Question about Goldstar MV-1320W/B Microwave Oven
Hood lights I have a Goldstar MV-1320W microwave oven that site over the range. The hood lights underneath do not work. I've tried changing the bulbs and I've taken off the underneath cover to look at the wiring. Everything looks fine (though I'm not an electrician). MicrowaveSvc mentioned that the problem is caused when the bulbs are changed without disconnecting the power first. The problem started long ago, but it could be that I did not disconnect the power before changing the bulbs. MicrowaveSvc also mentioned the problem can be fixed in the control board. What specifically needs to be replaced/fixed?
  • mickyk Nov 29, 2007
    How do I relace the light?
My microwave won't heat. I want to remove it and replace. How do I do this.
Posted on Jul 20, 2008
  • 225 Answers
First remove mains cord from main power. and remove the microwave oven top cover and check the bulb and crefully remove the old bulb and put new bulb. at high voltagae section dont touch any thing ,that area very dangerous ,thats why very carefully work inside the microwave oven ..
Posted on Sep 29, 2007
Oven quit working on model mv-1320w
That would be a defective door switch, most likely the bottom one.
(It's either the top or bottom switch (not the middle one) and whichever one has thicker wires, not the one with the thinner wires.)
See my help text file on door switches here.
To order other Goldstar / L.G. parts besides door switches, visit Encompass. You'll probably have to call them at 866-779-5835 to get part numbers.
Nov 27, 2012 | Goldstar Microwave Ovens
The scrolling speed for the timed cooking is running incredibly fast - too fast to allow the food to cook. I was looking for a manual for Model #MV-1320B.
The owner's manual can be found here.
It sounds like the oven has been placed in "demo mode".
Nov 14, 2012 | Goldstar MV-1320W/B Microwave Oven
Goldstar MV 1500 above the range is sparking when turn on there is no metal in there nor was then when it started
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Aug 24, 2011 | Goldstar MV-1526 Microwave Oven
Dear Sir, I have a Goldstar MV-1320W microwave. Tonight, for no apparent reason a loud blowing noise started. It sounded different than the usual fan and would not respond to anything from the keypad. I...
I'd suspect the relay located on the pcb to be shorted, as in the contacts welded/stuck together.  This isn't available separately from Goldstar, as it comes with the circuit board.  The board will probably be prohibitively expensive.  If you have the know-how, remove the board so as to make working on it easier.  Remove the relay lid and using a points file or emery cloth, clean them up.  My experience with this, is the repair works great.  The relay lid may never fit again, as most of them are "sealed", and not designed for removal.  Of course, a replacement relay with roughly the same specs could replace the defective one.  These are usually 120v spst, normally open.
Jul 15, 2009 | Goldstar MV-1320W/B Microwave Oven
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
I have a nine year old Goldstar over the Range microwave. It usually works great, however I need to replace the brown circle on the top of the range it sparks and now has a hole in it, I don't want a fire....
I'm just a typical homeowner who just replaced one for an MV-1310W.
Here's the info on the bag sticker:
Desc: Cover Assembly, Stirrer Fan
Spec: AL 1.3Cu.Ft MV-1350M
Hope it helps...
Mar 10, 2009 | Goldstar MV-1310W/B Microwave Oven
Goldstar keypad not working
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
Aug 22, 2008 | Goldstar MV-1320W/B Microwave Oven
No power
I would say a cooktop lamp got shorted by the moisture.
Assuming your circuit breaker is good, the main problem would probably be a blown 15A or 20A ceramic fuse inside the unit.
Once that's replaced, if the hood lights and /or exhaust fan still don't work, then your control panel would need to be repaired, which we do for $39.95 nationwide.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa:
If and when you remove or install cooktop lamps, the power to the oven must be unplugged or turned off at the breaker.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 15, 2008 | Goldstar MV-1526 Microwave Oven
Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Sep 23, 2007 | Goldstar MV-1501 Microwave Oven
Microwave Ovens Logo
392 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
