Question about Microsoft Windows XP Home Edition
Windows XP Unusually Slow Startup
I am running Windows Xp Media Center edition. When booting up, there is a long delay (30-90 seconds) at the "Welcome" screen. After that has passed, my wallpaper displays but I need to wait another 1 or 2 minutes before the taskbar or icons show. I have a fast computer and plenty of ram. I disabled some services with msconfig months ago but the slow booting happened this week. I was desperate and edited the prefetch to 3 (i don't know if that harmed or hurt it). The newest change I can think of is that i installed a new HP printer. If there are any ideas, please help. Thanks a bunch to everyone in advance.
  • 10 more comments
  • valid wong Sep 09, 2007
    Also I notice it that svchost.exe in the Task Manager will take a while to load. And when svchost.exe loads up, then my icons and startup items will appear also. I don't know if that helps.
    No signs of spyware/malware either.
  • valid wong Sep 10, 2007
    How do disable virtual memory? Thanks for the reply.
    Hey 24 seven,
    I did the disk error check and it came up with nothing. Then I did a defrag. I restarted an the startup continues to be very slow. I have a side question though, should I leave my VM off with my 2GB of ram? Also do you have any other ideas about the startup? THANK YOU SOO MUCH for your help by the way.
  • valid wong Sep 11, 2007
    Erwin,
    Thank you for the reply. I really appreciate it. How do I check if my disk is in parition and what do I do to fix it? It says on "My Computer" that I have a C(Local) and D(Backup) drive. :)
  • valid wong Sep 12, 2007
    Thanks a bunch 24 Seven, I will try things and let you know.
    I've tried everything in the last message but nothing changed. :/ Still, I really appreciate your help.
  • valid wong Sep 22, 2007
    Yeah, I really don't know. :/
    I've tried everything :/ but no luck. Do you think this would fix my problems? http://pcsupport.about.com/od/operatings...
  • valid wong Oct 02, 2007
    Thanks ask anything, the tip helped a bit, but I don't believe it was the source of my problem. I appreciate all the help from the members of this site nonetheless!
  • valid wong Dec 17, 2007
    It is so weird, I still don't understand why my computer does this.
    Scholar:
  • 151 Answers
1)Go to start menu 2)Then go to 'RUN' and write MSCONFIG in its textbox. Then click on Startup tab and disable all option. 3) then restart ur pc.
Posted on Sep 23, 2007
  • paras shah
    paras shah Oct 01, 2007
    Right-click on 'My Computer' and click 'properties'.
    Under the 'Hardware' tab choose 'Device Manager'.
    Click the + sign next to 'IDE ATA/ATAPI controllers' to view all of them.
    Choose either the primary or secondary IDE channel, by right-clicking and choosing properties.
    Choose the advanced settings tab.
    Of Device 0 and Device 1, the one with a drive connected will be greyed out, so you cannot mess up your computer. On the other one (the one not greyed out) change device type from 'auto detect' to 'none'.
    Press ok, repeat the process for the other cable if necessary, and close the device manager.
    Your computer will now no longer waste time during loading looking for additional drives.
    This trick has improved the boot time on every system I've tried it on, in some cases by up to 30 seconds
    Brigadier General:
  • 6,966 Answers
Hi, Since you have tried most if not all of the logical possible remedies, perhaps you can try: 1. Remove all USB connections to your computer the boot; 2. Uninstall your new HP printer; 3. On powerup hit "del" or whatever it is to enter your CMOS/BIOS setup. Select Optimized settings. Check/verify that your CPU is at correct FSB, mem cache latency at 2; 4. Verify that the PC is reading/accessing all of your 2Gb mem; 5. Run your Windows in Safe Mode (though startup maybe even longer) and run MsConfig again. Pls note any changes from your last modification; Hope that this be of further help/idea. Good luck and kind regards.
Posted on Sep 22, 2007
Make sure your hard disk is in partition. Partition mostly used in a internet cafe they have a hard disk c and d. So you better try to this if your problem fix this then it's good.
Posted on Sep 11, 2007
  • 883 Answers
Possible that the virtual memory is fragged. try disabling the VM then do a disk error check followed by a disk defrag then re-enable VM.
Posted on Sep 10, 2007
  • Marty marty Sep 11, 2007
    to disable VM:
    1. right click My Computer, select Properties
    2. left click Advanced tab
    3. on Performance option, click advanced
    4. click advanced at next screen
    5. under virtual memory area, click CHANGE
    6. select "no paging file" then SET and ok out
    remember your settings before changing.
    Also, I thought of another area. If your system restore is enabled and was never turned off, then if it too is fragged, could slow pc. first try a system retore date that you think was working fine before problem arose. if that does not work then disable system restore temporarily and see if this works. remember to try scandisk and defrag after each major change of options.
  • 76 Answers
If your computer is running slow, the only thing i know of that you could do, is replace the motherboard and the CPU. It would probably cost $300-$500. Or if you want to go the easy way, buy a new computer.
