Question about Canon (12x36) IS II Binocular
Pattern appeared on interior of lens/prism
My Canao 12X36IS binos were stored for a season (indoors. When using them for the first time, I noticed a pattern like etching or dried condensation on when looking through them. It seems to be on the prism or lens interior surface. Any sugestions on how to fix. Is this just a cleaning issue?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
What you see is fungus . It comes off very easily BUT if allowed to grow it will damage coating and glass because the organism releases hydrofluoric acid. So the key is to clean as soon as possible. You can do this your self but be careful around the prisms because even slight movement here will upset your collimation ( will get 'double image')and then you will need to have your nbinocs aligned properly.
Posted on Sep 15, 2007
SOURCE:
I was given a pair of 10X42 powerview FOV293FT the Prisms seem to have shifted can they be repaired and would this be cost efective Ian South Africa
If there has not been a major blow, it is in most cases straightforward to align that double image.
Begin by looking if any of the eyepieces or front tubes are jammed, if so they need to be straightened or replaced.
Another problem is if something rattles, and if you notice that it affects the double image. It could for example be the prism holders, or the front lens of the eyepieces. If you are lucky it is just the adjustment screws not being properly screwed in, see below, otherwise this problem needs to be taken care of firsthand.
For adjustment of the double image binos come with three more common options. There are in some cases concentric adjustment rings around the front lenses. More frequently on porro binos there are adjustment screws on the prism housing. You find them under the front and rear edges of the rubber fascia. Or with roof prism binos you often adjust the angle of the eyepieces with in that case adjustment screws on their periphery
To adjust you first pull the two tubes apart a little, look then at something with horizontal and vertical lines in the distance, for example a building. The image will look like bino views in a movie film, with two different circular fields of views kissing each other in the middle.
It is easy to see malalignment for horizontal lines as they go from left to right. These are also the most important to adjust. For vertical lines you need to scan left and right and see if the image jumps sideways. This direction is actually not totally necessary to get perfect, the eyes can slightly adjust for this, but at the price of fatigue.
Be careful and make small adjustments at a time. You should be done in a few minutes.
Nov 02, 2014 | Bushnell Optics
Winchester WL-7350WR 7X35 binos out of aligngment/colimation- need to re-adjust. Don't know if there's any objective lens alignment method, but I have found the rear adjusting screws for the prisms under...
There are another set of adjusting grub screws not just these! If you need to collimate them then you will need to adjust the correct ones to avoid what is known as "conditional collimation" where they are only good for people with the same IPD (interpupilary distance). If you feel confident that you can do this fine. But first is there any leaning field obvious? Using one side at a time and looking at a horizontal or vertical object (like a flagpole) show any lean when compared to the visual appearance? If it does then you need to send them to a service centre for correct alignment.
Feb 23, 2010 | Winchester Optics
We had a fire and my binos got smoked inside. I took apart the front and cleaned the prisms in front and lenses. How do I access the back prisms? How do i get the cover off the prisms at back of binos.
most prisms have coating on their air to glass surfaces. Chances are you have already degraded their original quality, even with the smoke gone. From past exp. you will be better of getting another bino...
Feb 16, 2010 | Bushnell Legend 19-1050 (10x50) Binocular
Dropped unit. Knocked the prisims loose. All
It's quite easy to dismantle and inspect, look for tiny retainer screws around eyepiece and/or unscrew lens shrouds. Normally the prisms shouldn't come loose in average to good quality viewers, they'd be held in by some sort of retainer, eg- flexed, spring tempered metal, where you screw in one side and then have to flex (bend) the metal to screw in other side over the back of the prism. It sounds like yours may use an adhesive retainer, if so clean of old residue and use fresh silicone, or may have broken the clip and or screws. But it may just have popped out, in which case reattach it. Make sure the prisms are seated properly, 1 hardly visible flake of glue or dirt under the prism will offset vision noticeably. I would say you may be lucky and find an honest repairer for about $45.00 if prisms aren't damaged.
Dec 11, 2009 | Swift 779 Birdfeeder (10x40) Monocular
I see two immages. I can not get the immage to become one. I am using a Nikon 8x21 6.3deg Sprint II
this is usually caused by the bino's being dropped or banged knocking the internal prisms out of alignment.
Oct 06, 2009 | Optics
I have double vision with binoculars. When I look at jupiter for example, I see 2 as if the optics are not aligned.
Your question is listed under "Zhumell Oberwerk 45 25x100 Astronomy binoculars". If these are what you have then they're an extremely high end expensive specialist item and will need professional realignment. I'm assuming that if you do own a pair of these then you're knowledgeable enough to have done all you can to adjust them correctly.
I suspect that you have a regular pair of 10x50 or similar binoculars, with a centre focus wheel and hinges. If this is the case then try to wiggle one of the eyepieces back and forth: if you can easily move it and the other eyepiece remains steady then you have a broken hinge. This is a very common fault especially if your binos have been dropped or if they've been stored in their case upside down (i.e.standing on the eyepieces).
A broken hinge is normally a write-off as there is rarely sufficient area to us epoxy glue on and the metal used is not usually suited to being brazed. Even when the hinge can be repaired it's normally permanently misaligned.
Either resign yourself to using one half of your binoculars or buy a new pair. In the UK LIDL regularly sell a pair of Meade 10x50 binos of excellent quality for just over £10 and that's only a little more than a bottle of epoxy resin glue costs. You may be interested to know that one of the world's most successful supernova spotters does so in his back garden in the UK using just half a pair of old 7x50 binos.
Sep 16, 2009 | Zhumell Oberwerk 45 25x100mm Astronomy...
Dropped new Celestron Skymaster 15x70 binoculars. Nothing appears broken, but now have two images. Can I repair this. and how? Thanks. Dan
Don't "unscrew" the binoculars. there are no user servicable parts inside. the collimnation adj screws are beneath the rubber boot just under where your index fingers rest when looking through the bino's. use a jewelers screwdriver to tease the boot up and stick a small nut or something in. then put the binos on a stable surface and play with the screws a bit while watching the images. you can get them pretty close this way.
Jul 21, 2009 | Optics
Double vision
take it into an outdoor shop and they can check the mirror alignment, seems that it may have "altered' itself
Jun 22, 2009 | Zeiss Classic B/GA 524013 Binocular
Prism came apart need assy instructions
you dont say what kind of bino it is....if its cheap model probably not worth repair and shipping charges.if i can be of further help call 5088331232...larry
Jun 22, 2009 | Tasco Essentials 165BCR (8x21MM) Binocular
Water inside trying to clean
Why are you using water , which contains impurities
I use alchohol impregnated lens wipes which you can buy over the counter for cleaning spectacles, it also evaporated quickly
Use a lens cloth to polish the glass as it dries off.
Do not over do the application of any liquids on lenses as over time it will seep through the the various elements of the lens causing them to part company and your bino's will lose their sharpness
May 27, 2009 | Praktica Roof Binocular
Canon (12x36) IS II Binocular Logo
206 people viewed this question
Top Canon Optics Experts
old marine
old marine
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Canon Optic Expert? Answer questions, earn points and help others
