Question about Pioneer PRO-610 58" Rear Projection Television
Elite Pro 610HD Turns off
TV turns off by itself after certain amount of time. In warmer ambient it goes off sooner. Turning off audio helps and extends the time. Looks like temperature sensitive. Anybody knows what is the problem/where to start?
  • LDMil1 Oct 07, 2008
    T.V. automatically turns off as soon I turn it on thought it may be a power issue however after the t.v. cord was replaced problem still exist.
  • daveleland May 21, 2009
    My set has the turn off issue. From what I have read it is probably due to a cold solder joint on the power supply board. I haven't had time to fix it as yet. It should be a relatively simple job. In my case, I am able to turn off the master switch, wait 10-20 seconds, turn it back on, and everything works properly for a time. Once in a while, that doesn't work. In which case I unplug the set and wait 10-20 seconds for the automatic circuit breaker inside to reset. If you have expertise in electronics, you will already know how to fix it from what I have said. If you don't, I would call for service. Simple job it is, there are live parts which can do harm- even after days of being unplugged. Be Careful. I have personally seen a technician fly across a 20ft wide room from a high voltage shock.
    Problem Solver:
  • 13 Answers
You may need the power supply board resoldered as I had the same problem. The guy listed below can do it for you as I shipped mine from Illinois to him in California... Piece of cake getting the board out of the back and it's not too fraigile... Just pack in bubble wrap and it will be fine. My TV is now working great.
BUT DON'T DELAY AS SOONER LATER TV WILL NOT RESTART..
http://www.avsforum.com/avs-vb/showthread.php?t=402397&pp=30&page=38
Good luck.
cell
Posted on Jan 16, 2008
Ours did this.   Service guy said the connections on the pc boards were loose.  He claims to have reworked them (re-soldered)
No problem after he returned the boards.
The reason sounds weak to me but what ever he did he fixed it.
Posted on Oct 20, 2007
SOURCE:
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
My sournd sound turns on then turns off can any one help
so is this sound on the tv or a sound system
May 03, 2009 | RCA F32649 32" TV
Problem with pioneer elite pro-99
We are having the same problem of the Pioneer Elite Pro-99 turning itself off all of a sudden. The red 'non' power button comes on as if we had turned it off remotely.
We would love to resolve this. If you can help let us know.
Jun 30, 2008 | Pioneer PRO-99 TV
Trying to find power supply unit for pioneer elite pro-610hd
Try PTS Electronics, they sell PCB's for TV sets. You'll have to register as a consumer.
Geno
Mar 06, 2008 | Televison & Video
Tv turning on and off itself
Try "hiding" the remote from the set so that the TV cannot "see" it. Hope this little trick helps...accordianman
Jan 22, 2008 | Philips 43PP9202 43" Rear Projection...
Aquos Turns off by itself
no. It goes black, then about 5-10 seconds, it turns itself back on.
Jan 01, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Pioneer 610HD Turns on the will shut off to stand by after 1 second
You have problem in the power supply section of your set. You can obtain a service manual for 12.99 at the following link and they provide free help in diagnosing your problem. They will also email the manual to them if you click n the contact us link and request they email it.Hope this helps.
http://servicemanuals.vstore.ca/
Dec 31, 2007 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer 610HD Rear Projection
Check all solder joints on the deflection board.
Dec 10, 2007 | Pioneer SD-582HD5 58" Rear Projection...
TV KEEPS TURNING OFF ITSELF
this sound like your regulator is not working see if the set turns off in white senes if so replace it
Oct 15, 2007 | Samsung HC-P4363W 43 in. TV/DVD Combo
My TV turns on by itself
does it Turn on at a certain time? or its turning on all the time? Those it have a mechanical switch like some DVD players have? It may be a broken contact in sidethe switch is making it going on all the time. Best Regards Patrick
Aug 27, 2007 | Philips 27PT81S 27" TV
Pioneer PRO-610 58" Rear Projection Television Logo
1,672 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
