Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
Loss os self propel and suction??
I noticed in the past couple of cleanings that my vacuum doesnt seem to pick up anything except for when i use the attachments and also it seems to take alot f effort to move the vacuum across the carpet...
  • fredzsis29 Mar 16, 2008
    How do you replace the belts?
    Is the 40201170 the correct belt to replace it with?
  • mary louise Mar 24, 2008
    I have the 6634-900 model. I bought it at Target, about a year ago, brand new in the box. I have had trouble with the self-propelled option not working, and the on-off switch does not work. But, the real problem is the roller does not spin. It will roll if I push it sometimes. And the suction is good, so it picks up somethings in its path. I just spoke with Hoover, and I have to produce the receipt, take it to a local dealer, and if it is out of warranty, I am looking at a minimum bill of $50-75 and higher.
    Out of frustration last night, wanting to vacuum....I took apart the handle and re-aligned the on-off switch and positioned the self-propelled option in the off position and tape it, on the outside, so it would not move. Now, the vacuum will turn on and off and I am not going to use the self-propelled option. Soooooooo frustrating. And what a dirty job..ugh.
    The repair store said because the little v-shaped belt looks shiny on the side, it might be caused by a pulley switch not operating...where is the pulley switch located?
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Posted on Mar 18, 2008
  • 126 Answers
Your belts are worn out. These belts should be replaced once a year.
Posted on Jan 20, 2008
SOURCE:
When should I replace my vacuum roller brush? How long should the bristles be to properly pick up debris? It doesn't seem to pick up on our tile floor any more. (NSS-Pacer-115UE)
If the vacuum is weak, it may not be the brush. Bag and filters need to be clean and empty. No obstruction in the vacuum system. Motor running at full speed. etc etc.
Jan 01, 2018 | Vacuums
My kirby shampooer doesnt seem to be placing foam on the floor like it should and it's not picking up any at all
Mine did that once and we were missing the filter part on the end of the shampoo hose attachment.fits on the end of the hose. Bought a new one at the Kirby store for cheap. It looks like a filter screen and without it just seems to soak the carpet without foaming up or cleaning it very well.
Oct 02, 2010 | Kirby Ultimate G Bagged Upright Vacuum
It doesnt seem to be picking anything up
Check the hose...they plug up and then everything stops...
Here is a tip that I wrote after having the same issues with my Bissell...
Bissell Bagless Upright Vacuum2_bing.gif not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
May 20, 2010 | Dirt Devil Featherlite Deluxe Bagged...
My hoover windtunnel is not picking anything up all of a sudden. Also the roller underneith is not spinning. I've replaced filters and the attachment part is working fine, just when it's in the upright...
The belt that drives the brush roll has broken. That's why it doesn't pick up and why it doesn't pull itself forwards. Check the User Manual (download from Hoover website if necessary) for information on replacing the belt. Good luck!
Feb 05, 2010 | Hoover U6630-900 WindTunnel Bagless...
My vacuum doesnt seem to **** up anything
It is either clogged or a inlet filter is blocked with dust. If something is clogging pickup tube. Flip over and clean out. Take off dirt catcher and make sure it is clean.
Jul 03, 2009 | iRobot Roomba 560 Robotic Vacuum
No suction in the hose
Take the Hose out bcack run the water hose thru it full blast to unclog it then leave it hanging to dirty all the water left inside out.
Aug 20, 2008 | Bissell 6594 PowerForce Bagless Upright...
Poor suction
Check the inlet down by the brush roll, make sure it is open, if it is then the hose itself must have a clog. If the hose comes off, drop something like a marble in one end and see it it comes out the other end, if it doesn't then you have a clog.
Jan 10, 2008 | Dirt Devil M1100009 Reaction Soft Touch...
Bad smell
it may be the roller bearings?
Dec 26, 2007 | Hoover U5450-900 Windtunnel Supreme Bagged...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
152 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
