Question about Danby DPAC10031 Air Conditioner
My indoor unit airconditioner located in my basement
It seemed to be just dripping water so i cleaned it up 1 day while cleaning basement i noticed that alot of water was coming out the base. i pushed it with my hand and tons of water came out. why and what is wrong
Hi, all a/c's produce water as condensation. Portables have a hose connector near the base. Wall mounted have a permanent hose that allows water to vent out. This pipe can get blocked by dust and fluff usually at the elbow joint. Try useing a small drain cleaning wire or extract all the water out ( i use a big syringe ) and put half a cup full of kettle boiled water in, or a drain cleaner. be sure to flush out well. Good luck. steve, UK
Posted on Sep 10, 2007
SOURCE:
What is the problem when an air conditioner begins to freeze up?
Freezing up is caused by
•dirty air filter or evaporator coil(indoor coil)
•dirty blower wheel or blower fan blades
•low freon
•weak or slow blower motor
If air filter and indoor coil are clean may be low on freon. Blower wheels seldom get dirty on window units. Pull unit from window and clean both coils with a water hose. Careful not to get any electrical wet. Let dry for a while and reinstall. If it continues to freeze its a freon problem most the time.
Jun 23, 2015 | Norpole 5000BTU Mechanical Window Air...
My Carrier Infinity system Model FE4A is leaking water from the bottom of the unit on to the basement floor. How do I stop the leak?
have your HVAC technician check the pressures in your unit...sounds like you may have low pressure. You should NOT be having any ice build up to melt off.
Sep 13, 2014 | Carrier Infinity Series Variable Speed...
I recently noticed that my GE window airconditioner has been leaking on the inside of my window. It has cause my new wooden windsill to turn black from the condensation dripping onto the sill. I did not...
Actually, you may have two issues. The drain hole may be clogged and the rear of the unit may not have enough downward tilt, to allow the water to flow to the rear of the drip pan and ultimately out thru the drain hole. The general rule of thumb is 1/4" to 1/2" rear downward tilt.
As far as the drain hole is concerned, it can be hard to find at times. Because the clog will often times blend in the drain hole. Patience & persistence are required in locating it. A pipe cleaner works well to clear the clog.
Troubleshooting the above should help to solve the problem. Thanks for choosing FixYa.
Sep 07, 2011 | GE Heating & Cooling
I have 2 units GE AGMO8LHG1. One is perfect but the one in my bedroom squeaks and gurgles, has a musty odor and is quite noisey. The tenant above has a unit that is constantly dripping onto mine, every...
This could be a couple things but yes I agree you do not need the unit above dripping onto yours.you shuld see if you can get the floor above to help solve it. then it sounds like you may havea wet filter as well. . you can pull the unit out and check the drains under the indoor coil and if you see some slim clean it out and wash it down with a mixture of bleach and soap and some hot water. bet certain that the unit is tiled to the out side about 1 inch or so. If the filter is wet wash it out well with HOT soapy water as well. Thi should help let me know Jon
Aug 07, 2011 | GE Heating & Cooling
Hi my name is Tom, The problem I have is my airconditioner runs and i've also cleaned filters, but it only blows nomal air...it dosen't seem to cool...
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Check indoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3 degrees less than room temp.6.Check compressor is working with correct pressure.
Thanks. Helpful?
Jan 03, 2011 | Heating & Cooling
Water is dripping out of the indoor unit on to the floor unit had only been turned on for about 1/2 hr this happened about a week ago but after cleaning the filters problem seemed to go away has now...
Hi
Check if the water drain pipe is not blocked. Or if the water drain pipe is not sloping downward away from the the unit. Or if the inside unit is level or slightly tilted to the side of the water drain pipe.
Jan 25, 2010 | Heating & Cooling
Too much water condensation
Check your condensate drain. It could be plugged. Or perhaps you have a crack in the drain pan.
Jun 21, 2009 | Ruud UAKA037 Air Conditioner
It will not cool below 72. 73 and when energy saver is on, it is always running
make sure indoor filter and both coils are clean indoor clean with mild spray cleaner and rinse with water same way out side mild spray cleaner rinse with water hose very low pressure to not bend the fins unit should have about 20* difference between air going in and air going out hope this helps
May 24, 2009 | Heating & Cooling
Uneven air distribution through indoor unit
you should remove the indoor unit and send the gas to outdoor unit and remove the pipe line and start cleaning it.
Apr 10, 2009 | Heating & Cooling
Leaking water
water leakage from indoor unit
1.clean cooling coil
2. wash air filter
3. check drain tray.if it block then clean it
4. check drain pipe U band.
5.check indoor unit water tray.if damage change by new one or repair it
Sep 04, 2007 | Friedrich QuietMaster RS10J10 Air...
Danby DPAC10031 Air Conditioner Logo
116 people viewed this question
Top Danby Heating & Cooling Experts
Dennis Boxerman
mintvl
Level 1 Expert
Bill Long
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
