Question about Epson Stylus Photo R320 InkJet Printer
Printing CD/DVDs I recently upgraded my mac to run 10.4.10. Since then the printer will be not respond to printing cd/dvds. The red light comes on and the message on the printer says to close the cd drawer. Sometimes the printer utility doesn't even recognize anything printing! Please help as I have to turn in this cd to a client tomorrow.
  • Epson Master
  • 705 Answers
Try reinstalling the driver and PrintCD utility. The utility was never designed to be run on anything much after 9 and Epson no longer use the PrintCD software. You may have to find an alternative product to PrintCD.
Posted on Sep 16, 2007
SOURCE:
Can I use printable cd on this printer?
No, this model haven't CD tray for printing on CD.
Oct 07, 2009 | HP Photosmart 2710 All-In-One InkJet...
My hp photosmart c5580 won't print the correct ink color on dvds
Unless a printer is specifically designed to PRINT on CDs or DVDS, that's the problem. Usually a program called "LightScribe" is used to print on CDs or DVDs right in your DVD/CD Drive. For printers, use a Self Adhesive DVD/CD PAPER Label(s) that you can buy in the store. Inserting DVDs or CDs through a printer can really mess them up and Damage the rollers inside!
Jun 11, 2009 | HP Photosmart C5180 All-In-One InkJet...
How do I print a label on a cd/dvd
your printer does not support CD label orinting. though you can still print CD labels but with some softwares. there are HP printers that prints CD labels. Check them out.
HP Lightscribe
Use LightScribe technology to label CDs and DVDs.
HP Photosmart D5460, D5463, D5468, and D7560 Printers - Printing Directly onto a Printable CD or DVD in HP Solution Center ...
On a computer running Windows, print directly onto a CD or DVD using the HP Solution Center software.
HP Photosmart Premium C309a, C309c, C309g, and C309n All-in-One Printers - Printing Directly onto a CD or DVD - c01622666
Review steps for printing directly to a CD or DVD.
HP Deskjet 900C series printers - CD Label.
These printers comes with a special software that enables them print on CD labels. Also try to get their softwares and see if you can interface them with your own printer and them print. Else you may have to get one of these printers that support CD labelling. Cheers!
May 19, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Mac OS 10.5 Leopard
you need to install Epson Easy Print too
Jan 15, 2009 | Epson Stylus Photo 2100 InkJet Printer
Hi, my one of customer need a printer for printing CD or DVD (SURFACE)
There are two different types of photosmart Printers with HP which can print on CD and DVD
First: HP Photosmart C5280 All-in-One Printer, Scanner, Copier which can Emblazon CDs and DVDs 1 with your own images and text, Check the link Below:
http://www.shopping.hp.com/product/printer/Photosmart/1/storefronts/Q8330A%2523ABA
Next is HP Photosmart C8180 All-in-One Printer, Scanner, Copier
Prints true-to-life photos, laser-quality documents, custom designs on CDs/DVDs, Check the link bellow:
http://www.shopping.hp.com/product/printer/Photosmart/1/storefronts/L2526A%2523ABA
Good Luck
Nov 25, 2008 | Office Equipment & Supplies
Mac OS 10.5 Leopard
As per someone elses post here:
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Oct 18, 2008 | Epson RX595 Photo All-In-One Printer
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Mac OS 10.5 Leopard
two issues here..
compatibility of Epson with Leopard..and also the drivers will need to be postscript compatible..not an easy task.
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Epson Stylus R380 InkJet Photo Printer
Mac OS 10.5 Leopard
First, install "epson easyprint" from the epson website. Its found under drivers and support for your unit.
Then click ok on that error message about "driver dealing with..."
After you click ok on the message, you will get another window where you will find a "manual print" button. Click on this manual print button and this will take you to the next window where you have to select "A4 as the paper size" and "CD/DVD as the paper type and paper path" . After this, click print... it should start to print! This is just a workaround until epson gets a patch for leopard for print cd........hopefully
Jul 27, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
150 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
