Toshiba Portege 300CT  PC Notebook Logo
Posted on Apr 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a new laptop, put in password, now have forgotten it !
Can you help me change the password?
peter evan
Level 2:
Sniper:
  • Expert 103 Answers
  • Posted on Apr 11, 2009
peter evan
Expert
Level 2:
Sniper:
Answers
103
Questions
Helped
42123
Points
334
You need to ree set it for mat
Windows Password Reset
jaafar,
Change your Windows password
Your Windows password is the password you use to log on to your computer. You can help keep your computer more secure by changing your Windows password regularly and by using a strong password.
  1. Press Ctrl+Alt+Delete, and then click Change a password.
  2. Type your old password, type your new password, type your new password again to confirm it, and then press Enter.
If you have forgotten your password and you have a password reset disk, you can reset your password.
If you do not have a password reset disk and you have forgotten the password you will need to reinstall Windows or search the internet for password reset software.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
tip
Problem: You do not have access to change the settings in BIOS? . Have bought a...
There are two passwords in BIOS. One is start up password, the other isBIOS setting password. If you have forgotten the start up password thatmeans you cannot open computer at all. Then the first method is theonly thing you can do. Other methods can use to clear setting password.
==①:Motherboard Battery Discharge==
The common way toreset start up password is discharge Motherboard Battery. Most of thecurrent motherboard BIOS is using the button batteries to provideelectric power.That means if there is no electricity, the informationit contains will be lost. When it’s on power again, BIOS will set backto its original state, of course, there will be no BIOS passwords. Butyou will lose your setting at the same time.
What we need to dois to power off computer, open the computer box, and then unplug thepower plug of the computer to make sure that it is no electricity atall. Then locate the white silver button battery on the motherboard.Remove the battery carefully. Perhaps 30 seconds later, put back thebattery.
After put back the computer box then power on, thesystem will prompt “CMOS Checksum Error-Defaults Loaded”. That meansCMOS errors detected during inspections, had been included in thesystem default, BIOS password cracking success!
On somemotherboards, the battery is soldered to the motherboard, making itdifficult to remove. If this is the case, you have another alternative.Somewhere on the motherboard you should find a jumper that will clearthe BIOS password. If you have the motherboard documentation, you willknow where that jumper is. If not, the jumper may be labeled on themotherboard. If you are not fortunate enough for either of these to bethe case, you may be able to guess which jumper is the correct jumper.This jumper is usually standing alone near the battery. If you cannotlocate this jumper, you might short both of the points where thebattery connects to the motherboard.
==② : Backdoor BIOS Password==
Eachmotherboard manufacturer has set a backdoor password in order tofacilitate the provision of technical support. The backdoor password isa BIOS password that works, no matter what the user sets the BIOSpassword to. These passwords are typically used for testing andmaintenance. Manufacturers typically change the backdoor BIOS passwordsfrom time to time.
AMI Backdoor BIOS Passwords
Reported AMIbackdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW,BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
Award Backdoor BIOS Passwords
Onereported Award backdoor BIOS password is eight spaces. Other reportedAward backdoor BIOS passwords include 01322222, 589589, 589721, 595595,598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARDSW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT,CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332,J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz,TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords
ReportedPhoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, andPHOENIX. Backdoor BIOS Passwords from Other Manufacturers Reported BIOSbackdoor passwords for other manufacturers include:
ManufacturerBIOS Password
VOBIS&IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enoxxo11nE
Epox central
Freetech PosterieI
Will iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
SOYO SY_MB
TMC BIGO
ToshibaToshiba
Remember that what you see listed may not be the actual backdoor BIOS password,this BIOS password may simply have the same checksum as the realbackdoor BIOS password. For Award BIOS, this checksum is stored atF000:EC60.
==③: Software Crack==
There are a lotsoftwares to test systems or start up password, but they need to run onWindows. So it is only used to reset BIOS setting password.
!BIOS will recover the BIOS password for most common BIOS versions, including IBM, American Megatrends Inc, Award and Phoenix.
CmosPwd will recover the BIOS password for the following BIOS versions:
•ACER/IBM BIOS
•AMI BIOS
•AMI WinBIOS 2.5
•Award 4.5x/4.6x/6.0
•Compaq (1992)
•Compaq (New version)
•IBM (PS/2, Activa, Thinkpad)
•Packard Bell
•Phoenix 1.00.09.AC0 (1994), a486 1.03, 1.04, 1.10 A03, 4.05 rev 1.02.943, 4.06 rev 1.13.1107
•Phoenix 4 release 6 (User)
•Gateway Solo - Phoenix 4.0 release 6
•Toshiba
•Zenith AMI
Ifall else fails, you might be going to lose some money for technician.But they will use these same methods, try hard by yourself.
on Jan 29, 2010 • Computers & Internet
1helpful
2answers
WHAT WOULD BE THE PASSWORD FOR ENTERING THE BIOS TOSHIBA 1115 F103 THE LAPTOP JUST GO A NEW HARD DRIVE AND I CANT GET INTO THE BIOS tHANKS
Hold f2 on start up until it boots in to bios failing that do the same but this time hold f8 but hold down this key just touching it wont work.
Forgotten power on password on a Dell Inspiron 910 Mini, running Windows XP, as soon as you turn it on the password prompt comes on, tried to get the child who put it on there to remember but they...
Hi there !
To reset the BIOS password, you need to remove open your computer CPU or your laptop to remove the CMOS battery and return it back again. By doing it, it will reset the BIOS password and will run your computer on usual way.
I hope it helps you.
Forgotten password to connect to network
In order to check or change your password for NetGear , go to http://192.168.1.1. It will ask you for a user name and password. The default is “admin” and “password”, Once you are connected, go to Wireless Settings and you have the option to change password there.
Hope this helps
I have locked myself out of my new Acer Aspire 5332 laptop because I put in the wrong password. I had not made a password recovery disc.....HELP !!
Hi
Sorry about this, but forgotten password is an issue, Whats your operating system? usually when you put a password on, there will be options where you can put a hint just in case you forget. in any case you're still unable to remember your password. The only possible way is to perform a clean install of your operating system...
Hope it helps!
2answers
Forgot password need help bypassing to change
is this a bios password? or windows logon password?
Password
i think its wep or wpa password which u created in teh w/l router>connect a pc through hard wired on teh routers ether net port>and open a explorer>and in address bar type-(192.168.1.1)>enter>
user name--- admin- all lower case
password---- admin- all lower case
click on wireless-and click on wire less security>and change teh wep or wpa password and click on save settings>and reboot the router as well as laptop and use teh new password which u changed>rate me solved if its works
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
