Question about Durabrand DVD-1002 DVD Player
Broken DVD player
DVD player will no longer read discs. It will load but DVD won't move around in circles. Within a second it says that there is no disc and won't do anything else. Is the lens supposed to be lit up? Because mine isn't.
  • 1 more comment
  • manerv Mar 30, 2008
    my dvd player won't read discs it just spins and then tells me there is no disc this is the 5th dvd player of this exact model that has done this within 30 days
  • Anonymous Dec 10, 2008
    NIGGERS!
  • Anonymous Dec 20, 2008
    having the same problem only this time it is the first time it is being used and it DOES NOT work. Imagine that right out of the box and the disk just stops spinning and i get the message "no disk"
  • 4 Answers
The motor that spins the disc is cooked, toast, dead, same as mine. Despite the fact that this device is a cheap piece of junk, I got nearly a year out of mine before the same thing occured. Sadly it's not worth trying to fix it. Next time we should spend a bit more than $20 on its replacement (a 'decent' Phillips dvd player sells for $40-50).
Posted on Dec 13, 2008
  • 32 Answers
Get a Sony Playstation 3 and quit fooling around with DVD's. Viva Blu-Ray!! :)
Posted on Mar 25, 2008
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
Magnavox MPD850 dvd player won't play, only display no disc
The problem is in the laser pickup assembly, over time the laser becomes weak until it can no longer read the disc, but you can buy a DVD cleaning kit that might breath more life into the player, if no! cheaper to replace the DVD player.
Mar 17, 2012 | Magnavox Televison & Video
Bush portable DVD player will not load my disc
Hello
Just put in an audio CD disc or an MP3 disc, and see whether it reads them or not. If the player can read these discs, and only refuses to read DVD discs, make sure that the laser pickup unit of it is faulty, and should be replaced with same type and number. If none of them reads, there are two possibilities, the first one is of laser pickup disc itself and the second one is the strip wire [a flat flexible cable connected between laser pickup unit and the mainboard of the player] is faulty. First replace the strip wire. If it helps you, it's OK. If not replace the laser pickup unit also. The strip wire can be bought from most of the electronic spare part shops at your town. When buying laser pickup unit, its number must be noted, and exact replacement should be done. Otherwise, it won't match with the main board. OK.
Nov 08, 2011 | Televison & Video
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
Can you manually release a DVD from the Panasonic S32? The DVD player 'died' - with a CD inside. The instructions are silent on a manual solution.
Well you can please follow the below steps -
1. Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
2. Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It's the part that holds the DVD loader in place.
3. Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don't want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
4. Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn't quite finished yet.
5. Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
6. Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you're careful. You should be able to access and remove the disc.
Good Luck!!
Apr 01, 2010 | Panasonic Televison & Video
CD/DVD drawer won't open so CD stuck inside :(
Good Luck!! Thanks for using FixYa!!
Feb 03, 2010 | Cambridge Audio Azur 540D DVD Player
Dvd do not loads
Our started doing the same thing about a week after the warranty ran out. It has to do with the alignment of the discs being loaded. here's a work-around that works for us:
Open the tray
Choose which disc you are going to watch and use the Change Disc button to push the selected disc to the back (ie, if you want to view Disc 1, discs 3 and 4 will be visible in the tray).
Look down the center holes of discs 3 and 4... manually move your tray left-or-right to align the holes with the tray.
Push the Direct Play button on the top right of the unit for your disc of choice (Disc 1 using the example above).
hope that helps... I've searched for a while and played around with the unit (with and without the cover on) trying to figure out a way to re-align the tray, but no luck.
--JeD
Aug 20, 2008 | Samsung HT-WP38 System
Philips dvd783c wont spin.
It sounds like one of the hindge/wheels are off set. Most of the time that can also cause the lazer lense not to come up all the way in order to properly read the disc. When you keep the door open and press start does it allow the lazer lense to come up all the way? That is the small circle glass peice you will see when you look in--some you can see it some you cant.
Let me know.
Thanks.
Mar 31, 2008 | Philips DVD783CH Multi-disc DVD Player
Panasonic SA-HT692
that just happened to me last night. do you know if there is a disc inside the player? it's possible it is stuck and preventing the tray from opening.
Jan 04, 2008 | Panasonic Home Theater System System
Durabrand DVD-1002 DVD Player Logo
371 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
