I have the all-in-one driver. The printer is hooked up directly to the PC via USB, and is also available as a network printer through this PC. Any time I print from a network PC, it requires me to cycle power to print. This often happens on the direct print as well.
A second problem I have is that I can't print from another PC hooked directly via parallel port. I do this because this PC is usually on our corporate VPN - therefore inaccessible from home network. The OS recognizes the printer, and I've installed the latest drivers. Is there a problem hooking two different PC's to this printer even though there are two ports available?
I am using the unit in a "stand alone" config. It will not send or receive a fax. Phone...
(More)
I am using the unit in a "stand alone" config. It will not send or receive a fax. Phone line is good. I probably have it hooked up wrong but I do not know. Help!
Half empty black cart stopped printing, error message to replace. New cart also didn't print. ...
(More)
Half empty black cart stopped printing, error message to replace. New cart also didn't print. Repeated cycles of clean and prime did nothing -- nothing but fill the bottom of the printer with a puddle of ink. Troubleshooting page suggests cleaning or replacing the cartridge service module. Is this possible on this machine. Is it a dead puppy or worth fixing?
Just installed a new color cartridge. It keeps saying that alignment failed and won't print in...
(More)
Just installed a new color cartridge. It keeps saying that alignment failed and won't print in color. Thank you.
Getting a message that says Report Job queued when trying to re-align. When I try to align it spits...
(More)
Getting a message that says Report Job queued when trying to re-align. When I try to align it spits out a blank page and flashes "Report Job Queued" then says alignment failed.
Hi, I am trying to scan and print a document on my printer and when I put it on the scanner and hit...
(More)
Hi, I am trying to scan and print a document on my printer and when I put it on the scanner and hit "start copy" my printer says it is jammed but I can't find any jams, It reads: "Original jam:" I've tried hitting enter and cancel but it won't let me scan it. Any help is appreciated. Thank you.
