Question about Kenwood KDC-128 CD Player
KDC 128 CD Player
I am having problems with my kenwood kdc 128 player. It will come on for about 1 minute then turn off. I have already checked the ignition, battery, and ground wires and reconnected them. I have also checked the fuse box in the car and on the back of the radio. No fuses are blown. What could be the problem? Please help.
  • utcsenior Sep 10, 2007
    The player does not get hot. I haven't tried your method yet, but I will later. I will let you know what happened. I hope it works.
    Scholar:
  • 94 Answers
It could be that the player is going into protect mode. This is normally due to a short in a speaker cable, or one or more of your speakers is blown. Try disconnecting all of your speaker cables at the speaker end and make sure the connectors don't touch. Power it up again and see if it stays on. Bear in mind you won't hear anything. If it powers up. Carefully plug each speaker back in. It will power off if you plug in the dud! If it still doesn't power up. disconnect all of your speaker cables at the player end. If it powers up this time one of your cables is shorted. Same as the speakers, plug one pair of wires in at a time to find the dud. If it's still switching off. It could be a blown circuit on the output stage of the amp. Here's a silly question. Does the player get hot? All this assumes that you have had this player working with these cables and speakers before. If not check that the speakers are the correct rating (Resistance in Ohms) for the player. And lastly here's where you can get a manual http://www.kenwoodusa.com/Support/Car_Files/#_
Posted on Sep 10, 2007
6ya staff
SOURCE:
:I shorted out my kdc 128 head unit and i switched all the fuses but it still wont turn on. any ideas?
Firstly, the main wires from the KDC-128 you need to check are:
RED - this should be connected to the vehicle's +12v IGNITION wire.
YELLOW - this should be connected to the vehicle's =12v BATTERY wire.
EARTH - i) some tuners will only earth when the tuner itself, is screwed into the vehicle's chassis (i.e. a metal mounting bracket); ii) some tuners require the BLACK wire to be attached to the vehicle's chassis (i.e. a metal mounting bracket).
Secondly, if the above wires are connected correctly, then you should suspect the fuse on rear of the tuner has blown (even if it LOOKS ok). Replace and see what happens.
Thirdly, if all above are ok, then you have a short somewhere on the vehicle.
Jan 12, 2013 | Kenwood KDC-128 CD Player
Can get kenwood kcd 128 to turn on
ok black is ground, red is remote, yellow is battery, orange is illumination, make sure the antenna wire is in and you hold down the SRC button for about 3 to 5 seconds. please vote.
Jul 29, 2010 | Kenwood KDC-128 CD Player
I took the battery out of and now my Kenwood Stereo asks for a code.
Reset the radio by pushing the small button on left side of the #1 preset. it is probably pulling the code for the anti theft protection. if you already have a lock code use it to unlock the tuner otherwise reset the tuner
Mar 24, 2010 | Kenwood KDC-135 CD Player
How do I set the clock on my Kenwood kdc-2025 cd player?
Press [MENU] for at least 1 second. *MENU* is displayed. Press [FM] or [AM] button to select menu item (CLK ADJ). Press RWND or FFWD button for at least 2 seconds. The clock display blinks. Adjust the hours. Press [FM] or [AM] button. Adjust the minutes. Press the RWND or FFWD button. Press [MENU] button to exit adjustment mode. Reference page 20 in this link to your Kenwood KDC-2035 Operating Instructions.
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDC-MP225.pdf
Dec 27, 2009 | Kenwood KDC-2025 CD Player
Ineed a manual user guide Kenwood kdc 128 cr
You can get your manual here:
http://audio.manualsonline.com/manuals/mfg/kenwood/kdc-128.html
Nov 23, 2009 | Kenwood KDC-128 CD Player
I hooked up my kenwood kdc 128 cd player and nothing works
i had the same problem as you, i own a 98 ford escort, and i couldnt find a wiring diagram that matched the ones in my car . i managed to connect the constant (red) and switched (yellow) to the wires in the car but i had made a mistake with the ground (black) . so i re connected it to where its suppose to go so now the head unit actually lights up and turns on.
now i have another problem because my head unit doesnt stay on for any longer than 1 mintute
Mar 05, 2009 | Kenwood KDC-128 CD Player
Got a new Kenwood KDC-128 car radio recently, fitted it but the radio presets would not stay when the ignition was turned off. Then it stopped working altogether and I noticed the 10amp fuse at the back...
you need to hook the yellow wire off the back of the radio up straight to the battery this keeps memory power to the head unit then wire the wires in color coded sequence red to red black to black so on and so forth if this doesnt fix it you might want to think about replacing head unit
Jan 02, 2009 | Kenwood KDC-128 CD Player
Kenwood model kdc 128
Blue with white stripe.
Sep 14, 2008 | Kenwood KDC-128 CD Player
Kenwood KDC-128 CD Player Logo
243 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
