Question about Philips DVD Micro Theater Shelf System (MCD288) System
Says close when i try to play my dvd.
Set up my new system mcd288. Tried to play a dvd sytem says close and wouldnt acept the dvd in.
  • MCD288user Nov 03, 2007
    same problem: Set up my new system mcd288. Tried to play a dvd system says close and wouldn't accept the dvd in.
    looking for solution.
My MCD288 developed the very same issue just 2 months after buying it. I kept thinking than my little niece had to do something with that, and only today, after 2 years decided to open it up and check. Well the problem is the GREY (not the black one) microswitch that is soldered on a little PCB atteched to the CD/DVD mechanism. You can check it on board with a multymeter. It stops working. I unsoldered it, opened it up, cleaned it and resoldered it. It now accepts CDs and DVDs and does not spit them out after a while. If only I could find a solution for the buzzing sound. It must be defective design. Maybe change C560 and C561 on main amp PCB with smaller capacity ones? Or maybe put away the toroidal transformer?
This is the LAST item I'll ever buy from Phillips. Period. They put an unfinished project on sale... Shame on them..
Greetings from Greece
George
Posted on Mar 10, 2010
  • 38 Answers
Try few brand new dvd movies in this unit(not rental disc)and see if it works?If not,Your dvd laser is having issue,hope you have the receipt to return it:)
Joe
Posted on Feb 04, 2008
Cannot turn subtitles off!
Turn off the closed captioning on your TV.
Oct 27, 2008 | Philips DVD Micro Theater Shelf System...
Region Code
1. Press DVD "OPEN/CLOSE" key on remote Control (R/C) or main set to open the DVD door (note: if no disc on tray, then no need to open the door);
2. Press R/C numeric key sequentially 9735 (entry code, no display on TV), enter DVD region code setup menu.
3. Press R/C "down direction" or "up direction" key to change REGION CODE,"0" is all code.
4. Press R/C "OK" key to confirm.
5. Press R/C "SYSTEM" key to exit DVD system setup menu
Aug 08, 2008 | Philips MCD288/37 DVD Micro Theater System...
How to play TV sound through Philips Mcd288
You must plug the t.v. audio out cables into an audio input on the philips. left and right audio rca jacks. then you must select that input on the philips to hear the tv. Lawrence
Feb 26, 2008 | Philips DVD Micro Theater Shelf System...
Twang
How do you connect your system?
Joe
Feb 04, 2008 | Philips DVD Micro Theater Shelf System...
Philips mcd288 mp3 albums
There's a little bit of work involved, but what you should do is to record those tracks individually as folders, then transfer those to your DVD burner...accordianman
Dec 30, 2007 | Philips DVD Micro Theater Shelf System...
Mcd288 problem
Try not to use any rental dvd discs or dvd burner discs. Go get a brand new dvd movie(again,do not burn a DVD disc and play in this unit.) and put it in see if it works? Should have at least 2-3 movies for testing.
If you have tried to put in some BRAND NEW DVD movies and still doesn't work,you have a problem with the unit.
Jul 23, 2007 | Philips DVD Micro Theater Shelf System...
DVDs & CDs will not play
If you are playing STANDARD CD or regular DVD that you have purchase and you are having this problem,your dvd player is malfunction;however,if you are playing DVD burner disc or a different dvd region disc(we are region 1 in U.S.) that is no going to work.Same thing for your CD burner disc,it might not work.
If you are using a rental dvd disc,check and see if there is scratches?If so,try to get one without that many scratches!
Joe
Jan 07, 2007 | Philips DVD Micro Theater Shelf System...
Philips DVD Micro Theater Shelf System (MCD288) System Logo
226 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
