Question about SanDisk Sansa e250 MP3 Player
No audio on snsa e260 2gb
My mp3 player worked for about 4 or 5 months and now there is no audio except for when i push back on the head phone jack and then it is really staticy sounding.
  • 626 Answers
If its less than 1 year old, you can have it replaced. Its a common occurrence. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Posted on Sep 10, 2007
SOURCE:
The audio for my Technical Pro HB3502UriBT Hybrid Amplifier is not working. What can I do to restore it?
IF the head phone jack works and the speakers don't then the issue is the jack. The jack disconnects the speakers when the headphones are plugged in. I have seen the jacks get the connections bent out of place by having pens and other objects stuck in the head phone jack. Ignore the subwoofer it is on its own circuit,
Mar 12, 2018 | The Audio Players & Recorders
No sound from mp3 player usb cable plugged into car cd player
Connect an audio cable from the head phone jack to the audio input on your CD player then you will able to hear music from your MP3 player.
Mar 19, 2011 | Philips Audio Players & Recorders
Why can't I no longer hear music through the earphones on my sharper image mp4 player?
Try another set of headphones to verify it's not the head phones that's the problem. If the other set of head phones don't work, then the audio output jack is the problem.
Feb 19, 2011 | Audio Players & Recorders
Ipod shuffle cannot hear music through headphones
Is it really a Head phone issue? lets find out that first.
If your headphones don't work as expected or not at all, connect the headphones to another audio source, such as your computer's speaker jack or another audio device that has a 3.5 mm stereo headphone jack, and test them. If your headphones are under warranty and still don't work, you can order replacement iPod headphones - Link - https://selfsolve.apple.com/GetWarranty.do;jsessionid=1B9ED1B556F0978A6C914A52711E59AA
And about the yellow and green LEDs
The yellow LED shows when the player is charging and a blinking green LED indicates you've paused the player.
At the back is another LED, the 'Battery Status' button, just below the toggle switch; when pressed, it flashes to give you a general idea of how much battery charge remains... green indicates a full charge... yellow, a low charge... red, very low charge... and no glow means its given up its ghost.
Hope this helps :-))
Dec 24, 2009 | Apple iPod shuffle MP3 Player
Head ear phones works
have you tried other headphones or earphones
some headphones lose connection in the wire  and will cause a short where one side works and the other doesnt
if this is not the problem may have a lose jack on the inside of the player and will probably have to have it serviced
May 01, 2009 | SanDisk Sansa e250 MP3 Player
Ear phones Jack not working properly
It's possible that there is bad soldering to the jack's contacts.
Mar 26, 2017 | SanDisk Sansa E280 MP3 Player
Head phone jack
Any other headphones to try? maybe even a friend's? I suspect it is a problem with the "phones" themselves even if they are new.
Feb 16, 2009 | SanDisk Sansa e260 MP3 Player
Coby MP3 MPC882
Ok people the problome is in the head phone jack. It don't make proper conection any more from being twisted and wiggled around all the time. What you can do is take the mp3 apart and put a little pice of paper and fold it upon top of the head phone jack and put it back together. Make sure that the paper is still thick enough to push down on the jack. You might have to get two extra screws of the longer two types. just in case. Any comments e mail me at: [email protected]
Oct 25, 2008 | Audio Players & Recorders
Ipod head phone jack no good
I agree with Solution 5. The copper pins in the jack that make the connection to your headphone plug are bent in such a way that they are springy and will make a good tight connection to the plug. When those copper connections get worn, they are not so springy and they bend inward causing you to lose audio on one side of your headphones unless you wiggle the plug and find that sweet spot that makes a connection. Then you have to hold the wire to keep pressure on it... it gets annoying.
You can open the case and there are slots in the headphone jack that you can get a hook scribe (like the dentists use) or safety pin to bent those copper connections back out. Don't bend them too far or they will break. You can also pick get a new part for $25 or a used part much cheaper. Once you iPod is open, it's a matter of a couple screws and a ribbon cable to replace the jack. Problem solved!
Feb 08, 2008 | Apple iPod MA446LL/A MP3 Player
SanDisk Sansa e250 MP3 Player Logo
26 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
