I have a sanyo smart tv and it keeps freezing up on me i can not do anything on it at all with buttons on the tv and i also can not use the remote at all
Reset Sanyo Tv without remote
Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed. Use the {CH+} {CH-} buttons to select menus. Use the {VOL+} {VOL -} buttons to change settings. Some menus might have sub-addresses. https://hardmasterreset.com/how-to-reset-sanyo-tv/
If the VCR button lights up when you press the Power button, you are not in the correct mode to operate the TV. If the remote is programmed correctly, when you are in SAT mode, you can press the large RED button to turn your receiver off/on. The RED TV button will turn your TV off/on. I have provided links to program your remote to your TV again. I have also provided codes for your Sanyo TV.
Instructions to program your remote to your TV (begin with step 6):
U have the original remote.Push the button said input or video to get out back regular tv.Or push the button on the front of the bottom of the tv pannel said menu push that button pick tv. U don't try Website 1-800- Remotes Factory Original.To buy an original or compatible remote.
Hello kls1996... programming your remote is rather easy. The easiest way (thanks to The Sharper Image Jumbo Remote being a LEARNING SMART remote) is to do the following:
1 - Point the head of your Sharper Image remote at the head of your Sanyo TV remote (nose to nose so the clear bulbs on each remote are facing each other).
2 - Press the "TV" button on your Sharper Image remote (located in the upper left-hand corner).
3 - Hold the "LEARN" button on your Sharper Image remote (located in the left edge under the volume buttons) until the red light flashes.
4 - Press the key on your Sharper Image remote (e.g. Volume Up or +VOL)... the red light will go solid (indicating that it is waiting for a signal from the other (in your case Sanyo) remote.
5 - Press the key on your other remote (in your case the Sanyo remote) that you want programmed in your new Sharper Image remote... the red light will flash rapidly again.
6 - Repeat step #4 until you have programmed each key.
7 - When done... press the "LEARN" key on your Sharper Image remote. Your Sharper Image remote should be programmed to operate your device (in this case, your Sanyo TV).
NOTE: You can program other devices such as your VCR, DVD, VHS, SAT, CABLE, etc. and not just one device.
here is the code for your remote
TV Sanyo
all for one
remote cod 0154 0159 press tv hold set down till light blinks 2 timen then inter code light s will flash 2 moor times your done
