Question about Olympus FE-190 Digital Camera
My camera will turn on but the shutter won't open!
I have an olympus camera and a few months ago I spilled a tiny bit of juice on it. The shutter just got a little sticky and no harm was done to the camera. It was working perfectly. Later on, I found that my camera would turn on, and occasionally the shutter would open but then go back in again, and every time I try to turn it on, it just goes to my last picture that I took. My buttons and settings will not work, and I can not press the power button for the camera to turn off. Sometimes if I press a certain button it will flash to my first picture. I know my shutter is working, but what could be wrong?
  • Anonymous Mar 01, 2008
    my olympus digital camera FE 190 won't turn on eventhough I charged its battery. nothing happened with the camera, it was just in my bag since I came from a 5 day travel and I still used it. also, i observed the charger, its red light did not go steady while charging, it went on and off, unlike before that it went steady while charging. I am far from the big city and I want to know the remedy of this problem. thank you.
  • Anonymous Mar 31, 2014
    the camera will go on
    I press the on button and the camera will not turn on
    Champion:
  • 217 Answers
Tiny bits of juice, remember? maybe (or I am sure) this tiny became corrosive inside the camera. (orange juice is the no.1 in my corrosive juice list, water is the least). You need to open and clean it, or a pro fix is necessary.
Posted on Sep 10, 2007
I have a coolpix and I spilled orange juice on it. I imediatly cleaned and dried it off but when I would try to turn it on...nothing. It's been a few months I tried to turn it on and it says battery...
First off, are you sure that the battery is charged? It is definitely possible that spilling orange juice on it messed it up, but it might be all right.
Assuming the battery is charged, it is likely that the spill caused some internal damage. When you spilled on it, did you open the battery door, take the battery out, and allow the the camera to air-dry completely before turning it on? If you didn't, it is almost surely fried. If you didn't allow it to air-dry, it is likely that there was residual moisture and liquid on the internal components, and when you powered it on you likely messed them up. This is really a repair that is not worth paying for, as the cost of a new camera would be much cheaper.
May 07, 2011 | Nikon COOLPIX L4 Digital Camera
I am from the philippines and i own an olympus e 3 dslr. when i use it, upon being turned on, it will focus just as quikly as before but the shutter would not 'click' or function. do you think the shutter...
Remove the lens and fire off a few shots. Does everything work properly? Put the lens back on and try it again. If it still won't work, then I suggest you go to the Olympus website, click on support, and e-mail one of their technicians about your problem. They can direct you from there as to wether you need to send it in for service and where.
Apr 08, 2011 | Olympus Cameras
My Olympus fe just stopped working. I changed the batteries and that wasn't the problem. It will not turn on! The viewing window is dark, only the tiny light blinks.
you camera is turned on but the shutter seems not to open the reason you only see a dark screen. remove battery and press and hold power button for one min. reinsert battery and try again. if it still doesnt work it might require to be send to depot.
Sep 07, 2010 | Olympus FE-230 Digital Camera
Juice on Shutter and on/off button- sticks or moves hard
take a wooden stick rape a cotton deep in alcohol try to clean it see that the alcohol should not' go inside or go to repair
Oct 16, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Lens blocked? Canon PowerShot SD1100 IS, recently water damaged
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 13, 2009 | Canon PowerShot SD1100 IS Digital Camera
When camera is turned on the monitor is black, takes black pictures
hi..
A stuck shutter is common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter.....
thank u
Jul 10, 2009 | Olympus Stylus 850SW Digital Camera
Canon Powershot S2IS black screen can't take pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). Not sure what causes this issue, but some say it's heat, others say it's dust.
But anyways, to confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Jun 24, 2009 | Canon PowerShot S1 IS Digital Camera
Shutter malfunction
It sounds like a part of your electronic system shorted. It's unusual anything works at all.
THe front and back housing fit together like a **** shell. After you have removed all the screws gently pry a thin blade between the halves and start seperating them little by little. You have to be careful since quiete often there are buttons and/or contacts that may fall out when you do the separation. You may want to try and pry off the front cover first (fewer buttons).
There is no real loss trying it, any repair (by a shop) would likely cost more then replacing the camera.
Jun 16, 2008 | Nikon Coolpix L11 Digital Camera
Shutter Problem
I had an Olympus C-3000 this same type of sympton happened to me. I sent it off to Olympus to be fixed (via local camera dealer). When it came back, after about 10 shots, it failed again the same way. Back to Olympus a second time. Came back and failed again after about 10 shots. This time dealer worked with Olympus and I was given a new reburbished camera (same model). This whole thing took about 4 months. Time frame was a couple of years ago.
Sep 13, 2005 | Olympus Camedia C-750 Ultra Zoom Digital...
Olympus FE-190 Digital Camera Logo
641 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
