Question about Sony Ericsson W850i Cellular Phone
Sreen comes on but thats it
I got a 9 months old phone thats been back to vodafone 3 times each time the same thing happen when i turn it on the sreen gos white and it vibs and nothink happen after that is there somethink i can download ato get it working again or bin it as vodafone will got help me nomore thanks
  • boutyee Feb 07, 2008
    phone vibrates when switched on but screen goes white and nothing else then happens. ive tried removing battery and sim and thats basically all because i cant get anything else up on the screen
    Brigadier General:
  • 7,752 Answers
Wilkos - take the phone and have the firmware reflash on the phone or do it online at www.topsony.com.
boutyee - it is best to take the phone and purchase a new even reflashing the firmware wil not correct this issue.
Posted on Aug 19, 2008
SOURCE:
Transit clutch has fell apart, the friction plate has come away from the rest of the clutch plate, (rivets sheard off) is this normal for 9 months old
no its not normal something has gone wrong somewhere for this to happen,sounds like something was loose or came loose at the time this happened.and if its only nine months old take it back to where you got it from and tell them what has happened.
Dec 09, 2016 | Motorcycles
I have just found my mobile phone LGCE0168 after losing it 6 months ago. How can I restart the Tesco PAYG sim card
I am wondering if you have tried another sim card in your newly found phone?
In theory there should be no problems just put your sim back in and make calls.
I am wondering If Tesco have changed service provider in the last 6 months? If they have it could explain your problem.
Asda mobile changed provider about a year ago from Vodafone to EE and my phone stopped working because it wasn't an unlocked phone. As it turned out I had to replace my phone for one that was unlocked because it wasn't worth the expense and trouble of having the old one unlocked. The old one still works fine on Vodafone and O2.
Just a thought. Another thought is perhaps it developed a fault while it was lost or maybe someone has been fiddling with it in that time.
There are lots of aftermarket phone shops around with specialists to give advice. The Tesco helpline might be able to help.
Feb 02, 2015 | Cell Phones
I made the mistake of buying another Kodak camera and this one is only 9 month old and only used 3 time in that time. When you turn it on it turns right off. I put in new battery and the same thing...
Batteries tend to deteriorate and leak over time, especially if left in a camera when it's not used for several months. Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Dec 15, 2009 | Kodak MX1063 Digital Camera
My internet is not working on my phone and i have 2 mms' that i cant retrieve i have been on the vodafone site and tried their settings but it still wont work.
In order to use the Mobile Internet and services such as picture messaging you are going to need to configure the phone you can do this a number of ways, I have included a link to the auto configuration on Samsungs website where the Internet and MMS can be setup quickly and easily. I have also included the manual configuration below if you have any issues.
Setting up WAP
1. Press menu
2. Scroll to and select Settings
3. Scroll to and select Browser settings
4. Scroll to and select Profile Settings
5. Scroll to and select a free profile (e.g. Profile 3)
6. In profile name enter Vodafone Wap
7. In home URL enter the URL of the site you want as your homepage i.e.
http://live.vodafone.com
8. Make sure bearer is set as GPRS only
9. Set proxy to enable
10. Select GPRS settings
11. In proxy IP enter 212.183.137.012
12. In proxy port enter 8799
13. In APN enter
for Pay monthly customers: wap.vodafone.co.uk
for Pay as you talk customers: pp.Vodafone.co.uk
14. In login ID enter wap
15. In password enter wap
16. Press save
17. Press save again
18. Press Back
19. Scroll to and select Current Profile
20. Scroll down to your new Vodafone WAP profile and press select to activate it
Setting up MMS
1. Press menu
3. Scroll to and select Message settings
4. Scroll to and select Multimedia Messages
5. Scroll to and select Multimedia Message Profile
6. Scroll to and select a free profile (e.g. Profile 3)
7. Press Options
8. Scroll to Edit
9. In profile name enter Vodafone MMS
10. In Server URL enter the URL of the site you want as your homepage i.e. http://
mms.vodafone.co.uk/servlets/mms
11. Set proxy to enable
12. Select GPRS settings
13. In proxy IP enter 212.183.137.012
14. In proxy port enter 8799
15. In APN enter
16. In login ID enter wap
17. In password enter wap
18. Press save
19. Press save again
20. Press Back
Once you have followed either step you will then be able to access Mobile Internet and MMS fine.
or.....go to the following website and configure your mobile settings
http://www.samsungmobile.co.uk/supports/configurephone/wapSetting.do
Nov 05, 2009 | Samsung J700 Cellular Phone
47" Vizio Flat screen HD LCD freezes up and remote will not work.
could it be Ch 9's digital signal is not broadcasting right? what is your refresh rate on your tv? 60 or 120hz? if its 120hz, then its more then likely the digital broadcast, if its 60hz I think its your tv can't keep up with their signal that may be at 120hz. Make since??
Jun 16, 2009 | Vizio VO47L 47 in. LCD TV
Non-responsive buttons
i had a similar problem where it kept lokcing up and being really slow, unfortunately i had to do a hard reset ( sets the phone back to its original settings ) and after that it worked fine, i think the problem was that i had to many aftermarket programs on it that stay running in the backround once they were gone it was back to norma.
Aug 27, 2008 | HTC PPC-6800 Smartphone
Loose power
We have the same problem. This is actually our second system. Our first system started overheating 3 months old...Nintendo replaced with no problem. Our current system is 17 months old and is doing the same thing. I again contacted Nintendo (2x) and they informed me I was out of warranty BUT they would send in for FREE REPAIR, since I had this issue for the second time, and I told them I was not happy. It takes a bit of persistence with the automated phone system but if you keep trying you will get the prompt. Nintendo 1-800-255-3700
Aug 16, 2008 | Nintendo Wii Console
Keypad freeze
Did the key pad froze before you took the battery off? If so, it mean the keypad is damaged. If you have insurance, you may call customer service and have it replaced for a new one.
If it frozed after you shoot it off, you might call customer service from another phone and they might help you to unlock your phone.
Artgirl
Jul 17, 2008 | Samsung SGH-D900 Cellular Phone
VIZIO 42" Plasma HDTV
i have a vizio p42 and i have sound but no picture i have tryed to reset it but nothing works
Nov 24, 2006 | Vizio P2 42 in. HD-Ready Plasma Television
Sony Ericsson W850i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
