Question about HP OfficeJet 6210 All-In-One InkJet Printer
Printer hardware problem
Hello, My printer won't turn on... when I called the HP customer support. They told me it was a hardware problem... Can someone help me?
  • aesterripa Sep 20, 2007
    How can I fix it?
    Problem Solver:
  • 9 Answers
Yes it is a hardware problem your logic board is bad
Posted on Sep 19, 2007
Plz check ur power cable and power supply unit
Posted on Aug 04, 2011
    Problem Solver:
  • 5 Answers
Plese check the fuse in the power supply unit of your printer
Posted on Sep 13, 2007
Hp officejet 7000 won't print 6.5 x 10 paper size
Officejet 8620 printed about 400 for me in 16 months then stopped. A few weeks prior to the error msg. that the paper in the tray did not match my document settings another message said it did not recognize any paper in tray including letter size despite there being about 100 sheets. I c alled HP two different days, tried documents on a brand new computer, created a new document. Took two hours total and $20 to be told the printer did not support this paper size. I called them prior to purchase and told them my needs and was told it would accommodate the size. My local techie and I both think the sensors have gone bad in under 2 years as I had been able to print my cards with no issue about 400 times. I called Epson three different times and each tech support person says Epsons can accommodate this.
Aug 08, 2012 | HP Officejet 7000 Wide Format Printer...
How can I add HP 5940 to HP Solution Center
In order to connect to a second printer, you need to re-run the wizard of hp solution centre like stated in the forum link here:
How do add second hp printer to HP solution center
If the printer is still not avail. through the HP wizard, please try and setup the driver manually (while connected to usb to the PC) like shown in the video below:
Dec 18, 2011 | HP Deskjet 5940 Photo InkJet Printer
Amber and 2 green lights on solid and won't pick up paper
To clear the error, turn the printer off and then on again. If the problem
persists, leave the printer off for 15 minutes to reset the formatter. If
the problem continues, contact HP Service. See HP Customer Care
Oct 26, 2011 | HP LaserJet 2200D Printer
I have an HP Officejet 6500 Wireless printer. The cartridge has jammed to the right and won't move. I don't know what happened.
It is a carriage jam. If you are still in warranty, you should call customer support. If not, then there is probably not a lot you can do to fix it.
Oct 12, 2011 | HP Officejet 6500 AllInOne InkJet Printer
Hp 2210
yes,i work for HP.Change the cartridge if this still persists with the old and new cartridges then its a hardware malfunction with the printer and so call in to hp at 1800-474 6836 and directly ask the customer representative for the upgrade options or get a new printer .If you call in to Hp then you can avail atleast a 50% discount on the upgrade printer with free shipping ........cool right(Hopefully)
Jun 15, 2009 | HP PSC 2210 All-In-One InkJet Printer
My printer wont print a document .....I called the 1300 no: and someone told me to uninstall the the printer from my computer and then reinstall it .....thanks i did this and now my computer does not what...
Go to HP.com and click on support, you will see downloads, select your printer and download software and drivers, they usually have updated versions and they work better than the disc you recieved with the printer.
Aug 04, 2008 | HP Office Equipment & Supplies
HP C4180 Carriage Jam
Lisa,
you can call HP technical service which is open 24 * 7 and the phone number is 1 800 474 6836 for US customers.
Customers of other countries can open the following link: http://welcome.hp.com/country/us/en/wwcontact_us.html
There is a high chance of the printer hardware failure. If the printer is under warranty, HP will replace the printer for you.
May 08, 2008 | HP PhotoSmart C4180 All-in-One Color...
Printer won´t work
The printers listed in here are older models. If you have purchased a printer in the last 2 years, your printer most likely will work with a print server. If your printer is not mentioned in this FAQ, it may work. If you are using a multi-function printer, only the printing function will work through the print server. Several kinds of printers are not supported on a network. These include host-based (sometimes referred to as GDI printers), and PPA printers. There are also printers designed for home use that are not intended for support on a traditional network, but that may work in a Home PNA network. In addition, several HP Officejets are not designed for or supported on networks. Host-based (sometimes referred to as GDI printers). A printer that relies on the computer´s processor to rasterize the print job. Most host-based printers use the GDI interface built into Windows (hence the "GDI printer" term), so there is no need to convert the data to PostScript, PCL, or other printer language. Some HP Deskjet printers are PPA (Printing Performance Architecture) printers. With this new printing system, the printer handles only basic printer functions while the printer software on the computer handles the formatting. All formatting, such as color matching and correction, half-toning, edge enhancement, tone correction, and ink management, are handled by the software driver. Furthermore, some of the printers listed below may work on a network, but only when they are connected to the parallel port of a Windows computer that has the correct printer driver installed and printer sharing properly configured. Contact the support group for you specific printer for details. Hewlett-Packard PPA or host-based printers: HP Deskjet 710C printer HP Deskjet 712C printer HP Deskjet 720C printer HP Deskjet 722C printer HP Deskjet 820Cxi or 820Cse printer HP Deskjet 825C HP Deskjet 1000C printer HP Deskjet 1000Cxi printer HP Deskjet 1000Cse printer HP Original Photosmart photo printer (C3804A) HP LaserJet 3100 product HP LaserJet 1000 product family The following printers are not supported on traditional networks: HP Deskjet 900 series 930C 932C 935C 940C 950C 952C 959C HP Deskjet 800 series 810C 812C 830C 832C 840C 842C 880C 882C NOTE: HP does not recommend the use of the HP Deskjet, HP Deskjet Plus, HP Deskjet 300, 400, 500, and 600 series printers, or the HP Deskjet 850C series printers for shared, high volume printing. These printers have a low duty cycle and are not designed for high volume network printing. The models listed below are not designed or supported on networks. HP Officejet 300 HP Officejet 500 HP Officejet 600 HP Officejet 700 HP Officejet K60 HP printer/scanner/copier 370/380 HP printer/scanner/copier (HP PSC) 700/900 HP Officejet V
Feb 16, 2006 | D-Link DI 707P (DI-707P) Router
HP OfficeJet 6210 All-In-One InkJet Printer Logo
630 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
