Question about RCA F36649 36" TV
RCA F36650 36" 2002 xbox ready tv
When I plug in my tv there is a loud squealing noise and the tv won't turn on. I read on the web that it is a component that is shorted out. Anyone have an idea as to what that component might be and is it something I can replace? I'm pretty handy.
  • stevo1904 Sep 14, 2007
    Sorry, I've got little time. Almost there tho.
    Genius:
  • 1,153 Answers
Yes it is the Horizontal Output and a few capacitors and resistor that needs changing. If you are good at desoldering and soldering you could do this. I think on this set its the Q4401, caps C4402, Cr 4402, Check Q4802, C4102, If you just want to try new parts and hope it works then you have to check voltages at different points to fix set. Now it also could be Bad Flyback in this set too. I have seen where you change flyback and horizontal output and c4402 would do it. R4118, R4114
Posted on Sep 09, 2007
SOURCE:
Owners manual for rca tv f32650YX01 ENTERTAINMENT SERIES, XBOX READY, GUIDE PLUS
When I turn on the tv it makes a loud chirping sound, with no picture. What could cause this?
Sep 05, 2010 | Televison & Video
Loud squealing noise first 5 minutes after tv is turned on
Sounds like the color wheel. It's the only moving part in most DLP's and the bearings can go bad. If it manages to get up to speed the picture may look normal. One temporary solution may be to let it run a few minutes, then turn the set off for 10 minutes, then turn back on. When my color wheel was going bad that would often quieten it down. For the rest of the day, try to leave the set on, especially if you're only going to be away from the TV for short periods. You can turn off your cable or satellite box but leave the set on and you won't have to go through the hassle of trying to quieten down the color wheel until the next cold start. Of course the best solution is to replace the color wheel which even with a rebuilt unit won't be cheap if your warranty is expired.
Nov 02, 2008 | RCA HD61LPW165 61" Projection HDTV
RCA Model f27650 High pitch squeal
the high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Oct 29, 2008 | RCA F32650 32" TV
Loud sound, No TV Picture
Power supply needs to be replaced - common problem with these tv"s
Sep 18, 2008 | RCA 32F531T 32" TV
RCA F36650 36" TV
is the squealing noise from the back of ur set , if so it is ur flyback transformer
May 29, 2008 | RCA F36650 36" TV
The rca television i have just made a weird noise and turned off. now it wont turn on.
can you describe what the noise was with a little more detail. Squealing or a loud squeaking can mean flyback.
Apr 05, 2008 | Televison & Video
Cant get scenium off stand by mode not manually ,remote useless
Is The nise a squealing. (bearing Noise) ? If so its probaly bad bearing in your color wheel
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Xbox 360 help
If its a really loud squeal you should probably call xbox customer support 1-800-4myxbox
if it is just a minor noise that seem irregular its probably nothing its happend to me to and goes away
Jan 13, 2008 | Microsoft Xbox 360 Console
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA F36649 36" TV Logo
94 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
