Question about RCA RCD148 CD Boombox
LCD not working.
Okay ever since i got this boombox, which was like a couple of years ago, the damn LCD display thing has not worked. how do i fix that problem? Or is it just permanently ruined and has been since i bought it?
0 characters
1 Points
JVC RV-DP100BK orange backlit illuminate LCD display stop working?
You need a new bulb installed - difficulty is semi hard , in that you must take apart the boombox , remove the shroud around the bulb , unsolder , resolder new one ..take the old one to an electronics shop to match.
Apr 08, 2013 | JVC RV-DP100 Cassette/CD Boombox
My Emerson 5812 Boombox will not turn on all of a sudden. I just bought it a couple months ago and it will not power on.
If its still under guarantee then take it back to the shop if you have the receipt. If not then it could be something as simple as a little glass fuse inside the boombox.
May 21, 2010 | Emerson (PD5812) Radio/CD Boombox
Ac/dc plug doesnt energize boombox. What should I
several days ago I get my blaster from ebay (don't like that new version in girlie size, is there a pink hello-kitty version out now?).
The first thing on my macho man machine I repaired was the bulb for the display. Also I modified some internal wiring as of the weak 12V DC connector. Inside there are two fuses, one 8AT for the transformer and one 6.3AT for 12/15 VDC. Probably on your machine this fuse is imply blown off. To unmount the front and rear part of the assembly you need a pretty long slim screwdriver for two deep buried screws. I made it by my own (**** blade, works well for that slow-torque screws) of a slim rod. Also remove the bass speaker covers with Allen key nr 4. Two of the screws on each side are dummy screws. Also remove two of four screws of each bass speaker and loose the others.
Greetings from germany, df4ian (eat)
Apr 12, 2010 | JVC RV-B99GY Cassette Boombox
FM reception
Assuming the antenna connection is not broken, an old trick is to get a sizeable piece of aluminum foil and twist the center of it making a big bowtie. Wrap (twist) the center of the bowtie around the top of the antenna and see what happens. Try turning it so it points in different directions to see if any particular direction gets better reception.
Mar 31, 2009 | Aiwa CSD-TD901 Cassette/CD Boombox
UO I is displayed even when plugged into A/C
okay try it 2 times and if does not wotk go to a store and try to fix it okay
Jul 30, 2008 | Panasonic RX-D20 Cassette/CD Boombox
Display light
This is the backlight, bulb 9V. must be repaced, i suggest to replace by a 12V. bulb
Unit has to be disassembly. Good luck
Mar 03, 2008 | JVC RV-B55 Cassette/CD Boombox
Digital Display
Last time that happened to me I moved it to a different outlet and it went back to normal. a couple of days ago this happened again though, and nothing i've tried has worked so far.
Oct 08, 2007 | RCA RCD158 Boombox
Emerson PD6810 CD Boombox Error
My older model PD6810 had the spindle that holds the CD on the player missing causing the ER message to show and the player to stop working.
Aug 21, 2007 | Emerson PD6810 CD Boombox
Display light out
Hello, I've had JVC RV-B90 Boombox for few yearst too, but display lighting is ok, There is just small bulb, so take it apart and just change bulg for new one. Good luck !
Jan 17, 2007 | JVC RV-B99GY Cassette Boombox
RCA RCD148 CD Boombox Logo
Top RCA Boomboxes Experts
Jonathon summesfield
Are you a RCA Boombox Expert? Answer questions, earn points and help others
