Question about Emerson EWD7004 DVD Player
Will not play my dvd-r
I have an Emerson EWD 2004 player and it will not play my burned slideshow on dvd-r 16x disc. The owners manual says it will but when i place the dvd in the player tray and close.........nothing. The tv is on the same station as when we play purchased dvd movies. There's just a blank screen. The player light indicates that its playing but nothing on the tv screen. What's up with this? The dvd-r was burned on my brand new Toshiba lap-top. I think the burner is a mitshita dvd-ram UJ-841S. The disc plays on my laptop but will not play in my emerson player. Please help.
  • 752 Answers
Re: will not play my dvd-r
Is the media a compatable format? DVD player might play video cd's but not .WMV's for instance....
Posted on Sep 10, 2007
0 characters
3 Points
How to copy VCR to DVD on Sanyo DVR V100E
Try Googling (Sanyo)(DVR V100E)(manual) without parens to get instructions.
Sep 19, 2016 | Sanyo DVD & Blu-Ray Players
I have never been able to play a slideshow 0n my dv454 no matter where i had the discs burned what am i doing wrong? ps the discs play in other dvd players
Check to make sure that the format of the discs burned are acceptable by the dvd player, some companies do not support certain formats. refer to owner manual as to which ones are readable on your particular dvd player. if the dvd player plays other regular/non-burned discs, this is the probable issue,...more info is needed if this is not solution.
best of luck
Oct 17, 2010 | Pioneer DV-454 DVD Player
I bought DVD's and to my understanding that i need
While it is true that not all dvd players will play,record, or even acknowledge some media I don't think you need a firmware.4X -16X is the max . write speed of the DVD disc. It should be OK with slower speed machines.What did you use before? Good Luck.
Sep 08, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Cannot record on 16X DVD-R
You will need to call Funai 1 800 605 8457 give them your brand / model number and expose your problem - they should be able to send you an upgrade disc but it will cost you -
If you want my advice - you DO NOT need a 16x disc inside a DVD recorder - the optical drives used on DVD recorders and even worse a Funai drive are quite bad as it is in terms of writing strats for higher speeds - you are better off recording at 8x on a 16x disc.this will provide better burns ( lower PIE/PIF errors and jitter %).
Aug 25, 2009 | Emerson EWR20V4 DVD Recorder/VCR
My Cyberhome CH-DVD-300 (dated 2003) will play movie DVDs, CDs with photos and music CDs. It will not play a DVD with a slideshow software for photos with music and text that I burn on my computer. The...
I feel for you because I also have the same unit and have been frustrated in the past when I tried different dvd's to play. The conclusion that I have come to is that I only use my cyberhome player to play rented dvd's
Jul 13, 2009 | Cyberhome CH-DVD 300 DVD Player
Memorex dvd-r 16x wont work
It could be the dvd there is different types of dvds that some dvd players cant use.
Mar 29, 2009 | Emerson EWD7004 DVD/ CD Player
I have a Emerson DVD/VCR combo player, have lost the directions, can't get it to work. EWD 2202
Go on Google and type in Emerson EWD2202 Owners Manual and look for the link tht shows it in a pDF file. Download it and then print it is you like
Jan 08, 2009 | Emerson EWD2202 DVD Player/VCR
Playing recordable dvd
My Emerson won't play anything except DVD Movies, never has, wasn't suppose too. Make your movies in DVD Video format and it will read them fine (unless it's broke). I make movies all the time and play them back in mine. It reads DVD-R, DVD+R, and in duel layered. It will not read RW disks!
Man I've every problem you can imagine with DVD Players. I've found when the disk gets stuck, as long as it's not jammed. You can turn the unit off or unplug it. Plug it back in but DON'T TURN IT ON! Instead hit the eject button and the drive should open the drive without trying to read the disk.
Feb 24, 2008 | Emerson EWD7003 DVD Player
Timer recording
I sent you the manual if you dont get it. you can download one there for free!
Jan 13, 2008 | Emerson EWD2004
Emerson EWD7004 DVD Player Logo
312 people viewed this question
Top Emerson DVD & Blu-Ray Players Experts
Level 1 Expert
Are you an Emerson DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
