Question about JVC AV-56WP30 56" Rear Projection Television
TV IS GREEN
THE PICTURE IS GREEN. SOMETIME IT WILL CLEAR UP AND PLAY NORMAL AND THEN YOU CAN TELL WHEN ITS STARTING TO MESS UP BECAUSE THE PICTURE COLOR WILL FLICKER IN AND OUT AND MAY STAY GREEN FOR A FEW MINUTES AND PLAY NORMAL OR IT MAY STAY GREEN FOR THREE OR FOUR DAYS. PLEASE HELP ME WITH THIS PROBLEM IT AS BEEN IN THE SHOP TWICE BUT COULD NOT FIND ANY THING WRONG.
    President:
  • 4,402 Answers
Gave the crt's a little rat-tat-tap be careful!!!!!!!!!!!!
There are other possibilities as well. Look at the front of the green projector tube and see if it looks like the cooling liquid has been leaking out or if it is not clear all across the screen.
could also be convergence ic's
Posted on Jan 31, 2008
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
While we're trying to watch TV, our Panasonic PT-AX200U HD projector will sometimes start alternating from a green screen to a blue screen and then to snow, and finally back to a normal picture. It's
You are experiencing Power Fluxuation. The Power Supply seems to be going out or on the way out... How old is the TV? Is it still under warranty?
Apr 08, 2013 | Audio Players & Recorders
How do I change my W2613 TV resolution to 1080i? I just bought this TV a few weeks ago and I want to be able to play my XBox360 in HD and when I connect all 6 wires (Red, White, Yellow & Green, Red,...
use just the red green and blue wires for the picture and NOT the yellow wire. That is why it is messed up.
XBOX games only play in 720, but it will still look great.
Aug 09, 2010 | Televison & Video
Component input colour is messed up
Go to the back of the TV and make sure, the component cables are inserted in all the way. Do the same for the source (cable or satellite receiver) component cables should be firmly inserted.
Try narrowing the problem by testing the TV with a different source, such as a DVD player if it compatible with the component. If the TV works with the DVD then your TV is fine and the problem goes back to the source (Cable or Satellite Receiver)
If the TV still not showing natural colors after been tested with another source.. then, the TV may have a bad PCB.
Best of Luck
Nour BMI
Feb 05, 2010 | LG 32LG30 32 in. LCD HDTV
Tv works good picture is good and clear sound is good but im only getting blue and red colors??? is that the board? or the green bulb?
That is what happened with are tv. My husband took the tv apart and started messing with everything and got the tv to line up better. he just turned the nobs and messed with the coloring.
Dec 09, 2009 | Hitachi 61HDX98B 61" Rear Projection...
My 32" sanyo picture goes green
needs resoldering, in the heated areas, such as, crt socket board, power area, and high voltage area....it will be back to normal...
Oct 20, 2009 | Sanyo DS32920 32" TV
Samsung Tantus Picture Problem. Green Yellow Black Hue
it seems that your unit got loosed contact.i mean it needs resoldering.call a technician to do further troubleshooting.
May 11, 2009 | Televison & Video
The tv screen is green
This is usualy a bad picture tube. are there any bright lines running across the screen? It would be helpful if you could give the brand and model number
Mar 12, 2009 | RCA TruFlat 27F520T 27" TV
Green screen
Not really sure how much the tv weighs, but I know it is a bunch. I have 2 of these t.v.s. One I bought at Wal-mart and after about 6 months it started doing this green screen also. I would normally give the side of the tv a good wack and it would go back to normal for awhile. The other tv I bought from my neighbor who was moving for $25. The problem with this one was the "no picture but I have sound". If I wacked this one I could get the picture to come back on for a while, but it would go out again. Well just the other day I took the back off the "no picture" tv and was looking around. I noticed that the circuit board that is attached to the picture tube was loose. I pushed it back down on the tube and put it back together and the picture has been fine since. So I thought I would check the one with "green screen" issues and sure enough that circuit board was loose also. Pushed that one all the way back down and have not had any issues with that tv either. Hopefully that fixed my problem, I guess time will tell. Maybe it will fix yours also.
May 19, 2008 | Sanyo HT30744 TV
Tv is messed up
need manufacture and model#
most likely convergence chips going
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | Televison & Video
JVC AV-56WP30 56" Rear Projection Television Logo
60 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
