SOURCE: Will Not go to voice mail
Jennifer209, if you press FEATURE + the button VM is pre-programmed on what does it display? It should show the extension number pilot to VM. If you call it directly, what happens? If you get no answer calling it directly, your VM may be down.
Kaait, is it getting into the VM that's the problem, or doing things inside the mailbox that is the problem?
SOURCE: Programming speed dial numbers into NEC DTU-32D-1A phone
hit feature key,hit a line key,dial 9 plus the number,hit feature
Hello again,
Oops, I can't see the VM button. We have Feature, recall,conf, redial... We switch off the main (that switch off all phones) and on again, the light still flashing. We connect another phone on the same line, line flash on the other phone too.
