Question about Sony PlayStation 2 (PS2) Console
Playstation 2: Blank screen
I'm using an A/V cable to connect my playstation through a surround sound system to my TV. Yes, I've tried multiple AV cables, different televisions, and different connection options. I can hear the browser "music" through my speakers, but the video is not working. This issue has come up in the past, and I bought a new cable. That worked for some time, but now I'm having this issue again. Please help!
    Problem Solver:
  • 13 Answers
Try another AV cable, recheck your connections and just try it straight to the TV first without using the sound system and see what happens.
Posted on Sep 20, 2007
6ya staff
SOURCE:
I hooked hdmi to tv. i went thru ps3 settings for video n audio n swithch audio to the red n white output. now i have sound thru surround sound but my video is flickering n i cant c so i can undo it
Make sure the Component AV Cable is connected to the AV Multi Out port on the back of the PLAYSTATION 3 system. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the ON/OFF button long enough to reset the Video Output Settings.
3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 01, 2010 | Sony Playstation 3 (PS3) Console
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
Ps3 as no video or sound i bought 3 wires for the tv and no color or soud sows we even used a ps2 cable
Excerpt from the PlayStation 3 Manual:
There is no picture on the TV screen.
*Check that the input mode of the TV is appropriate for the connector in use on the system.
*There may be a problem with the AV cable in use. Try using another cable that is compatible with the PS3 system.
*If the video output settings on the system do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system. Then, with only the system and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
*If the resolution of the video content is not supported by the TV in use, when the video is played the screen may go blank. If this happens, go to the screen for selecting the resolution in the system's video output settings, select "Custom" and then select all the resolutions that are supported by the TV.
Jul 29, 2009 | Sony Playstation 3 (PS3) Console
Origiannly had my son's PS# hooked up to our HD TV
You must reset your PS3 in order to accept the new TV configuration.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • From: http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/std_adp.php?p_faqid=967&p_sid=1frk_Cuj
    Hope this helps please remember to rate my response, thanks!
    OpenSource13
    Apr 06, 2009 | Sony Playstation 3 (PS3) Console
    Can no longer see output on TV but PS3 is on
    • Check that the input mode of the TV is appropriate for the connector in use on the PLAYSTATION computer entertainment system. If you switched to the analog cable you need to change the TV from HDMI input to the AV input.
    • There may be a problem with the cable in use. Try using another cable that is compatible with the PLAYSTATION. If you use a different type of connection make sure to change the channel.
    Jan 28, 2009 | Sony Playstation 3 (PS3) Console
    Want to play my playstation thru my sa ht500 system
    You will not be able to get full surround from your Playstation using this home theater system - if you use a red/white composite AV cable and connect it to the area marked TV AUDIO IN on the back of the Panasonic, you will be able to get stereo sound.
    -Tha Mp3 Doctor
    Dec 21, 2008 | Panasonic SC-HT500 System
    How to connect an Xbox 360 to a PM 420 W
    You'd take the audio cables you'd normally connect to your TV or surround sound system, and connect them to the chair. I believe the chair comes with extension cables to make this easier, but if not you can get them at any Radio Shack or electronics store.
    If you use a HDMI cable to connect your 360 to your TV, you'll need to also plug in the AV cable so you can get the audio cables. The 360 won't have a problem with this.
    Dec 14, 2008 | Pyramat PM450WR for PlayStation 2,...
    Ps3
    Hi bazza1945,
    The answer would be a yes, as long as the model of your playstation 3 has what's called a DIGITAL OUT (OPTICAL) CONNECTOR. As far as I know all of the PS3 has this type of connector at the back of the unit near the LAN port and AV port.
    The next thing you need to check though is if you surround sound system has a DIGITAL OUT (OPTICAL) CONNECTOR. If it does, then you're all set. All you need to do is buy the necessary cable to connect the PS3 to your home theater/surround sound system.
    For more information you can check your PS3 user manual or view it online at http://www.us.playstation.com/Support/Manuals/PS3
    Hope this helps!
    Peace! :)
    Oct 22, 2008 | Sony Playstation 3 (PS3) Console
    PS3 no longer communicating with TV
    All: Try this -
    P
    erform the following steps to reset the Video Output Settings.
    1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
    3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
    NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
    As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
    If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
    With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
    If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
    1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
    3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
    4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
    5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
    6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
    7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
    Dec 16, 2007 | Sony Playstation 3 (PS3) Console
    Ps3 hdmi-av
    i currently have the exact same problem...i always play HDMI but i went home from college for thanksgiving and wanted to play on a regular AV jack TV, hooked up, and have no picture whatsoever...and i think it's because of the settings on the PS3 since it's set to send out an HD signal...Well i found this straight from Playstation3.com, on the support/troubleshooting section
    • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution."
    Hope it helps =)
    Nov 17, 2007 | Sony Playstation 3 (PS3) Console
    Sony PlayStation 2 (PS2) Console Logo
    71 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Ekse
    shevantha perera
    Damen Wong
    Damen Wong
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
