Question about Sony DCR-PC53E Mini DV Digital Camcorder
Sony DCR-PC53E camcorder vertical hold
Our little Sony camcorder is behaving like a 1970s TV set, with the vertical hold failure that meant the picture rolled upwards. It doesn't seem to respond to resetting the camera, so do we have a hardware fault that'll involve an expensive repair?
SOURCE:
SOURCE: Sony DCR-SR200 screen slowly "scrolls" vertically like the V-Hold on an old television
After researching various flexible cable numbers from different posts, I found that the SR-200 uses a unique cable, FP-610, part number 187145711. This has been discontinued and replace with part number 187145721 (same cable also used in DCR-SR300).
If you are in doubt with your camera, just take it apart up to the point of seeing the ribbon cable. The part number is printed on the side.
I found two sources for this so far, www.nexttronics.com and https://servicesplus.us.sony.biz/sony-parts.aspx. Price ranged from $30 to $40 plus shipping.
Posted on Sep 14, 2008
SOURCE: Sony dcr sr 200 camcorder doesn' turn on
LCD ribbon cable is probably the culprit.
Posted on Jul 07, 2009
  • 497 Answers
SOURCE: camcorder SONY DCR-TRV25E, COMPATIBILITY window vista
If you want to use the USB cable to connect the Camcorder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System.
Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable.
You can use any video capturing software like Windows Movie Maker to transfer the video from the Computer using i.LINK cable.
Refer this link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
If you are using an i.LINK cable then:
The Camcorder will flash the DV IN message as soon as the i.LINK/Firewire cable is connected to the Camcorder.
If you are getting the DV IN message then it indicates that the Camcorder recognize the connection.
If you are not getting the DV IN message as soon as the i.LINK cable is connected with the Camcorder then the issue may be with either the Camcorder or with the i.LINK cable.
Try resetting the Camcorder or try with different i.LINK cable. Locate the RESET button behind the LCD screen of the Camcorder. (You will be able to locate the RESET button by opening the LCD Screen. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object).
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
If the issue still persists after resetting the Camcorder and with different i.LINK cable then your Camcorder requires service to resolve the issue.
Good Luck!!!!!!!!!!!!!!!
Posted on Sep 23, 2009
  • 125 Answers
SOURCE: No image on Sony DCR SR82 Camcorder. Only horizontal lines.
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's very common in sony. Good luck
Meggita
Posted on Sep 25, 2009
  • 29 Answers
SOURCE: Sony vx2100 internal battery no longer holds charge
battery is inside the handle... open the three top screws of the handle cover and remove the cover. you can view the batteries.. replace both of them with same type.
Posted on Jan 12, 2010
DCR-TRV30 Internal clock battery is end of life. It will not charge overnight or hold date/time set information between main battery changes. There is no replacement information in the user manual. Where...
This small back-up battery on my Sony is under the main big power battery, it is like a large screw under the main power pack, I just turn that screw and the little round lid comes off to get to the little silver flat back-up one.
They are readily available from most good camera shops like Jesops for around £12 to £15 each.
May 23, 2010 | Sony Handycam DCR-TRV30 Mini DV Digital...
How to connect to tv
I don't know how to connect my sony dcr hc 21e with the tv can someone help me please.....
mogie naiken
Dec 18, 2008 | Samsung SONY Handycam DCR-HC21E MiniDV...
My sony dcr-dvd105 handycam camcorder all of a sudden shows only
There is 2 possibilities, either aperture of camera jammed and doesn't open or CCD Imager got defective in your Sony DCR-DVD105 camcorder.
Let me know if you have little experience of camera repair to guide you further.
Nov 29, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Jul 21, 2008 | Sony Handycam DCR-SR200 Camcorder
AC Power Adapter
Hi here is link where you can buy this ac adapter/charger for DCR-DVD108
http://azsurplus.com/index.php?main_page=product_info&cPath=1_85&products_id=1910
it is also works with more models as mentioned bellow
Compatible Part Numbers: AC-L20A, AC-L25A, AC-L25B, AC-L200
Input: AC 100V-240V 50/60Hz
Output: 8.4V 1.5A
Dimension Approximate: (48mm x 29mm x
To Use With :
CCD-TRV138
CCD-TRV338
DCR-DVD103
DCR-DVD105
DCR-DVD108
DCRDVD202E
DCR-DVD203
DCRDVD203E
DCR-DVD205
DCR-DVD305
DCR-DVD403
DCRDVD403E
DCR-DVD405
DCR-DVD505
DCR-DVD508
DCR-DVD7
DCR-DVD92
DCR-DVD92E
DCR-HC1000
DCR-HC1000E
DCR-HC16E
DCR-HC17E
DCR-HC18E
DCR-HC19E
DCR-HC20
DCR-HC20E
DCR-HC21
DCR-HC22E
DCR-HC26
DCR-HC28
DCR-HC30
DCR-HC30E
DCR-HC32
DCR-HC32E
DCR-HC36
DCR-HC39E
DCR-HC40
DCR-HC40E
DCR-HC42
DCR-HC42E
DCR-HC46
DCR-HC65
DCR-HC85
DCR-HC85E
DCR-HC90
DCR-HC90E
DCR-HC96
DCR-HE20E
DCR-HE22E
DCR-HE30E
DCR-HE32E
DCR-HE40E
DCR-HE65E
DCR-HE85E
DCR-IP1
DCR-IP1E
DCR-IP210E
DCR-IP220
DCR-IP220E
DCR-IP45E
DCR-IP5
DCR-IP55
DCR-IP55E
DCR-IP5E
DCR-IP7BT
DCR-IP7E
DCR-PC1000
DCR-PC106E
DCR-PC107E
DCR-PC108E
DCR-PC109
DCR-PC109E
DCR-PC350
DCR-PC350E
DCR-PC53E
DCR-PC55/B
DCR-PC55/R
DCR-PC55/S
DCR-PC55/W
DCR-PC55E
DCR-SR100
DCR-SR200
DCR-SR300
DCR-SR40
DCR-SR60
DCR-SR80
DCR-SR82
DCR-TRV280
DCR-TRV480
HDR-CX7
HDR-HC3
HDR-HC5
HDR-HC7
HDR-SR7
HDR-UX5
Jul 11, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Error message
hi i have the sony DCR-PC53E camcorder with the error code E:61:10 does anyone have any suggestions on how to fix this problem any help will be more than appreciated
Apr 17, 2008 | Sony Video Cameras
Vertical green and brown lines on the viewfinder and LCD
Your camera DCR-HC20 has problem with ccd imager and this part will be replaced. After that camera will show live view to record.
Sony announced free of cost repair scheme for such problem. You will pay shipping charges only $15
Click Sony Support for details.
Jan 09, 2008 | Sony DCR-HC20E Mini DV Digital Camcorder
Sony DCR PC101
Good Day, you have to open the left cabinet, and there you can see the 2 screws holding the LCD panel,
Sep 04, 2007 | Sony Handycam DCR-PC101E Mini DV Digital...
Sony DCR-PC53E Mini DV Digital Camcorder Logo
94 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
