Televison & Video Logo
Posted on Sep 09, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears.
Anonymous
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 556 Answers
  • Posted on Sep 10, 2007
Anonymous
Expert
Level 2:
Prodigy:
Answers
556
Questions
0
Helped
173028
Points
916
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears .if your tv is very old than it might be due to crt getting weak crt base loose loose contact in power supply thanks
I have a 2005, 42" toshiba LCD model 42DPC85 that when we turn it on everything is good except the whole screen is black but imediatly the colors dot by dot start making the black disappear, it only took...
You need a new DLP chip. The chip has little mirrors that are black on one side and white on the other side. When the chip wears out , your screen will turn white one dot at a time or black one dot at a time or they may just all stick shut at once. Since your screen is black, all your mirrors are closed. You can buy the chip from shopjimmy.com and they have a video of how to replace the chip so you can do it yourself. It takes about 1 1/2 hours. The chip is about $160. To have this service done for you is about $200. Do it yourself and save the money. Your tv will be just like new again. Just make sure the chip is in perfectly level or when you turn your tv back on, your picture will be slanted. you won't notice it on the picture itself but words on the screen or scrolling messages and the menu will be slanted.
1helpful
CS-40503 takes about 10 minutes for the picture to appear once the set is turned on (sound comes on immediately)....when the picture does appear, it's dim for approx. 5 seconds then comes up to full...
IF THIS SET HAS PIP (PICTURE IN PICTURE) THAN I'D SAY THE PIP MODULE IS GOING BAD. YOU CAN REPLACE IT OR GET THE BYPASS PLUG FOR IT. IT JUST PLUGS IN.
2helpful
2answers
I get a black square on my screen after about 30 seconds when I tune to some channels. Does not do it on every channel. If I tune to another and then back it will be gone but soon reappears. jd
This sounds like your closed caption has been activated. There are several closed caption options that aren't used for anything, and if you select one by pressing the cc button on your remote by mistake, it will cause the problem you're having. To fix the issue, locate the cc, ccd, or closed caption button on your remote. Press it until you the option "off" appear on the screen. Once you see "off," simply stop pressing the button and the word "off" will disappear.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
1helpful
Icons and Start tool bar disappearing every few seconds
Sounds like the explorer.exe process might be restarting. Open Task manager and keep refreshing the processes to see if explorer.exe disappears/re-appears.
2helpful
Sony KLV-S23A10 takes approx 30 minutes to warm up
OFF YOUR TV WITH POWER BOTTON, THEN PRESS IN REMORE CONTROL DISPLAY BOTTON # 5 BOTTONVOL + BOTTON AND POWER BOTTON.( DISPLAY--5--VOL+--POWER)
No picture for 3-4 minutes after start up
Roger,
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Bill
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
