600 Car Audio Amplifier
Power light
This could be a DC offset condition. Check you manual for what this means. Or other condition. First Disconnect the Subs and try it. If it still goes red then disconnect the RCA's and try it again. If the Led continues to go red after the click then the Amp is hosed. The Click you hear is an internal relay that cuts the subs in after a dely so you do not get the turn on THUMP of the radio at your subs.
Jul 08, 2007 | Hifonics Titan TX 8805 Multi-Channel Amp...
Legacy Audio Blue Diamond LA580 Car Audio Amplifier Logo
Top Legacy Audio Car Audio & Video Experts
Richard Lukszys
Richard Lukszys
FastHarley
FastHarley
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
