Home | Biostar | M7VIG-400 (M7VIG 400-COMBO4) Motherboard | M7VIG-400 NOT POW...
Biostar M7VIG-400  Motherboard
Problem for Biostar M7VIG-400 (M7VIG 400-COMBO4) Motherboard
M7VIG-400 NOT POWERING ON
By Roiboi85 on Sep 09, 2007
The board was powering on and posting with a AMD 2600+ chipset
I installed a higher chipset on the board and the CPU fan started spinning and stopped. I put back the original chipset and the CPU fan started to spin and stopped as it did earlier with the higher chip. I reset the CMOS and nothing changed. can u help me
Same Problem
Mar 24, 2009
-   CUANDO ENCIENDO LA FUENTE ,LOS COOLERS ARRANCAN,QUEDA ENCENDIDA EL LED DE HD ,PERO LA MAQUINA NO ARRANCA
-   Guest
Apr 23, 2008
-   DRIVERS DE SONIDO-   Guest
Best Solution
posted on Sep 11, 2007
Very Helpful)
fugazi
Rank: Guide
Rating: 90%, 12 votes
possible cause:
1.low supply of voltage try checking your Power Supply Unit(PSU). try to swap with a different good PSU.
2.Defective/burned Motherboard, check for any bloated Capacitors or burned chips...
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Biostar M7VIG-400 Motherboard
Questions and Unsolved Problems for Biostar M7VIG-400 Motherboard
Do you recommend Biostar M7VIG-400 (M7VIG 400-COMBO4) Motherboard?
Answer
Answer
i am having intel DG13PR mother board, now iam having front panel mic and line out connections, now... (More)
Answer
need to sound driver
Answer
Original arcade game Space Invaders, may need new motherboard. Screen image has many vertical lines... (More)
Answer
en donde en Cuentro los controladores del teclado USB de la m7vig jabalí 400
Answer
tengo un disco duro de 40 G y la placa madre me manda un mensaje de error al cargar el sistema... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Biostar M7VIG-400 Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14128
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
