Question about Magic Chef CER3760 Electric Kitchen Range
I can't get my oven to go on, keep getting f-7 code on panel
I have a majic chef electric range. try to turn on oven & keep getting f-7 code
    President:
  • 373 Answers
F7
Function key shorted or stuck button Clean and un-stick button or replace Touch Pad or Clock
Posted on Apr 11, 2009
SOURCE:
My Majic Chef Oven model CGR3760 is taking a long time to heat up. It took 1 hour to reach 450 degrees! Not sure if this might be a thermostat issue or burner. Penny
Turns out it was the ignitor going bad but not totally gone. We are waiting on a part to come it to replace it. Thanks. By the way, this is a neat service, keep up the good work!
Jan 31, 2010 | Magic Chef CGR3725 Gas Kitchen Range
Magic Chef Oven 3888VRA beeps and shows F-1.
Hi this is indicating a Defective touch pad or clock (ERC).
This simple test will help determine whether the ERC (Electronic Range Control board or Clock) or the touch pad is defective when F1 error code is present. Follow carefully, and with caution.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: Do not preform this test if you feel as if you are not qualified to do so. Contact your local service depot, if needed.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Nov 17, 2009 | Magic Chef CER3725AA Electric Kitchen...
F3 error on magic chef electrical range
Hi glrecu,
The F3 fault code description is a shorted or open oven temperature sensor (RTD). Please check the sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope it helps.
Thank you for using FixYa.
Sep 06, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven Lights but goes out after just 3 to 5 seconds?
Fixed by brushing vigoursly with a toothbrush and some windex. Allow to dry and restart oven. Works perfectly.
May 01, 2009 | Magic Chef 31000 Gas Kitchen Range
I have a majic chef oven, when i turn it on it beeps and flashes
Self clean on some older models can cause some issues. F-3 is a sensor error. This could have been damaged by high heat or in some cases if the sensor is ok, the control doesn't know it's there.
Mar 14, 2009 | Magic Chef 9815 Electric Single Oven
MAJIC CHEF DOUBLE OVEN NOT WORKING
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Nov 29, 2008 | Magic Chef 9522 Electric Double Oven
Magic Chef Elec. Oven F3 error code
check temperature probe , if connection is good at connector then replace sensor
Nov 18, 2008 | Magic Chef CER3760 Electric Kitchen Range
Unable to find pilot light for m,ajic chef oven
its electronic ignighters is it plugged in and have you tried turning it to light new ones dont have piolets
Jul 13, 2008 | Magic Chef Ovens
Magic chef electric range model 38HK-6TXW
MAGIC CHEF
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad F6 means no ac signal and will need to replace the oven control.
Oct 18, 2007 | Magic Chef CER3725AA Electric Kitchen...
Magic Chef CER3760 Electric Kitchen Range Logo
172 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
