Question about Kenmore Elite 45986 Front Load Washer
Washing machine spin with noise
When im spin cycle it rumbles, please help
  • 209 Answers
I am a recently retired appliance engineer of 20 years sounds like the dreaded drum bearings, to check, switch off and open the door and try to move the inner chromed drum in the direction it should not go (pull towards you with your hand near the rim edge just behind the door seal) (and not too much force)if there is any play movement or it rattles then yes its confirmed, if the back of the machine is removed you may also notice brown rust water marks coming from the center rear of the drum just behind the center of the pulley always work with safety with the plug removed, if i have helped please rate me, and if i am correct (sorry) could be an expensive repair
Posted on Sep 09, 2007
My fisher paykel washing machine top loader is making terribe noises particularly on spin cycle. Can this be fixed
if its scraping noise some is jammed between the out and inner bowls if more of a rumble bearings are worn out
Jul 26, 2018 | Fisher Washing Machines
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Oct 22, 2014 | Washing Machines
Noisy & will not progress to spin cycle
The tub must pump down before it will go into spin cycle. My pump was making rumbling noises and when I took the basket out (simple process) there were a couple of bobby pins stuck in it. (kids) Cleaned it out and checked the flowpath with a wet and dry vacuum on the drain connection. Still makes the noise. There is a small zip lock bag under the control panel that describes the trouble shooting and error codes. It also says how to go through the diagnostics steps. Hope this helps.
May 30, 2010 | Fisher and Paykel GWL11 Top Load Washer
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
Rumbling noise during draining
i know with my fridgeadair it was the pump going out of mine , it would take me 3 spins to get the clothes wrung out enough to put in the dryer.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Washing machine makes weird noises
hi,
There might be the problem with bearing of rotor mechanism or some garbage so please clean it .
Thanks
Aug 12, 2009 | Admiral AAV7000A
Loud noise in washing machine
Hi, Raise the lid and stick something into the hole to activate the lid switch. Start the washer in spin cycle and after 30 seconds or so, release the lid switch and see if the tub continues to turn and make the rumbling noise. It sounds to me like the block that holds the inner tub has gone bad.
Has nothing to do with the move but, might have just happened.
Please let me know if this is the case or if I can assist you further.
Thanks
Vic
May 30, 2009 | Kenmore 22422 Top Load Washer
Washer making noise during spinning cycle.
why is my ge front load washer making a rumbling noise
Jan 06, 2009 | GE Washing Machines
Spin cycle noise
pull up and down on your basket to see if it has up and down play in it
kind of rock it side by side too
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Elite 45986 Front Load Washer Logo
1,141 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
