Question about Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax
Caught in spool, can not cancel or print
I have tried every advice that I found on this and other sites to get a printer for a friend on line. It printed 1 test page and not everything is caught in spool. I can not cancel them or delete them as they stay in the spool and nothing will go to the printer. I uninstalled everything, unplugged everything and started from the beginning and still nothing will print. He has Windows Vista (that I do not like workign with) with Lexmark X4270 All In One Printer. Really need help, he is disabled and really needs to be able to use his complete system. Thanks
  • 2 more comments
  • btchwzrd2008 Sep 21, 2007
    There was not rating because the problem is still not fixed. None of your advice has worked yet and I am still trying to get the printer hooked up to the computer. My friend is good with computers (she use to teach people how to install them and use them) and she can not get my Windows Vista and the Lexmark to talk to each other.
  • PePaSan Nov 29, 2007
    I have hp1018 on a wireless airport. Works fine with my mac, but any time I've added it on Vista it both fails to work and fails to delete - despite canceling all documents. Very frustrating!
  • mole2068 May 23, 2008
    I have a similar issue. Something is wrong with the lexmark's x4270 driver when used with vista. It installs, but the first document I tried to print won't delete. I printed a button from internet explorer 7. I'm not sure if that is part of the issue. The only thing I can think of is to manually delete the spool files of the hard disk. Not sure if it can be done but i'm gonna research and try it.
  • mshugge Nov 02, 2008
    I have a Lexmark X8350 all in one. Same thing has happened to me since switching to a new computer that has vista x64. I installed the vista driver. Contacted Lexmark. They advised me to change the setting in hardware>printers>print processor. This did not work at all.
    I liked the recommendation that I go into the task manager and delete any processes with lex in the name, and then refresh the printer. This didn't work either.
    I've sent another complaint to lexmark. They seem to have a system wide issue with their printers running on vista. Any other ideas?
Been working on my computer for two hours on this problem!
i could not cancel what was in the spool
do this
If you are on Vista Home Premium, go through the following steps to clear "deleted" print jobs from the print queue.
1) Go to Control Panel
2) Select System and Maintenance
3) Select Administrative Tools
4) Double-click on Services
5) In the list of services, scroll down until you find one called "Print Spooler"
6) Right-click on "Print Spooler" and select "Restart"
7) The "deleted" jobs will disappear and any queued jobs in your print queue will print
Hope this helps. I figured it out on my own without any assistance from the paid professionals
Posted on Feb 06, 2009
What I did was (and it works for me all the time) that I press (ctrl +alt+del) and choose task manager from the list of options. Then, on the task manager, if you go to "Processes" tab Instead of "applications" tab then you can see which tools/utilities are running. You can then safely click upon any of those processes e.g. anything with a "lex..." name is going to be a lexmark printer driver application. So get rid of them all in the processes. And then once all of these "printer related appz" have been stopped, you can then go onto "C:\Windows\System32\Spool\PRINTERS\" and delete all of the files from that folder. It should now let you delete all of the files. =]
One final thing (tho it wud usually do it by itself) is that refresh the printer
which is right click, then >> "refresh". And it should show the "0" symbol on the bottom right icon of the printer. [meaning there are no print jobs queued at the moment] I hope that helps other people that are stuck like I once was and found out how to fix the problem.
-pleasure, Dazz
Posted on Sep 23, 2008
I booted up in safe mode and deleted all the files under the [c:]\windows\system32\spool\printers\ folder. That deleted all print jobs in the spool. Then I booted normally uninstalled the printer. The spool problem is solved, but its unlikely this printer will ever work properly in vista.
Posted on May 23, 2008
Is ur ink low? buy new ink or push the red button stop/clear and hold it until it says all done
Posted on Sep 11, 2007
Troubleshoot/hpDeskJet 895Cse printers,how to cancel a print job
Print jobs are kept in a print spool on your computer. Turning off your printer only clears the printer. To clear the print spool on a Windows type computer, look for the printer icon on the task bar, lower right hand corner of the monitor. Double click on the small icon will open the list of pending print jobs. Select the one you wish to delete, then cancel the print job.
Feb 18, 2015 | Office Equipment & Supplies
HP 1500 will not stop Printing
Printer of all types connet to a computer and make use of a spooling service on the computer. You may need to go into the Printers and Faxes section of the computer from the Start button and open up the printer you are using and right click on all the documents that are listed there and click on cancel. There is a relationship between printer and computer with handshaking so you need to cancel and let the printer be connected to cancel the jobs. Pull out the paper tray might be a way to have it stop printing while to cancel the jobs. The cancel or clear on the printer only affect the jobs held in the memory on the printer and then as soon as that is clear the next job from the spool comes in. Clear printer spooling and then the printer should stop.
Jan 30, 2013 | HEWLETT-PACKARD Hewlett Packard Products -...
I want to cancel a printing job. Please help.
Dear friend,
In windows Xp or 7,open command prompt,
type the following
@net start spooler
@echo off
@net stop spooler
@rmdir /s /Q "%SystemRoot%\System32\spool\PRINTERS"
@cd %SystemRoot%\System32\spool
@net start spooler
@echo off
@net stop spooler
@net start spooler
hope it'll help.
Mar 07, 2011 | Brother HL 2140 Laser Printer
Document will not delete, keeps spooling
go to the devices and printers
click on printers click on --what's printing or printer tasks
high light and delete each line
Feb 10, 2018 | HP PhotoSmart InkJet Printer
My daugther is trying to print but the documents are coming out side ways and the printer is printing the same thing over and over. I tried to cancel the printing , cut off the printer, unplug it and is...
you need to give the following commands at the run
you can get it from the start menu..
in it give the following code
one by one each line
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
it actually cancels the print jobs and deletes the contents in the buffer..
you should give the files to print again....
if it helps you please give a vote....
Mar 02, 2010 | Brother MFC-7340 All-In-One Laser Printer
How to cancel a print job that has multiple copies selected for the print job
Click Start
Click Control Panel
Click Classic View
Click Printers
Double-click the active printer to open the "job-queue" window
Select the file to be cancelled
Right-mouse click on the selected file, and choose cancel.
Nov 17, 2009 | Microsoft Windows XP Professional for PC
Printer problem
Cancel all print jobs because most likley you have an error in a print job so cancel them shut off your printer turn it on nd try to print again
BestWishes                  -SunShine-
Jul 04, 2009 | HP LaserJet P2015dn Printer
The printer is printing so slowly.
I think what happens with these printers is Spyware and virus scanners etc... on our own machines remove the odd file..
Try putting the CD in the carriage when you are about to print something. Make sure it does not get stuck on the auto start page. Cancel and leave in carriage. Have found the odd time if the PC is looking for a file it will grab it off of the CD!
My Printer properties - Ports. Have configured mine for two ports Virtual USB and the dot4.... USB. I have enabled bi-directional printing and printer spooling. Enable printer spooling. Ensure start printing immediately is selected. Not sure if this will work but give it a go. Then Printer properties - Advanced - Always available - Spool print docs. so program finishes printing faster - Start printing immediately - Print spooled documents first - Enable advanced printing features.
Not sure if this will work but hope it helps.
Feb 21, 2009 | HP OfficeJet 6110 All-In-One InkJet...
it looks like it was hanging, reset the unit again and cancel all spooled file that you wish to print, even all the queued file, the file was somehow corrupted along its way
Nov 27, 2008 | Panasonic KX-P1131 Matrix Printer
HP 2600n can't cancel the last document
Just stop and restart the printer pool service through administrative tools -> services.
Nov 09, 2007 | HP Color LaserJet 2600n Printer
Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax Logo
663 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
