Question about Sony DRX-820U Burner
DRX-820U power area error
Was burning fine this morning, burned an audio cd rather than dvd and now it keeps saying power error...any ideas
  • Anonymous Mar 24, 2014
    lost the ac power adapter
    Lost my ac adapter
    Sergeant:
  • 457 Answers
Trouble shoot it in the Device of the Control Panel?
Posted on Sep 12, 2007
SOURCE:
Trying to burn a movie from a new burner by samsung 22x 768564 dvd, but the green line doesn't keep up with the timer, i let 1 movie burn for 12 hours on timer and all it did was encode, didn't...
should not take 12 hrs to burn
does it burn data cd/dvd or audio cd/dvd's ?
you might have to burn it as an ISO image
this might be because you have not selected the option to burn a dvd movie you might have selected another option ie:burn data audio or your burning software does not support movie dvd burning
there are plenty of free burning software programs on the internet
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Sep 25, 2011 | Samsung Computers & Internet
0xeb020bc5 error in burning cd in OS vista it
easy, that happened to me and what I did was just took a cotton swab, alcohol and wet it. Then I opened the cd device and smothly clean the eye of the reader, blow indirectly to it's surface and ready!
easy solutions for big troubles, enjoy.
Aug 31, 2011 | CyberLink Power2Go
The controller only burns to 4 out of 5 drives and 1 of the 4 working frive keeps making burn errors. Is it time to install new firmware to fix this? or do i have to install new drives? Can i install...
Hi I have this problem with my systor 0-3 target duplicator, the one tray works fine, the middle one keeps making burn errors and the bottom one won't burn at all I can't seem to find a solution
Sep 20, 2010 | Vinpower 16x CD / DVD Duplicator with NEC...
I keep having failed burn sessions it says "Power Calibration error" what and how can I fix that
Their could be several possible reasons and solutions for the above error, basically what is happening is for some reason the CD/DVD burning software is unable to determine the Optimum Power Calibration rate (a small pre-burn test to determine optimal laser power for writing), resulting a disk burn failure. There is no easy way to pinpoint the exact reason, so try all the possible fixes from top to bottom (easy to hard) and see what works:
Try using different brands of quality blank media, most common reason for such error's is cheap blank media.
Try burning at lower speeds (Highly effective).
If this fails try a different burning software
Aug 20, 2010 | Sony AD-7191A DVD±RW Dual Layer Burner
CD/DVD will not burn DVD
Did you tell CDBurnerXP that you want to burn a CD? or to burn a DVD?
Does this happen with _EVERY_ "blank" disk that you insert, or just one disk?
Can your DVD-RW _read_ a previously-recorded CD? DVD?
If not, then that hardware is suspect.
Sep 14, 2009 | QPS Que! CD-Rewriter CD-RW Burner
Sense error
Every time i try to burn my home from windows to a Philips DVD-RW a message keeps popping up from my laptop saying that i need to place a DVD-RW cd in which i have done . The funny thing is that i edit my movie from my Pinnacle Studio 12 which i got last week, this was my 1st movie i burned well Pinnacle Studio did it for me really, it was so easy when i took the cd out of my hp pavilion laptop it played on my LITEON DVD Recorder & watched my movie clip on my tv, it worked fine but do you think i do this again NO SUCH LUCK i am really new to all this its so frustrating windows wont burn my move pinnacles not burning, what am i doing wrong, i ve got all new dvd-rw cds is there any one out there who can help me please :-(
Oct 05, 2008 | Computers & Internet
LineOut
Yep. Take it to the nearest Sony Repair facility, usually when they say that there in an internal problem with the audio in from the laser to the audio ic
Don
Jan 02, 2008 | Sony CDX-R3000 CD Player
Burning
YEAH YOUR ENCODING SOFTWARE
TRY NERO VISION EXPRESS
OR AVI TO DVD CONVERTER
OR IF ITS ALREADY IN DVD FORMAT
USE NERO BURNING ROM TO COPY IT
Dec 12, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Jun 13, 2007 | HP DVD940e Burner
Sony DRX-820U Burner Logo
75 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
