Question about Dometic RM2652 Refrigerator
Need directions to remove and replace 110 element in Dometic 2652
Need directions to remove and replace 110 heat element in Dometic 2652 refrigerator
  • Red River RV Repair Aug 29, 2017
    I own a mobile RV repair company (redriverrvrepair.com) When you open the service panel on the outside of your coach to the right you will see a 6 x 9 panel held on with three screws. Remove that panel. You will now see the heat riser cover and a metal rod bending out at an angle with wires connected to it. That is the heating element. You will want to see if it is free by wiggling back and forth. If it is frozen and will not move - DO NOT FORCE IT!! It has ruptured and welded to the inside of the cooling unit. Forcing it to move could break the weld and cause the ammonia/hydrogen to leak out which creates a fire hazard. There are two small tubes that a heating element can be mounted into should the first element seize into place. If you opt to install a new element in the second tube - a. I am not responsible for any issues and or damage that may arise from your choice to work on your own unit. b. Cut the wires off of the old heating element so as to not get confused. c. If the cooling unit has been compromised adding a second heat source could ignite the hydrogen and cause serious injury and loss of your unit. My recommendation is that you have the cooling unit replaced if the heating element has welded into place. Moving forward, there is a small metal cover that is removable that holds the heating element in place - remove that plate. Remove the cover from the circuit board. Locate the two wires from the heating element (take a picture before unplugging anything so that you will know where to reconnect) and unplug them. Now, while apply upward pressure begin to wiggle the element back and forth until it is out of the tube. Once removed, discard and install the new element following the procedure in reverse order.
    Problem Solver:
  • 9 Answers
Get to the back of the fridge. On the right hand side, there is a metal tube about 4" in diameter which starts at the bottom and goes up. This is a piece of thin sheet metal, which holds insulation against the refrigerant line that goes up the right side of the fridge. The 110 volt heater is located inside of that, near the bottom. The heater sits inside of a small tube, welded to the refrigerant line, and is easily replaced. To get to it, remove any flat sheet metal parts that block your view of the 4" tube (you will need to have a clear view of the bottom of it.) Then you can see the heater. It is on the left side of your 4" tube, metal, about 5/16" in diameter, has 2 wires attached, and sticks out an inch or so to the left. Trace the wires back to where they are connected on your fridge, and remove them, (probably with a small straight blade screwdriver.) It may be necessary to remove another cover or 2 to get to that connection, so remember where all your cover plates came from. Digital cameras are great ;-) . Then, on your 4" tube, unsnap and open the "door" (the metal piece which is a couple if inches wide and 7" or so high,) Grab a hold of your old heater, and pull it up. It probably wont come up all the way so you can lift it completely out, so you will have to unsnap some of your 4" tube above the door. When you remove the old heater, note its position relative to the insulation and refrigerant tube, 'cause the new one goes right back in the same spot. Pull the old one out, and put the new one in. You will know you have it installed correctly when it is snug in its own little tube (you wont be able to see that part,) and there is no side to side play. Then reverse the directions, and put everything back together again. When you re-attach the 2 wires to your unit, don't worry about getting it wrong, it doesn't matter which wire goes with what connector.
Posted on Jul 26, 2009
    Habit-Forming:
  • 62 Answers
Take ref out remove sheet metal cover and fiberglass and their it is
Posted on Jun 05, 2009
  • 4stevetaylor Jul 24, 2009
    Remove refrigator then remove sheet metal that is wrap around buner unit. The element is in a tube next to the burner unit it has to be twisted to get it out
    President:
  • 704 Answers
Here's a manual for your fridge, it has a diagrams of the unit, which should allow you to remove and replace the element.
http://gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Hope you find this helpful and best regards!
Posted on Aug 08, 2009
  • Alan Hand Mar 15, 2015
    Do you have an update of the url above as it doesn't work anymore. Thanks
  • Mark
    Mark Mar 18, 2015
    It appears the one I linked to 6 years ago, is no longer a valid. Here's the manual on another site.http://kitchen.manualsonline.com/manuals... Also, here's a Youtube video that walks you through the process.https://www.youtube.com/watch?v=b2zioJ7X... That should help you address your problem! Hope you find this helpful and best regards!
Place heating element on dometic 2652 . The 2 heater leads j7 and j8 need plugged back in. Does it matter which goes where? they are both black wires
heating elements are simply resistance wires and allow current flow in either direction
so there is noconsideration for polarity
either way will be correct
Mar 08, 2016 | Dometic RM2652 Refrigerator
How to convert 110v to 240v dometic 2652 fridge ?
Simple solution would be to step down the 240V to 110 V with a transformer .
Jul 01, 2014 | Dometic RM2652 Refrigerator
Dometic rm 2652 refrigerator will not cool
if voltage to unit remove thermistor let run if ok replace thermistor if not see if chimney hot if not heater element if doesn't work on LP bad control board
Nov 18, 2013 | Dometic RM2652 Refrigerator
How to replace heater unit RM 2652
remove back panel remove black cover see black wires follow to element
Sep 30, 2013 | Dometic RM2652 Refrigerator
I have a dometic 2193. It will not cool down at all.
if hot replace cooling unit or thermistor if not hot heater element
Sep 05, 2012 | Dometic RM2193 Compact Refrigerator With...
Dometic 2652 cooling on gas but not on a/c
No AC operation
- operates on gas mode
Operation
AC Volts
Fuse
Heating Element
Wiring
Lower Circuit Board
Jul 03, 2011 | Dometic RM2652 Refrigerator
I have a dometic 2652 in our rv we went to change the heat element at the back of the trailer and the element broke off inside the tube because it wa seized
http://www.rvdealership.com/rvdstore/index.aspx?CustomerNumber=885555
You can probably order the parts you need from this web site. Look at the diagram to spot the broken parts - which will get you the part number and then you can do some web shopping for the best price.
Jun 08, 2011 | Dometic RM2652 Refrigerator
RM 2652 RV refrigerator runs on gas, not on AC. Power surge took out power converter and refrigerator power module. Replaced converter and power module. All display panel lights working. Cools great on...
just had same thing happen to mine. replace control board. starting working on gas. one the ac I then replaced the ac heating element and now working great on ac
Mar 21, 2011 | Dometic RM2652 Refrigerator
I have a dometic rm 2652 in a 2003 travel trl. The propane side works. The elect side quit working. There is power to plug. The lights for auto and fridge inter. also work. The two fuses are good.
Unplug hydro plug to fridge. Remove cover on circuit board. Follow wires from heating element, to terminals on circuit board. ( probably J7 and J8 ) . With an AC volt meter or multimeter set to AC voltage, turn fridge on hydro, and leave door open on fridge so that it calls for cooling. To be sure it's calling for cool, try gas first, when it's starts, you know it's calling for cool, then switch to AC operation. Now test for voltage at the 2 terminals that the heating element were/are attached to. If you get 100-120 VAC, then replace the heating element. If not get back to me and I'll walk you through a couple more tests.
Jan 26, 2011 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
3,889 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Lollo Pop
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
