SOURCE: 96 Voyager won't start
Then the next thing to check is the starter itself, are you hearing any popping noises from the base of the motor? The starter should not be hard to change. Once you pull it out you can take it to the autozone and they can test it for you. The starter solenoid may be bad also, but these are normally attached to the starter. I hope this helps give you some insight.
SOURCE: Are there any main fuses on a 2001 plymouth neon
Have you checked the starter solenoid. Your battery + cable connects to this then + cable runs from it to your starter. You also have an ignition switch wire connected to this. Just follow your cable from the battery and it will lead you right to the part. Some times these will break inside or the contacts go bad inside and therefore you will not get power to start the engine, but you will have power to turn on lights or whatever other accessories.The part is about $15
SOURCE: car won't start
A mechanic would check for voltage at the starter, the neutral safety switch, and the key switch. Also check the ground connections.
