Question about Bose 3 2 1 GSX System
Bose 321 My bose system shows "TV and under it, it says PCM: 2.0" And I cannot hear the tv through my system. What is that and how do i fix it?
  • 752 Answers
PCM means it thinks you have a digital cable hooked between the TV and Bose (most TV's don't have digital audio outs...). You will have to use the menus to change the TV input to use the ANALOG cables (assuming thats what you're using...).
Posted on Sep 13, 2007
Trying to hook up Bose AV 321 media system to Samsung LED TV model
You can use a Optical to Analog audio adaptor (found all over the internet for under $30). You'll also need an optical cable that goes between the adaptor and TV. Be sure to set the audio output on the TV settings to PCM audio output, otherwise there will be no output.
Jan 22, 2014 | Samsung Televison & Video
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Apr 28, 2011 | Bose 3·2·1 II System
Sound issues
make sure your audio out jacks are pluged into auidio in on bose and make sure it is pluged in under tv audio on the back of bose
Apr 14, 2010 | Bose 3 2 1 GSX System
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
Faint sound when watching TV with Bose GSX 321 System
I connected my surround sound to the audio output on my samsung tv and it works fine. Of course I don't have an hdmi input on my surround sound system because its an older model, but it works great. Just got to put the surround sound to audio instead of dvd or tuner setting
May 07, 2009 | Bose 3 2 1 GSX System
Communicating with your tv message on bose 321 series 2
Well, it seems that this may be a common issue with this BOSE unit. My 321 GSIII was working fine as well for about a week. After a full frustrating day of switching, disconnecting, reconnecting cables and resetting the unit and TV several times, I was forced to call the BOSE Technical. They tried to help with the situation over the phone by directing me to do just about everything I did before I ever called them. After about an hour of their unsuccessful help, they left me in saying that I will now have to run Composite cables because my TV will not connect for some reason through HDMI even though it was working for a short time. AHHHHH...I custom prepared the walls in my new office to accommodate non-exposed cables and wires and now BOSE is saying to expose Composite cables. Tomorrow, I am going to connect the Composite cables to confirm if the 321 will now work that way (for curiousty). I will then call BOSE back and demand a replacement unit. I will keep all in the loop with my progress of this situation.
Apr 01, 2009 | Bose 3·2·1 II System
Need audio out for TV Ear
Send it back as i did. Did not work for me either.
Jan 30, 2008 | Bose 3·2·1 II System
PCM 2.0
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
Dec 19, 2007 | Audio Players & Recorders
Bose 3 2 1 GSX System Logo
707 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
