Question about Orion STV2763 27" TV
TV The plug were the coaix plugs in came loose
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
See where plug goes to socket is big in size or plug or socket is loose call electrician to make it okay thanks
Posted on Sep 10, 2007
Why wont my sharp lcd LC-32D44U turn on?
Well, there could a be few issues. First thing is to verify the breaker that gives power to that wall has not tripped off in the home's break power panel. If it is not tripped then verify the wall outlet that the TV is plugged into has a reset button, like a GFI (ground fault interrupt) If it does then verify that it has not tripped. If the GFI on the wall plug is tripped simply push the reset button back in and then try plugging in your TV power plug again. Then if that checks out or does not have a GFI outlet, verify that the power plug going into the back of the TV is not loose. Unplug and replug power plug that plugs into the back of the TV in and verify it is securely connected. Lastly, the power supply in the TV might have gone out.
Aug 22, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
The av2 input doesnt work
Look for any loose contacts in RC jacks/sockets/Cable. Connect another input on that input of the TV and check. Connect your ps3 to some other TV and check.
Aug 05, 2012 | LG 32LG30 32 in. LCD HDTV
Our TV seems to reboot it self regularly while we are watching it. Why does this happen and how can we prevent it?
Hello
Just check your wall plug for contact loose. it interupted supply comes to the TV, this type of fault will occur. Try plug the device to an other plug point without any loose contact and check. OK.
Feb 20, 2011 | Vizio E371VA 37 in LCD TV
My terminal board became loose as a result of moving the tv from one house to another, the cable input is still in tact but when i hook up a dvd player to it and hit tv/video it shows all of the ports as...
you may be able to remove the back cover and see if any connectors are loose or if the board is plugged in(if it plugs in). get a pencil and gently press each of the connectors that have plugs in the to see if they are loose..re-assemble the tv and try it...worse case is circuit board is cracked or solder connections bad
Dec 27, 2010 | Samsung PCK520R TV
Our Panasonic tv is about 8 years old and will cut off by itself and a few minutes later it will come back on. Some days it is worse than other days. Please advise what we need to do. Thanks, T. Gibson...
The first thing you can do is try plugging it somewhere else. Sometimes its the wall outlet. Unplug it and check to see if the plugs don't wiggle. Sometimes the metal plate on the plugs has broken loose. While it is plugged in move the cord to see if it does it. When all that don't determine the problem. You can open the TV, and check for loose connection, and cracked solder joints. Look aroun the flyback area because thats where most cracks develop because of its weight. I really don't recommend opening the TV because you could make the problem worse if you are not carefull. Also the tube can have lethal charge even if not plugged in, and some TV this charged remain for up to three days. Good luck.
Jun 27, 2009 | Panasonic CT-32D12D 32" TV
Color TV
it might be due to
  • plug or socket loose where tv is connected.
  • loose connection in switch.
  • some connector loose in power supply
  •  switching transistor in power supply &horizontal section loose or wire open
  • some capacitor loose in oscilltor section in power supply.
  • if you are not tech. person please take help.
  • hope this will help
  • good luck
Oct 16, 2007 | Televison & Video
Tv power up, no picture, then power off all with in 5 seconds
it might be due to
  • good luck
Oct 16, 2007 | Sanyo DS27510 27" TV
TV plug came loose inside tv
The damage most be heavy for the power cord to come out with the conector that attaches to the main board,telling you where it goes will not help because most likely you have a broken main board,you shoud get an estimate from a qualified technician.
Sep 04, 2006 | Philips Magnavox MT1905B 19" TV
Orion STV2763 27" TV Logo
16 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
