Question about RCA HD61THW263 61" Rear Projection HDTV
Rca hd61thw263 61 in. dlp
Seems a lightning strike took out my bulb eventhough i have a surge protector. after replacing the bulb perhaps 1 hour later a shadow began to appear at the top of the screen and progressed slowly down until only the edges are visible. please can you help?
Posted on Apr 14, 2008
When and How Should a Surge Protector Be Used on a Fixed Switch?
Common Causes of Lightning Strikes
  • Outdoor network cables or power cables are routed overhead.
  • A switch is deployed outdoors but is not properly grounded.
Damages of Lightning Strikes
  • If power cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn the power supplies.
  • If network cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn interfaces of the switch.
When a switch undergoes lightning strikes, overvoltage is induced by lightning on network cables and transmitted to interior of the chassis. The surge protection measures, such as lightning rod and chassis grounding cannot prevent the damage. Therefore, surge protectors or surge protection circuits are recommended.
Surge Protector Use Precautions Take the following precautions to protect a switch from lightning:
  • Ensure that the ground cable is connected to a ground bar or a ground point on the cabinet.
  • Avoid routing cables overhead in an outdoor environment. Bury cables underground or route them in steel tubes.
  • To protect network interfaces against lightning, use 8-line surge protectors (or Huawei certified 4-line surge protectors).
  • When installing a network interface surge protector, connect the IN end to terminals and the OUT end to network interfaces of the switch.
If a fixed switch is installed in a network box, follow these instructions:
  • Connect the ground cables of the switch and surge protectors to the ground bar in the network box.
  • The maximum length of a ground cable cannot exceed 40 cm, and a length of smaller than 15 cm is recommended.
  • If the network box is located outdoors and power cables are routed aerially over a long distance (more than 300 m) to the network box, it is recommended that you install a power supply surge protector in the network box. The decoupled power cable must be at least 3 m long
S2300 Switch Thunder link com
Dec 08, 2016 | Office Equipment & Supplies
Is the module of lg tv 32ld330-mb affected when theres a lighting strike???is there a chance to be fix??
The damage from a lightning strike tends to be random. Sometimes it's minor, and only a few parts are affected. Other times, many parts are ruined, or destined to fail soon as a result of the current surge.
If the strike came over the power line, the input surge protectors in the power supply should be replaced, even if they look good. It would be prudent to replace the entire power supply. If you had the set plugged into an external surge protector, that should have taken most of the hit and should also be replaced. (Some surge protector manufacturers will pay up to a certain amount for repair or replacement of equipment plugged into their products if it is damaged by lightning.)
If the lightning came over an unprotected input cable, fixing the set would be a gamble. You could end up changing a lot of modules, beginning with the main board.
Jan 30, 2015 | LG Televison & Video
I have a motororola model MBP8 PU babby montior quick working after power went out they turn on but but don't work
Is it plugged into a surge protector? When the power comes back on to a lot of residents at the same time, a power voltage spike occurs that can damage electronics. All items that have any electronic circuits, need to be protected by a surge protector. Surge protectors do not protect against lightning strikes.
Jun 04, 2014 | Computers & Internet
Rca lcd tv power surge lighting
The power supply is a likely place to find what's causing the problem
Jul 11, 2013 | RCA Televison & Video
After a lightning storm my bosch single 30" wall oven displayed an F03 err. I turned the power supply off at the breaker for one minute as directed by the oven's manual. This action did not...
Find out what the F03 error is for and then check out the appropriate area. If there was a strike of surge the most likely place to look for damage is the area where the electricity first enters into the device.
Sep 07, 2017 | Bosch HBL 5036 Electric Single Oven
My sister in Charlotte, NC had a couple of seconds power outage, her processor, modem, monitor, tv and phone were connected to outlet thru a surge protector. All work except processor. Is there a reset for...
No reset for that processsor.. ALL Surge protectors are not guaranted for lightning strikes. Does she know if lightning hit the line that services her home?
Jul 13, 2010 | HP Pavilion a1540n PC Desktop
61" RCA DLP won't turn on after power blip
Hi, thank you for visit fix ya.
Do you havve problems with power supply capacitors.
Replace this:
2200uf 25V, 220uf 25V ( bowed or vented). Located beside power transformer.
Thank you
Jul 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power Surge - No lights on control panel
u might need to change Lightning/Power Surge Suppressor the comes inside of ur motor connected between the black and white cables of the power input of ur motor
Jul 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sony KV-20FV12 channel will not change
Pasted from another message I just posted-
It may be too late for this advice, but if you live in a lightning prone area, you should consider having a 'whole house surge protector' installed.
The cost should be well under $300 (a lot less if you install it) and with the included insurance (most often for $25,000) it is a good investment.
If your house was struck, I'm surprised you don't have a list of things that no longer work.
No, I don't think it is worth the cost of a repair, if you can even find someone to do it for you.
Most of us are retired-
Jun 24, 2008 | Sony KV-20FV12 20" TV
Lightning Problem
I HAVE A 61" RCA INFOCUS ALL THE LIGHTS IN FRONT OF THE TV IS BLUE YOU UN PLUG IT AND PLUG IT BACK IN IT STAYS BLUE. YOU CANT TURN IT OFFOR ON
Apr 14, 2008 | RCA HD61THW263 61" Rear Projection HDTV
RCA HD61THW263 61" Rear Projection HDTV Logo
222 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
