Aiwa VX-S207 20 in. Combo
Problem for Aiwa VX-S207 20 in. Combo
Parental control code
By laynesmom on Sep 09, 2007
I have a 13inch Spongebob squarepants child's tv that is set to PG and I do not have a manuel to see what the code was set to when the tv was purchased. It says the tv was distributed by Emerson Radio Corp. Model was manufactured in 2005.
Same Problem
Dec 09, 2007
-   i forgot my parental control password-   lilman
Solution #1
posted on May 31, 2008
Somewhat Helpful)
arthurroger
Rank: Guru
Rating: 87%, 57 votes
The only AIWA unlock procedure I have heard of is this:
Using the original remote, simultaneously hold the #7 on the remote and the volume down control on the set. This may work.
Was this helpful?
Yes
No
Solution #2
posted on Feb 08, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
explanation of step 4 in previous solution(for DVD parental control...not TV channel v-chip control):
PARENTAL LEVEL
Parental Level allows you to set the rating level of
your DVD discs. Playback will stop if the disc’s ratings
exceed the level you set.
1 Press SETUP twice in STOP mode so that
the QUICK SETUP menu appears.
¡If the menu does not appear, press PLAY, STOP,
then SETUP twice.
2 Press Arrow L to select “CUSTOM”, then
press ENTER.
3 Press Arrow (K/L) to select “PARENTAL”,
then press ENTER.
4 Enter your four-digit password then press
ENTER.
Solution #3
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
IF YOU FORGET THE PASSWORD
1 Press 4, 7, 3, 7 at step 4. Then enter your
new password.
¡Password will be cleared and parental level will be
set to ALL.
Solution #4
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If you unplug the power cord or power failure
occurs, the changed access code will be lost and
will return to default (0000). Change your access
code again as necessary.
Solution #5
posted on Oct 10, 2007
Not Rated)
cocoa212004
Rank: Apprentice
Rating: 0%, 0 votes
ok first go to the DVD setup which should be located near the bottom of the remote is says SETUP. Then it will give you a list of options go to the one with the parental code one. Then you should try and change the password. My tvs old password was 8888 but I am not sure if it is the same on all tv's. If it is right then you should be able to change the password to whatever you want! I hope this helps anyone who sees this response!
Was this helpful?
Yes
No
Popular Solutions for Aiwa VX-S207 20 in. Combo
Questions and Unsolved Problems for Aiwa VX-S207 20 in. Combo
Do you recommend Aiwa VX-S207 20 in. Combo?
Answer
Answer
The DVD player in my wharfedale L22TiiW-C tv/dvd combi is not working. I need a replacement dvd... (More)
Answer
TV/DVD combi 14" for soem reason when it's now turned on it just beeps at you and no... (More)
Answer
just shows a black srceen and thats it.
Answer
urc-r6 codes for JVC DR-mv79
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top TV Combo Experts
Top TV Repairmen
(316) 283-8873
Aiwa
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Aiwa
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
