Question about Novell Nsure Audit 1.0 Secure Logging Server for PC, Unix
My emachine wouldnt let me log on even though im using proper username and password
Logging on . my emachine wouldnt let me log on even though im using proper username and password
  • 457 Answers
Re: my emachine wouldnt let me log on even though im...
Please elaborate more on what you mean by it would not allow you to log on discribe in detail what it actually is doing so I can know how to help you. For instant is it whirling at the bios screen and continuing doing this?
Posted on Sep 10, 2007
0 characters
3 Points
I have problem in logging in facebook because i forgot my password and the email that is connected with facebook is deactivated due to lack of use
Face book will never remove your account. log in to facebook with your email address then click on forgot password they will email instructions to reset your password.
Mar 13, 2015 | Hainsoft Reset Password Batch
Using two domains for example Domain X and Domain Y.
You can create a two-way trust with domain-wide authentication.between the two domains if they belong to the same organisation depending on the imformation that you want to share or use between the two domains .you do this on an established domain controller for each domain.
  • .On the server where you have domain controller for example on Domain X ,log on as an administrator then go to >Start >Administrative Tools >Active Directory Domains and Trusts.then Right-click on Domain X, go to > Properties. >click on "Trusts" tab. then > New Trust. click - [Next].
  • In the name field type the second domain to trust thats domain Y, in this case then click >next to continue
  • then Select the Direction of the Trust. either two way trust or one way but in this case its a two way then Click [Next].
  • In "Sides of the Trust", select the "This domain only" bullet. then [Next].
  • Set the Authentication level to "Domain-wide Authentication". then [Next].
  • you will be prompted to Enter a Trust Password twice. also Remember to make it strong enough to comply with password criteria in your domain security policy.
  • Click [Next] - [Next] - [Next].
  • Select the "No" bullet to the Outgoing Trust Confirmation - [Next].
  • Select the "No" bullet to the Incoming Trust Confirmation - [Next].
  • Click [Finish] - [OK].
  • Log off of DomainX ,
  • Then .Login to DomainY using Administrator account.
  • go to > Start > Administrative Tools ->Active Directory Domains and Trusts.
  • Right-click on Domain Y, and select Properties. click on "Trusts" tab. Click the [New Trust...] then [Next].
  • in the Name field type domain X to indicate the domain to trust, then click [Next].
  • Select " the Direction of the Trust. in this case its a two way trust then Click [Next].
  • In "Sides of the Trust", select the "This domain only" bullet. Tthen Click [Next].
  • Set the Authentication level to "Domain-wide Authentication". then Click [Next].
  • you will be prompted to Enter a Trust Password twice.dont forget to use the same Trust Password that you used previously in the step above then Click [Next] - [Next] - [Next].
  • Select the "Yes" bullet to the Outgoing Trust Confirmation - [Next].
  • Select the "Yes" bullet to the Incoming Trust confirmation - [Next].
  • to finish Click [Finish] - [OK].
  • Then Log off of DomainY.
on Dec 30, 2009 | Network Software & Management Tools
I've forgotten my password to
BT have now transferred emails from what used to be known as BTYahoo and is now known as BTMail. If you go to the log in page here
Email Login Page
then you can enter your email address and underneath the password box is a link "Forgotten password". If you click on this (the word "password"), you will be taken to a page to enter your username (email address). Clicking continue will put a green tick against the email address (it does, I checked it with your email address) and then be taken to a page where you can choose how to receive a password reset email (martin.****@****
or a password reset text message (********6333)
If you no longer have access to this email or this phone then I am afraid you will have to brave the BT phone system so that they can reset your password !!
Hope this is helpful, if so would you please register that with Fixya
Jan 03, 2015 | BT Broadband Desktop Help
How do I unlock voicemail on a hand set?
Enter the admin mailbox (usually FEATURE 981). Follow the prompts to enter the mailbox change menu for the box you need to reset and select the "reset password" function. This unlocks the box and sets the password to 0000, which will then prompt the user to enter a new password when the mailbox is opened.
Jun 27, 2014 | Nortel Network Software & Management Tools
Just log on your mobile using your email and password. That should fix it.
Apr 02, 2013 | Samsung GT-S5300 Galaxy Pocket Unlocked...
I try to log into my user name dragooljd, but it keeps coming up when I put in my password that it is not valid. How can I get it changed as I can not log into that one. It says that my password is not...
Common problem is the caps lock key is on so you are typing with CAPS and the password is invalid.
Hope this information will help.
Your response is very much appreciated...Thank you for using Fixya...
Sep 26, 2011 | AOL America Online
I lose my other hotmail possword,in my computer how can i get back my password
hotmail has a password recovery system, try to log on and click "i forgot my password"
Oct 30, 2009 | Sony Network Software & Management Tools
Can't log onto Windows XP
Let me guess you type in your password and user name it then logs off. Have you check the recharger it may not be you laptop but the power plug not connecting there for you laptop had ran out of battery. Check recharger as I had the same problem and I replaced the plug recharger and it worked fine.
Jan 11, 2009 | Microsoft Windows Services For NetWare 5.0...
Ristricted logging onto server when server is off
Thanks for the background info, this makes it easier for me to see what you need.
You need to disable your guest account if you havnt already done so.
The user is logging on with a cached version of the logon information, this is useful for when the server goes down but not in your case as you need to prevent this.
Another worrying aspect is that you allow all your users to log on using the same password. Very bad from a security aspect anyhow. It is better to change at least every 30 days. If they moan they will get used to it soon enough.
Go into group policy again and computer configuration>windows settings>security settings>local policies>security options and look for interactive logon:number of previous logons to cache - set this to 0. If the domain controller is not available and the logon info is not cached they cannot logon to domain.
Group policy can be overruled at the client end if they have admin priviledges so you may have to set this on the client pc also. But you need to test to see if it is required there. I have not used that particular policy but it should be ok just on the server. Your users dont have admin rights do they? Anyway good luck. You can set this by applying it to an OU or domain wide but if you want to target just this one pc then maybe if you put it in its own ou and apply it just there.
You need to create new policies rather than modifying the domain one and keep each policy for specific purposes so that applying them to ou's is easier, ie internet options policy, firewall policy, working hours policy etc.
Mar 26, 2008 | Network Software & Management Tools
Disappearing Command Bar in Business Objects 5.1
Hi monismitch,
I'm assuming that you're using Business Objects full client, in which case we can simply reset your user preferences.
Workflow on your machine
1. Start > Run > Type Regedit -- this will bring up your registry
2. Browse to:
HKEY_CURRENT_USER\Software\Business Objects\Suite 11.5\default\BusinessObjects\ "username" user prefs
3. Delete only the key that shows your username
4. Note - the above registry path is for BO XIR2, for version 6 the version name will be slightly different.
Log back into Business Objects and rerun the report.
Mar 19, 2008 | Business Objects BusinessObjects...
Network Software & Management Tools Logo
175 people viewed this question
Top Novell Network Software & Management Tools Experts
Jax Planet
Jax Planet
Level 1 Expert
Shahzad  Waseem...
Shahzad Waseem...
Are you a Novell Network Software and Management Tool Expert? Answer questions, earn points and help others