Posted on Feb 28, 2009
SOURCE:
Installed win 7 but want restore to xp
To reinstall win XP from usb flash drive you need WIndows XP cd, 1 gb flash drive and Novicorp WinToFlash. Download WinToFlash to your computer and follow instructions to transfer Windows XP from cd to flash drive, After that boot your notebook from usb device and select "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon" then install win xp normally, but format C partition. After first start of your notebook boot again from flash drive in "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon". Now windows is starting, go to start/my computer right click on it and go to properties in this windows go to advanced tab and there go to startup and recovery, click on settings, in new window go to edit tab and in new window change the line "multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP" /noexecute=optin /fastdetect" after windows XP write the type of your XP Professional, Home Edition, or Media Center. Now you can remove usb flash drive and boot normally from hdd.
Nov 12, 2012 | Advent 4211c Notebook
How do I change the default program on my startup. Microsoft updated it to their media center. And how do I change my starup programs. windows XP
You can check, remove or disable your system start-up programs with Autoruns from Sysinternals. To change a specific startup program (ie a media player) with something more suitable for your needs you should check the program's configuration to look for a "run at the startup" sort of option.
Apr 29, 2011 | Microsoft Windows XP Home Edition
I start up my computer and i get a black screen that says "NTLDR is missing Press Ctrl+Alt+Del to restart" at the startup screen pressing f10 doesn't bring up system recovery and I don't have...
what is the model of your computer,? if the recovery software is in a hidden partition there must be a way to access it from boot, otherwise, you will have to buy a windows disk and reinstall windows.
Feb 05, 2011 | Microsoft Windows XP Media Center Edition...
I want to know that "is how many Windows XP version is publish So far"? any one answer detail i know only 2 one is HOME edition and 2nd is Professional " IS it ???? what about Media Center Edition...
to your amasement one answer is 8 versions
Windows XP Starter Edition
This edition is aimed for first-time desktop PC users in developing countries. This edition can only run three applications at once.
A version of Windows XP for home users. This edition replaced Windows 9x/ME
Windows XP Home Edition N
This is a special edition of Windows XP Home Edition for the european market
without media player
Windows XP Professional
A version of Windows XP for both businesses and home users. This edition replaced Windows 2000 Professional
Windows XP Professional N
This is a special edition of Windows XP Professional for the european market without media player
A Windows XP version for Media Center PCs with an easy to use interface and remote control support
Windows XP Tablet PC Edition
This is a Windows XP version for Tablet PCs with pen and speech capabilities
Windows XP Professional x86 Edition
This edition is for AMD64/EMT64 64-bit processors
guess you didn't knew that.
nice question and thanks for using fixya.
Please vote if satisfied.
Jun 03, 2010 | Microsoft Windows XP Professional for PC
Media center does not work on my windows xp
You should reinstall it using the installation cd because there is no downloads on the net for this.
Feb 22, 2010 | Microsoft Windows XP Media Center Edition...
My screen shuts down automatically
hiiiiii friends
some virus on your pc .....remember you format it total driver........
Nov 10, 2008 | Microsoft Windows XP Media Center Edition...
Booting
the following id taken from my own XP media centre laptop.
line 1 [boot loader]
line 2 timeout=30
line 3 default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS
line 4 [operating systems]
line 5 multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Windows XP Media Center Edition" /noexecute=optin /fastdetect
ignore the "line 1,2,3 etc" I added them for clarity the formatting in this answer pane messes up the last line.
also before you get to edit the start up file make sure that the default operating system listed is the sae as line 5 starting from the "
hope this helps.
Nov 08, 2008 | Microsoft Windows XP Media Center Edition...
Xbox 360-computer?
To connect the Xbox 360 console to this computer, you must be running Windows XP Service Pack 2, Update Rollup 2 for Windows XP Media Center Edition 2005, or Windows Vista.
To obtain your setup package or instructions for connecting your Xbox 360, select the version of Windows installed on this computer from the following list.
To determine the version of Windows XP Media Center Edition that you are running, follow these steps:
  1. Start Media Center.
  2. On the Settings menu, click General.
  3. Scroll down, and then click About Media Center.
  4. Click Software Version
    The version number of Media Center you are running is displayed.
To determine the version of Windows XP that you are running, follow these steps:
  1. On the Start menu, right-click My Computer, and then click Properties.
  2. On the General tab, under System, look for the version of Windows that you are running.
Oct 05, 2008 | Microsoft Xbox 360 Console
from msconfig you disable all startup item and restart.Also you defragment your hard drive once in a month and use a good antiviruse and scan your pc at regular interval
Jun 23, 2008 | Microsoft Windows XP Professional
plz go to msconfig and disable all item except the antiviruse in the startup tab, then go to my computer propeties ,click on advance then click on performance then select adjust for best performance(visual tab) then go to advance tab and change the page file to 1024 for both(min and max) then do a full scale system scan for viruse
Post your findings
Apr 28, 2008 | Microsoft Windows XP Media Center Edition...
Microsoft Windows XP Home Edition Logo
192 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
