Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
WBR-2310 router needs resetting 5 times per day
Each time I lose connectivity to the internet, I regain it by power cycling my cable modem and router. This is happening WAY too often. I never have this problem if I connect the cable modem directly to the computer, though admittantly, my cable service is probably more sluggish than it should be. Do i have something set wrong, or is it time to go buy a new router?
  • Anonymous Apr 08, 2009
    I have the same problem, it definetly has something to do with wireless interference. I have a wireless router hooked directly to a desktop and run 3 other laptops at different times. When I turn certain laptops off, then back on. I have to unplug my router for 5 to 10 seconds before I can go anywhere on the internet. If I don't unplug the routers power, I can still connect with my laptops but they say limited connectivity and I can't 'go' anywhere. I have no solution. I read above where GeorgeD says to change the wireless frequency. I have no idea how to do that.
  • 59 Answers
I'm going to bet you have wireless interference...try changing the wireless frequency in the config under channels. Good luck
Posted on Sep 10, 2007
My D-link router has never worked the way it should be. I always come to the point when would have to be reset by pressing and holding the reset sw in with a paper clip for 10 secs. Unfortunately I always come to realize that there is no switch, or the hole is blocked. So I called tech support couple of times, but they only tell me the same thing to type in 192.168.0.1 and do not understand that I tried this and all other possibilities a million times. The result always "The server at 192.168.0.1 is taking too long to respond." So last time I was so upset when tech support hung up the phone on me, so I went and opened the case and found the switch is factory blocked, (sealed) with black epoxy. Has anyone else found similar problem??? What should I do??? D-link tech support makes a habbit out of hanging the phone up on me. The reason I think they do this intentionally, b/c for start they ask my phone number but they have never called me back so far. I am sick of it to keep calling them back and spend hours on the phone waiting.
chevy
Posted on Jan 12, 2008
    Scholar:
  • 33 Answers
Call Dlink help. Those guys know things that aren't in the manual. You may need to update the firmware. Or reset it. I had a problem with another brand of router and it turned out it needed a 2nd level reset, which involved holding a paperclip in the reset hole for 60 seconds. Then it worked great.
Hi geo-geo
I can never get access through my d-link; My reset is indeed blocked; i too get the same "too long" ip server message; mine won't recognize my wep. Just a mess! i empathize.
Posted on Jan 17, 2008
SOURCE:
Last january my d-link WBR-2310 still working fine but now i wanna use it, it wont connect in the net?
Try power cycling the router.
Disconnect the router from all computers. Power off the router. Power on the router. Reconnect the router to all computers. Check the Internet connectivity.
Mar 01, 2011 | Computers & Internet
I have a WBR-2310 D-Link wireless router. Yesterday it started not getting the signal from the Comcast cable modem. I can connect the cable modum direct to this computer and it works fine. But the gold...
If ever I have had a problem with my D-Link I have contacted them directly and they have solved it over the phone for me. There is an initial answer message that states that you MAY be charged $40 for the help ... but I have never been charged. It is a brilliant service.
phone 0800 900900. I hope that this helps you.
Oct 29, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Just need help to hook up im slow learner handicap know how to just walk thru it make sure im do ing it right just got it today
Who is you ISP? if you're using cable connection follow these steps:
1. Connect modem to WAN port of the WBR-2310
2. Connect computer to port 1 of the WBR-2310
3. Open web browser (IE, firefox,chrome,safari), and type in 192.168.0.1 into your address bar
4.Into the log-in page username:admin password: (none)
5.click on "SETUP"
6. Click on "MANUAL CONFIGURE"
7..in the Internet connection type, make sure that it must be in DYNAMIC IP DHCP
8. Click on CLONE YOUR PC's MAC ADDRESS button(notice that mac address will change after you click on that button)
9. Click on SAVE settings now and it will count down click on Continue after that
10. Then Try to ACCESS Internet
/... but if still you cannot access Internet try to power cycle the modem and the router.. follow these steps also
1. turn off bothe modem and router (just unplug the power cord)
2. after 1 minute, TURN ON first the modem,
3. after 1 minute again, TURN ON the router
4. after 1 minute try to access Internet
But if still no Internet connection, please look for the brand of your modem if it is speedstream 5100 or hugesnet or actiontec modem because those modem have the same IP address with your DLINK router and you need to change the IP address of your DLink then....
Further questions? call 1-877-453-5465 (US), 1-800-361-5265
Hope this will help you. Goodday
Aug 13, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link router does not connect to my laptop
remove the cat5 cable end that goes from your internet connected computer to your router; remove the end of this cable from your router ; remove your modem to router cable end from your modem put the internet computer cable into where the router cable was in the modem; unplug then: plug in your modem; wait for the modem to reboot; verify that the internet computer is online then swap the cables back where they were
you should now be able to connect your laptop wirelessly to the internet.
Jul 15, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link wireless router,WBR-2310 no connection thru router, connect ok thru dsl modem when d-link ethernet cable connected, lose all internet
First reset all settings of router to default.
You can reset it with RESET button it is in back side of router press It for 10 seconds.
Then connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then configure your router WAN settings as your internet service provider settings.
Go to wireless enable wi fi .
Then save all settings then check.
Also enable DHCP if you want ip addreses automatic from router.
Then save settings and restart router.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Wbr-2310 error 112
Check your physical connection first. From the modem, it should be connected to the router's Internet port, then your computer must be connected to port 1 on the back of the router. Then do a power cycle, no need to run the setup CD. If it doesn't work, you need to manually configure the router. You may need assistance from D-Link tech support. Call their toll free number
Jun 20, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
D-link WBR-2310 has serious drop out problems
I'm pretty sure that downgrading the firmware to 1.0.3 will work. I had been running at this level for quite some time and for some reason I decided to upgrade to the latest version which started the problems for me. I am downgrading to this now and I expect better results. All of the firmware versions are available at http://www.dlink.com/products/support.asp?pid=470&sec=0. You pick the right hardware revision. PLEASE NOTE: Save off/remember your settings as when you change the firmware it resets all of them back to system defaults.
Dec 12, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
D-link WBR-2310 Stop working
Sounds like a defective modem/modem failure if, it does not reset or if you take all of the other wires out and just leave the power in and none of the other lights go off then that is definitely a defective mode, I suggest either returning the modem to where you purchased it from or calling D link it should be covered under there warranty for replacement.
Nov 14, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Intermittent connectivity
Check to see if you are losing the DSL or Internet light on the modem when you lose your onnection. If so, then check with your IP provider, that may be the problem.
Apr 11, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
1,688 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
