Question about JVC AV-27020 TV
Help! How can you unlock a pin on a TV that you don't know?
A friend of mine was playing with the remote and all of the sudden, I can't get a channel. Only snow. I think he locked my tv with a pincode by mistake and now I don't know how to unlock it.. Are there any clues? The tv works.. watching a dvd on it now.. but the channels are totally gone.. and its asking me for a pin.. but no clue!! Desperate.. Can anyone help??
  • humais khan Jan 23, 2008
    I have a jvc tv model # av-27020 it is locked i need a unlock pin or the tv does not work i am desperate!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Anonymous Apr 29, 2008
    I can the picture on the tv but a big black block is in front of the picture. How can I get that big black block off
  • 752 Answers
Tried unplugging it for five minutes then plugging it back in? It resets the software.
Posted on Sep 10, 2007
  • Mitch
    Mitch Sep 14, 2007
    Was my answer "unhelpful" beacause you tried it and it didn't work? ....Or did you not even bother....?
  • Tracy Cosby
    Tracy Cosby Feb 07, 2019
    Same problem can u help me please
Go to summary of channel and then press your remote control channel down until the check mark beside your channel that is locked is yellow.Press channel down once more so that the lock becomes yellow.Press on the number 0 on your remote and the lock should disappear (mine did)
Posted on Feb 02, 2008
    Problem Solver:
  • 6 Answers
Type in as code 0000 or 1111or9999, 0000 should do the trick but it will unlock but every time you turn it on might ask for code so unlock go to menu and channel summary and and any channel that has a lock symbol get rid of it and fixya!t will work.
Posted on Jan 30, 2008
SOURCE:
RCA XL 100 Commercial Skip TV
Only thing I can think of here is to get a Universal remote, then try these pins to Sync your TV with URM:
RCA - 000,003,004,005,007,009,011,015,048,082,092,094,
096,098,101,102,103,107,113,125,129,067,179,187,188,191,194
May not work 100%, depending on remote functions.
Instead of just buying any, you could maybe borrow one from a friend first of all.
Oct 11, 2017 | Televison & Video
Unlock TCL-21276 child lock without a remote please help
Okay Welkins, try to power of the tv and power it on by keep on pressing POWER-BUTTON and MENU-BUTTON at the same time,... and see if the tv start into de menu mode....if it does...just keep on using volume "up and "down" button combined with channel "up" and "down" buttons to select an reach the UNLOCK-MODE...most of the time the MENU button will be the enter button after each sellection....hoping to inform you correctly I remain,Yours Friendly.
Mar 06, 2014 | TCL L32HDM11 32 Class Widescreen LCD HDTV...
My akai tv is locked,don't know the code
Most TVs have a parental control lock that can be set to prevent children from watching specific television shows. In order to activate or deactivate the controls, you need to know the four digit security code or parental lock control password. If you forget the number you chose or if the lock gets set accidentally, it is still possible to unlock the TV.
Instructions
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Sep 13, 2012 | Jensen Q2749J 27" TV
My friend gave me this tv and i plugged my xbox into the white and yellow thingys but i dont know what channel its on if please help me
If you have a remote, the channel is usually labeled "A/V" or "Video". If you don't have the remote, you might need to purchase a universal remote and use that to get on the video mode. Sometimes you can just go down further than channel 2 and it will show the A/V channels.
Jul 18, 2011 | Emerson SpongeBob SquarePants TV
Have Aiwa TV MODEL No. TV-A209 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its stuck...
have Aiwa TV MODEL No. TV-A209
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
O6895H
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
000 001 1
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Nov 08, 2010 | Televison & Video
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
AGING
6EDEH
S123 K234 Y
100 000 0
Sep 14, 2009 | Aiwa TV-S2011 20"
Problems with getting channels locked in on our plasma tv
Yuo can change the pin # even if you don't know the old one then you can can turn off with the new one.
Press the 'MENU' button on the remote control.
Press cursor down to select SETTINGS.
Press cursor right twice.
Press cursor down to select MENU PREFERENCES.
Press cursor right.
Press cursor down to select CHANGE PIN.
Press cursor right once.
Enter code 0711 if you have don't know yours
Enter a new four digit PIN using number buttons. Number combinations from 0000 to 9999 are valid.
When prompted to confirm PIN, enter new PIN again.
Press the 'MENU' button to exit the menu.
Feb 22, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
How to unlock some channels that locks by mistake on your remote?
is it a cable channel that is locked or a normal TV channel ??
if its the cable channel, you can always call your cable company and have them give you the unlocked code...
if its the TV channel... what make/model is your TV ?
Feb 17, 2009 | Daewoo DTQ-13P2FC 13" TV
Can't get to "Video 1" to play DVDs
try turning your dvd player on and then doing a channel search if that does not work just buy a RF modulator and hook up your dvd player to it and it will run on channel 3 or 4 and will switch over by itself when you turn on your dvd player
Feb 26, 2008 | Emerson EWF2703 27" TV
GE 27GT271 locked onto satellite mode?
Is there a way to unlock the satellite setting? no. Will we have to sign up for satellite for a month or so, so that we can unlock it? yes I do not know about your place I stay in INDIA & here unless you subscribe you can not see cable channels. Or are we just out of luck on this?
Sep 24, 2007 | GE 27GT722 27" TV
JVC AV-27020 TV Logo
913 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
