Question about Garmin GPSMAP 60 GPS Receiver
GPS Maps 60 Won't turn on...
I have used it for about a yr...was working fine until other day...It ran out of battery power while connected via USB to my computer...I disconnected from computer and placed fresh batteries into the GPS...and it has not turned on since...I've tried everything..different batteries...looking for a reset switch...there are no trouble shooting guides in the owners manual...What can I do...other then send the unit back which will cost me over 100.00 dollars??
  • Lorie Collingwood Jan 03, 2009
    I push button to turn unit on and I hear 3 distinct beeps. screen
    remains blank, I push button again and I hear one beep. I tried holding
    button down , makes no difference , can not get the screen to show
    anything. Tried the points mentioned for contact of battery to board,
    made no difference. Not sure its worth $100 for repair, but hate to put
    our another $300 for a new one.af???
I had a similar problem. I opened the unit up and the two contacts (little metal tabs) that make contact from the battery to the circuit board had to be bent up a bit so they make contact.
Posted on Sep 12, 2007
SOURCE:
How do I upload the 2015 maps on my garmin free?
You have to purchase map updates from Garmin. No freebies.
Feb 19, 2015 | Garmin GPS
Switronix Tl-50 won't turn on
I too have had a problem with mine no longer charging. I talked to the manufacture. Since the cord light is on however my torchlights charging light is not on they said could be the batt or could be a bad wire in the charger. I've been debating whether to send it in for fix or buy a new batt to try first. For yours I would send in for repair. Unfortunately these lights only come with a 1 yr manufacturing warranty so if you've had it over a yr you will end up paying 60-130 was the price range I was quoted depending on the problem.
Mar 03, 2013 | Switronix TorchLED TL-50 Video Light - 75...
I have a Garmin Nuvi 200W and have been receiving a message that it needs to be updated. Would I need a special accessory cord to connect to my computer? Also, is there a charge for updates? Thanks in...
That could be an update for maps or software..... software updates are free... new maps are from 50 to 60 dollars..... but do a software update first...if your maps are more that 2 years old i would buy new map
with the unit Off...... connect your gps to your computer using the usb cable..(usb cable is the same connection most cameras use to connect to computers)
your computer will detect new hardware (usb) minimise pop up box
next
go to www.mygarmin.com register your gps (free) it too will detect your gps model and let you update Firmware and Maps
it will tell you to download WebUpDater utility to transfer files to your gps... Done !
Nov 27, 2010 | Garmin nuvi 200W GPS
Garmin gps powers off even when fully charged
If you're "recharging" via the car charger - you might want to try charging via USB jack on your computer - or AC adapter (if your GPS shipped with one) for 5 or more hours.
Many Garmin units develop this condition when used strictly in the car / cigar outlet power source. While connected to your computer, you should go to Garmin's website and download, install & run the "webupdater" software. When complete, your Garmin GPS will have the latest firmware and patches to the software (not maps!).
After charging via USB or AC adapter, your GPS should stay on. If your GPS turns on via a slide switch on the top, Slide the switch from OFF and hold in the ON position for 10 seconds before letting go of the switch. This should force a "boot" on the GPS.
If you're unable to get the device to power up, contact Garmin Support to determine if your device is affected by a a recent battery recall or if there are other suggestions they have to solve the problem.
I hope this helps!
Oct 08, 2010 | Garmin nuvi 650 GPS Receiver
My garmin ran out of charge and when it was plugged in to the car charger it says loading maps then stays on the garmin page and goes no further...
Disconnect the nuvi from the car charger and connect it to your computer's USB port with the supplied cable (or any USB cable you have that fits it), and leave connected overnight (8 + hours).
You should be able to get the GPS to start up as expected after charging via USB port. if this happens again, simply repeat.
Jul 15, 2010 | Garmin nuvi 255W GPS Receiver
My Garmin nuvi 250W GPS is NOT powering on.
try connecting it to your computer via the usb cable. that may reset it. outdated maps will not cause this problem.
Feb 21, 2010 | Garmin nuvi 250W GPS Receiver
When I start my garmin nuvi 765t. it will try to start but just before finishing loading the maps it shuts down and keeps trying to start until I turn it off. also my computer does not recognize it when I...
Download the Garmin Communicator Plugin and Web Updater software from Garmin's website - both tools are free and will load the proper USB drivers for your 765T.
Ensure that the battery is fully charged via the battery strength icon, prior to aquiring satellites.
To reset the 765T: Hold finger or thumb on lower right hand corner of screen while powering the unit on from the off position. This will erase all user data.
Nov 16, 2009 | Garmin nuvi 765T GPS Receiver
How do upload updated maps to my garmin660
go on garmin, connect your gps via usb , get map install program and you should be fine, works on any operating system
http://www8.garmin.com/support/mappingsw.jsp
Jul 01, 2009 | Garmin Nuvi 660 GPS Receiver
255w in a loop - loading maps, then restarts...can't recharge
Use a USB connection to your computer and let it charge for three hours. Also download updates while your at it. Cigarette lighter charger is not efficient
Dec 20, 2008 | Garmin nuvi 255W GPS Receiver
My Garmin Etrex wont turn on on batteries but it works fine on external usb power.
I have the same problem. The unit works until I connect it to whatever computer via USB (Mac or PC). The screen blanks out as soon as I plug in the USB cable. I have to disconnect the device and only then I am able to turn it on again. That started after Firmware update from V 2.90 to 3.00 . I am not sure this is causing problem. What about the firmware versions of your devices ? Are they all on the latest ?
However, does anybody know if there is a way to go back to firmware version 2.9 if it is not possible anymore to connect the device to any computer (evtl. through putting data on the microSD card ?).
Thanks,
Martin
Jul 04, 2008 | Garmin eTrex Legend Cx GPS Receiver
Garmin GPSMAP 60 GPS Receiver Logo
59 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
