Question about Mitsubishi WS-65615 65" TV
Pic n pic
I can get my pc n pic to work. it says can not view same channel
    Problem Solver:
  • 9 Answers
You have to have an analog signal plugged in ant-1 input read below
Operation of PIP and POP
You can display programs from analog channels, analog inputs or devices as Picture-In-Picture (PIP) and Picture-
Outside-Picture (POP). The TV has a second analog tuner for non-scrambled analog channels received on Ant-1 and
will display them as the PIP/POP sub-pictures. Digital channels and devices can be shown as the main picture but
cannot be the sub-picture. PC screens can be viewed in the side-by-side mode.
Press PIP/POP to activate. With each press of PIP/
POP on the TV remote control (within 3 seconds of
each other), PIP/POP will cycle through the following
display options:
MAIN
PICTURE Side-by-Side
* POP
side-by-side
pictures
MAIN
POP 1 I
POP 2 I
POP 3 I
* 3 POP
MAIN
POP 1
POP 4
POP 7
POP 2 POP 3
POP 5 POP 6
POP 8 POP 9
* 9 POP
Aqt-l 2 )O<XX
Standard
Stereo SAP
TWPG DLSV
SQV1
PIP Anhl 17
* PIP large
_tq2XXXX
S_nd_d
Stereo SAP
TV-PG DLSV
SQV1
PIP Aqtq 17
* PIP small
Standard
Stereo SAP
_ oLsv
* PIP/POP: off
PIP/POP can be turned off, 10 seconds after displaying,
by pressing PIP/POP. The next time you activate PIP/
POP, the last used PIP/POP option will be displayed
Changing PIP/POP Device
Press PIP DEVICE to change the PIP or POP picture
source device. A menu similar to the Device Selection
menu will be displayed. Not all devices can be
displayed.
Changing PIP/Side-by-Side Channels
Press PIP CH to scroll up and down through
memorized channels on AnN and Ant-2.
Exchanging Program images
Press EXCH to exchange the main picture and the PIP/
POP picture. This feature is only for analog pictures.
Moving PIP Image
If no menus are on the screen, press ADJUST A, V,
or • to move the PIP display anywhere on the main
screen.
Automatic POP Switching
When automatic POP switching is active, the TV will
cycle through memorized channels on Ant-1 or Ant-2 or
strobe pictures from other A/V components in the POP
display. Press PAUSE to pause or restart automatic
POP switching.
Selecting POP "Live" Image
Press ADJUST A, V, _ or • to select a different POP
"live" image (automatic POP switching must be paused.)
Freezing the PIP and Side-By-Side Picture
Press PAUSE to freeze the PIP and side-by-side
images. Press PAUSE again to return to a "live" image.
IMPORTANT
Side-by-Side cannot show the same channel or
device on both screens.
When Ant-1 or Ant-2 is the main picture, Ant-2 is
not available as the PIP, POP or Side-by-Side.
HDMI and DVI devices can be the main picture only.
PIP/POP is not compatible with signals from IEEE
1394 or some digital channels.
Posted on Oct 10, 2009
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Can get my pc n pic to work. it says can not view same channel please clarify problem in more detail thanks
Posted on Sep 10, 2007
SOURCE:
How do I download and view pics from my camera to PC? HP Desktop Vista/XP
Hi Lynn this is Alex Walker expert to help you for this call +1(404)981-1535 I will be glad to assist you
Dec 27, 2015 | HP Pavilion Computers & Internet
I can't get my pic from camera's memory card to upload. Neither from camera hooked to PC, nor memory card in PC's memory card slot. #2) I can't view my pic on the camera either. The
If you hook up your camera using the usb cable make sure the camera is on. Next go to my computer and click on the drive that is new and open,. then you can access your pictures.
Jan 11, 2013 | GE X500 Digital Camera
View/Import pics from folders
Just connected the camera at pc and search as external device... or use one external card reader in order to connected your SD Card at pc.
Aug 08, 2012 | Canon PowerShot A480 Digital Camera
I need a pic. of a 03 chevy trany with a 323 eng.
Let me know if this helps you....
internal component exploded view:
the case and related parts exploded view:
the channel plate exploded view:
the PArking Pawl, and related parts exploded view:
the gear train exploded view:
Jun 26, 2012 | Check Point Network Adapter
How to download the internal memory of my Panasonic Lumix DMC T27 to the memory card
Go to previous view pics in internal memory, select the pic and then "move"at SD Card (work in some models).
Other possibilitie, take off the SD card and connected the camera at pc, open explorer software and copy/paste the pics from camera at one folder in the pc. Verify that the pics are saved and secure, so, delete the files in the internal memory. Turn off and unplugged the camera.
Then, take on SD card inside camera and reverse procedure, copy/paste from pc to SD card (like a external device).
Hope helps.
May 25, 2011 | Cameras
My proscan 32LB30QD won't power up. It worked
try this first:
Setup and Connection
The TV won't turn on Check your power cable connection.
• t can't view the Basic channels. Check the connection of the antenna cable
• t want to view cable channels. Register with your local cable company then connect their receiver to your TV.
• t want to view satellite channels. Setup your Satellite parabola antenna then connect your satellite receiver to the TV.
• Digital broadcasting is not functioning Check your antenna cable connection. Check if the digital channel selection is correctly
connected to your antenna cable.
Jun 15, 2010 | Proscan 32LB30QD 32 in. LCD TV
Im trying to sync pics and ringtones to my phone but its not working
if your phone has bluetooth activate it and make it visible. If your PC has bluethooth do the same and it should find the phone automatically. After it does you can send pics and ringtones to the phone from the PC. You can also view the pics/ringtones on your phone, as you do you should have a menu feature to let you send them via bluetooth. Hope this helps.
Feb 20, 2010 | Motorola Mobility Mobile PhoneTools 3.0...
Can't receive pic and sound with the converter box.
The tv should be on channel 3. Otherwise, you can go to menu on tv, then find "autoprogram" and it will search all available channels. Usually tv should be on channel 3 if hooked up with a coaxil cable and aux or AV or Input if you are using rca jacks.
Jul 08, 2009 | Televison & Video
UNABLE TO VIEW PICTURES
no disc for these cams...should be able to view pics straight from SD card thru a card reader to pc...(may have to go thru START..MY COMPUTER...LOCATE DRIVE CARD READER IS DESIGNATED AS....
also should be able to view pics on tv thru video cable attached to cam.
Jan 24, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Mitsubishi WS-65615 65" TV Logo
162 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
