Question about Refrigerators
Can drinking water with lemon prevent kidney stones? Also, I have been told not to drink city water. What is the best water to drink?
    Habit-Forming:
    Scholar:
  • 40 Answers
If you have small kidney stones, then you won't require invasive treatment. So, yes drinking water can help you in preventing or curing the kidney stones.
The best way to prevent most kidney stones is to drink enough fluids every day. Most people should drink eight to 12 cups of fluid per day.
The other liquids that you can refer to are
- you can add freshly squeezed lemons to your water as often as you like. Lemons contain citrate, which is a chemical that prevents calcium stones from forming.
- Basil contains acetic acid, which helps to break down the kidney stones and reduce pain. It's also full of nutrients.
- Apple cider vinegar contains acetic acid. Acetic acid helps to dissolve kidney stones.
- Celery juice is thought to clear away toxins that contribute to kidney stone formation and has long been used in traditional medications.
- Pomegranate juice has been used for centuries to improve overall kidney function.
For more you can contact General Surgeon in Gurgaon
Posted on Aug 26, 2019
    New Friend:
    Problem Solver:
  • 9 Answers
Sadly no lemon is a prophylactic for scurvy or Vit C deficiency. drinking plenty of fluid is very good for the renal system but depends on the viscosity of the water or in other words the mineral content. preventing kidney stones is down to good diet exercise and fluids.
Posted on Jan 12, 2019
    New Friend:
  • 4 Answers
Drinking only plain water will also improve our health and prevents kidney stones as well.
    New Friend:
One-half cup of lemon juice concentrate added to drinking water over the course of the day is a preventive therapy for calcium oxalate stone formation.
As for city water, it is safe to drink but the concern is with water softened using a sodium ion exchange. Softened water should not be used for cooking, drinking, or for ice dispensers.
visit http://knowlious.com/
Posted on Aug 27, 2013
4 Suggested Answers
SOURCE:
cactus bob
  • 267 Answers
SOURCE: NO DRINKING WATER
common problem the water line inside the freezer door is frolzen up . to fix remove everthing from the freezer door , turn off freezer . open freezer door and put a blanket over the opening to the freezer leaveing the door to room temp for an hour or so to defrost . check if defrosted . remove blanket close door . this will happen with ge , try seyying the freezer control on the next lower number (warmer)
Posted on Jan 16, 2009
SOURCE: OASIS drinking fountain , no water
Pull the water jug and open the top of the unit. Look for frozen water. May need repaired or adjusted to keep water from freezing.
Posted on Jun 12, 2009
SOURCE: samsung rs2555sl ice maker trouble
how to replace the filter? the indicator light is on the front left side over dispersement h20/water
Posted on Oct 16, 2009
Can you drink to much lemon water like 2 liters a day?
the amount of water need depends on the conditions and body stress
if you are out side in heat then 2 liters of water may not be enough but inside in the cool 1 liter may be too much
If the lemon water is prepared from water and lemon juice , it probably will not be harmful as the body needs something more than water to keep the electrolytes correct
If it is a staminade or power aid drink , then yes 2 litres is far too much
straight water is the best
Aug 08, 2018 | Lemon Water Wine & Spirits
Sideeffect cranberry capsule 500mg
Click on the GREEN Side Effects tab.
Cranberry is LIKELY SAFE for most people when taken by mouth appropriately. Cranberry juice and cranberry extracts have been used safely in people. However, drinking too much cranberry juice can cause some side effects such as mild stomach upset and diarrhea. Drinking more than 1 liter per day for a long period of time might increase the chance of getting kidney stones. Special Precautions & Warnings: Pregnancy and baby feeding: There is not enough reliable information about the safety of taking cranberry for therapeutic reasons if you are pregnant or mummy feeding. Stay on the safe side and avoid use.
Children: Cranberry juice is LIKELY SAFE for children when taken by mouth as a food or drink.
Aspirin allergy: Cranberries contain significant amounts of salicylic acid. Salicylic acid is similar to aspirin. Avoid drinking large quantities of cranberry juice if you are allergic to aspirin.
Inflammation of the stomach lining (Atrophic gastritis): Cranberry juice might increase how much vitamin B12 the body absorbs for people with atrophic gastritis.
Diabetes: Some cranberry juice products are sweetened with extra sugar. If you have diabetes, stick with cranberry products that are sweetened with artificial sweeteners.
Low stomach acid (hypochlorhydria). Cranberry juice might increase how much vitamin B12 the body absorbs for people with low levels of stomach acid.
Kidney stones: Cranberry juice and cranberry extracts contain a large amount of a chemical called oxalate. In fact, there is some evidence that some cranberry extract tablets can boost the level of oxalate in the water works by as much as 43%. Since kidney stones are made primarily from oxalate combined with calcium, healthcare providers worry that cranberry might increase the risk of kidney stones. To be on the safe side, avoid taking cranberry extract products or drinking a lot of cranberry juice if you have a history of kidney stones.
CRANBERRY Uses Side Effects Interactions and Warnings WebMD
Dec 27, 2016 | Reaction Watches
Not drinking enough water can cause?
Yes and dehydration which leads to all sorts of problems.....all which are very serious.
Sep 17, 2014 | Wine & Spirits
Refrigerators Logo
4,247 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
