I had some problems with my alternator, so I took my car into the shop to get it fixed. After that, my CDE-9845 would not turn on. I took it back to the shop and they said that my car has power and no fuses are blown....it's the CDE-9845 that's not working. Is my stereo toast or is there some way to replace a fuse or fix my stereo easily? I already tried replacing the red fuse in the back, but it did not help.
The only way to know for sure is to see if it has voltage getting to it. You need a Voltage tester (DMM, testlight, etc...). There should be 12 volts on the yellow always and on the red wire when the Ignition/Accessory is on. If both are present then the radio probably got surged and will have to be replaced/repaired.
Head unit is doing nothing but showing the word interrupt. Everything appears connected including...
(More)
Head unit is doing nothing but showing the word interrupt. Everything appears connected including wiring for the suvwoofers. But getting no power to the amp as well. Remote wire is good. 2007 scion tc with alpine head unit.
I connected it to the back and all. i hooked up the mp3, it says it plays. i cant set the AUX in On...
(More)
I connected it to the back and all. i hooked up the mp3, it says it plays. i cant set the AUX in On so that i can hear the song playing on my mp3. please help?
