Question about Holmes Products PCH4199UM Ceramic Heater
Too noisy while running
Very disappointed in heater. Too noisy while running. Too many vibrations.
  • 625 Answers
Sorry to hear that. Mass produced in China or Taiwan units rarely need to pass a quality control check or they get josled about in transit. Some units made by Honeywell with overseas assembly and parts also have this same problem. Cheap labor, cheap parts. It shouldn't be on the part of the user to track down faults, but if you want to try to find the squeaks and vibrations - go inside the unit and look for loose components. Duct tape in the right places does have a calming effect. A little silicone sealer does wonders too! Just be careful! I'll probably get a "thanks for trying" rating but this is just my opinion.
Posted on Sep 10, 2007
SOURCE:
Experiencing a noisy vibration from Monitor 441 heater
Lawrence, I suggest you post this question where all the Monitor "experts" hang out, here:
Forum Monitor Heaters
Dec 21, 2014 | Heating & Cooling
Vibration Noise Fix
Place the dehumidifier feet on foam or rubber vibration absorbing pads.
Touch all sides of the cabinet with the compressor running to see if your touch will dampen the noise. Once the noisy area is identified check that the fasteners are all in place and tight. Sometimes loostening and retightening a number of fasterners around the noisy area will cure this problem.
Apr 30, 2014 | Honeywell DR90A1000 TrueDRY Dehumidifier...
The heater operation is very noisy compared to new. Perhaps it's the fan? The heater is six years old and I'm concerned that it may cause a fire.
Its most likely the bearings in the fan motor failing causing vibration. One simple way would be too check and make sure all nuts and screws and bolts are tight around th e fan. If so is the fan blade dirty it doesnt take much dirt on a fan blade to get it out of balance and cause bearing failure.
Dec 13, 2010 | Dayton (3UG73) Electric Utility Heater
2005 Sienna AC Heater fan is very noisy
the fan may be loose on its drive shaft and catching the housing
Jul 07, 2010 | 2006 Toyota Sienna
Loud Vibration/Noise when System Starts
This happen when there is air in the gas line...if the problem is still there after a couple of days you will have to return the unit for an exchange the gas control is giving problem...contact rheem first before making a exchange decision..they will walk you some step first to ensure there is not a problem
Jul 03, 2010 | Rheem Direct Vent Natural Gas Tankless...
My brand new Danby compact chest freezer is very noisy.What is the problem?
It could be an area where the tubing is vibrating against the cabinet or it's touching other tubing. While it's running you can run your hand along the tubing and when you get to the vibrating area it should stop. You can then slightly move the tubing away from where it's vibrating. Do not bend or kink the tubing.
It could also be a noisy compressor which would be under warranty.
Aug 26, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Noisy water heater blower
It may just need a new pump coupling. Fairly inexpensive. I don't think you need to replace the whole burner.
Feb 14, 2009 | Fasco Bradford White Hot Water Heater...
yes the bearing could be gong bad, the screws could be comming loose which could make it where out the motor faster, it should be attended to
Feb 10, 2009 | Fasco Bradford White Hot Water Heater...
Rinnai model 531 2520FFU 91 N
Have the installer replace the inducer blower assembly. Rinnai will cover the repair and your technician will get paid from Rinnai.
Mar 03, 2008 | Heating & Cooling
Noisy pump
Obviously, this unit has a warranty. Are you packing the coffee too tightly? Run the unit without any coffee and see if the vibration is still there. If it is, get it fixed. If not, modify what you're doing.
Nov 02, 2007 | DeLonghi BAR 140 Espresso Machine
Holmes Products PCH4199UM Ceramic Heater Logo
85 people viewed this question
Top Holmes Products Heating & Cooling Experts
Bruce Showalter
Paul Carew
Gil Shultz
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
