Question about Hitachi 46BX01B 46" Rear Projection Television
Hitachi 50UX15k Screen is ok Then starts to roll, roll roll ...twist . Took the back off hoping for some simple adjustment but even if there is, seems like I would need a schmantic (spelling?) to locate it. My question is if there is an ajustment or not. thanks
  • Anonymous Dec 27, 2007
    I have an older 53" hitachi ultravision that rolls and twists when you turn it on. After about 10 minutes the picture is watchable but still wavey. Is there a component that is easily replaced? If so, Where can I buy it? Thanks a lot
    Genius:
  • 1,153 Answers
You will need to replace IC-5501 to stop rolling. Hope this helps
Posted on Sep 24, 2007
SOURCE:
Screen rolling on hitachi 58F710G cant find any controls..am I blind,or is it inaccessible? has been working fine
There will be no ports to adjust rolling . its done through service mode program. To know more about service modes check the link.
http://electro-medical.blogspot.com/
Mar 13, 2016 | Hitachi Televison & Video
PICTURE KEEPS ON ROLLING OVER. SOUND O.K., PICTURE O.K, COLOUR OK. TELEVISION
Check your V-Sync (i don't know what make or model your using, but generally the v-synch is a little knob on the back of the TV) Make adjustments until the refresh is in sync with the signal. (no science to it.. just twist clockwise or counter clockwise until it clears up)
Apr 13, 2011 | Televison & Video
Dark picture
Hmm my dad's old t.v. just cut out on him it took awile to turn on this my be the end of ur tv so this might be a power problem but older t.v. loose there colour on the screen my uncle had a like 10-15 year old t.v the screen was like green when it was light but when u turned of the light or closed the blind's it's picture was ok so try that.
Feb 02, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Our Hitachi tv turns on okay but the picture on comes in for 2-3 seconds and then the screen goes black. Last night the tv work just fine but this problem started today as I turned the tv on to watch...
I don't know what model you have,but... I have a 50v715 and it was doing the same thing and it turned out to be the lamp. So if you have not replaced the lamp in a while then it could just be it time. Hope this is helpful.
Oct 03, 2009 | Hitachi Televison & Video
The humming noise from my hitachi 42hds69 television seems to have gotten a little louder. This humming sound is more prevelant on various stations. The humming sound seems to be normal/better on dark...
usually it means your screen is going bad unless it is a fan or some mechanical part thats humming if it comes from the screen itself the screen panel going bad.now you can check cables and eveything else for this a signal loss type of short but if you have allready checked all cables or recievers or connected devices for this then its a simple main panel humm means a bad screen panel sorry to say but i hope this helps..
Jun 24, 2009 | Hitachi 42HDS69 42 in. Plasma Television
How do you change the belt on a kirby sentia vacuum cleaner?
ok Imussati here is how you change the belt take the roller brush out and put the belt in the center of the roller brush place the roller brush back in nowtake the name plate and twist it until the hook graps the belt it may seem like it is to tight but keep turning it once you get the belt twisted to the highest point put the nozzle back on the vacuum and lock it down then turn the face plate back the way it was and it should allow the belt to slip around the driveshaft and you are ready to roll. hope this helps
Jan 24, 2009 | Vacuums
Hitachi hd 57 inch rear projection tv.
You may be able to correct this problem with the convergence controls in the user menu. Hitachi also has on some projection sets a button called "magic focus" which is an automatic convergence control. If you can't seem to bring things back the way they should be you may have to get your convergence ICs replaced as well as some resistors in the convergence circuit. Unless you have above average soldering skills I'd suggest leaving that up to a technician.
Oct 07, 2008 | Hitachi 57F500 57" Rear Projection...
Hitachi 50UX15K Television Picture is Very blue and very red
The television has to be worked on, there only two componants which can contribute to that. the screen is about to finish or a mixer stage is gone.thanks
Aug 27, 2008 | Hitachi 46BX01B 46" Rear Projection...
Magnavox tv
I think I'm having the same problem dont knowif its the cale or the TV I have an old one too,gets wavy kinda rolls vertically
Jul 05, 2008 | Philips Magnavox 27MS343S 27" TV
Tracking seems off
I have had the same problem. There is no way to manually adjust the tracking on this Hitachi, or on most 8mm cameras, for that matter. I copied all of my more recent tapes to DVD first (2 copies of each) and then I went to the oldest tapes, which for some reason were OK. When I got to one tape that gave me trouble, I just let it play in the camcorder for about an hour. It adjusted its own tracking so that the picture was OK. Then, I rewound the tape and copied that one. I still have 2 tapes that will not adjust. I am going to send those out to a copying service. I hope they can adjust the tracking and make the copies I need.
By the way, I used this camera and a Panasonic DMR-E55 to make the DVD copies.
Jun 04, 2008 | Hitachi VME545 Camcorder
Hitachi 46BX01B 46" Rear Projection Television Logo
148 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
