Question about Samsung SGH-E900 Cellular Phone
E250 Video Bluetooth problem
I tried to upload a mp4 video to my e250 via bluetooth but it places itself in the "other files" folder. I tried opening it to play but there is no such option. Please help ASAP I'm running out of time!
Get Samsung PC link 3, for ur E250 (m using the same), u'll get it from samsung's website. Get a data cable, connect ur phone to the pc, open the pc link, Ull find option there to edit snaps and videos ant lot more. Get the videos from pc to the window of pc link, and edit it to mp4 format. U cn do a lot more from that pc link. Enjoy.
(p.s.- not every video is convertable, the will come in other files only)
Posted on May 29, 2008
Check for the MP4 software being available in ur mobile
Posted on Feb 07, 2008
  • Anonymous Feb 07, 2008
    check for the MP4 software being available in ur mobile
SOURCE:
Installing java games to SAMSUNG E250
I finally succeeded in installing some java games to my Samsung E250 via bluetooth. I thought I would share the info on how I do it here because it seems to be a frequent unanswered question on various forums. You will need a *.jad and a *.jar file for your game. 1) Download Softick PPP and Samsung Java Uploader.exe . Also JADmaker if required. 2) Install SoftickPPP according to this Polish website. I don't understand Polish, but the pictures tell enough of the story. Set up your bluetooth COM ports in the SoftickPPP bluetooth/serial settings. My Bluetooth COM ports are either 24, 25 or 26. I leave them all ticked. 3) Enter *#52828378# on the phone to access the Java Test Menu. Choose OTA type setting, choose Serial bearer OTA. Click select. (This seems to need to be changed back to GPRS bearer OTA for Samsung PC Studio to connect) 4) Start SoftickPPP. Click on cancel for the missing USBPort.dll error message. Accept bluetooth connections for DUN and Serial connections on the phone. 5) Choose 'Activate PPP' by right clicking on the icon in the taskbar. Accept connections on phone again. 6) Start 'Uploader.exe' and then add the required jad file. Leave the program open. 7) If you are not still in the Java Test Menu then enter *#52828378# on the phone again. Select 'Serial test', 'PPP Up', 'Bluetooth' on phone, 'Serial download'. My phone sometimes restarts at this point in which case I have to choose 'Shutdown PPP" in the taskbar icon and then re-activating it once the phone has restarted and then re-do step 7 after entering the Java Test Menu again. A Java splash screen should appear with a progress bar showing the upload of the file. The game then starts automatically. There we go. It works for me Please man do you speak bosnian..
.Quote:
1) Type in the code *#9998*52824678255# (which reads *#9998*JAVAINSTALL# )
2) Your phone should return with 'Activated'
3) Now using Bluetooth or USB cable, connect to your phone (IR probably works too)
4) If you have a game as .jar, but don't have a .jad file, use JadMaker to create one (draw the .jar file to it and it will generate a .jad file for you).
5) Copy the .jar AND .jad file of the game into the map called "Other Documents" on your phone.
6) Now on your phone under 'My Files' browse to the 'Other Documents' map and doubleclick on the just copied .jad file.
7) The phone will ask you if you want to Install the game.
8) After Install you will find the game under Games on your phone.
9) You can now remove the just copied .jar and .jad file again (they were only there to install the game onto your phone).second answer:that i go to samsung company and when i ask them about jave install on samsung they say to me that the only way is to download from mobile internet games but it will be triall expet a game called 4*4 extreme race only and i tried to install any game it will be trial thanks for your reading (trusted)
May 22, 2009 | Samsung SGH-E900 Cellular Phone
How i can install java games in samsung sgh e250 via card reader problem:
I got a beautiful answr on d net surfn 4 yr questn ...
.Quote:
May 22, 2009 | O2 Samsung SGH-E250 Cellular Phone
How to install themes on my samsung e250
im not sure if you will be able to install it to your samsung e250. i used to copy and install sis files to my nokia and it works without a problem. im not sure if sis file is compatible for samsung phones. try to copy it again to other folders and open the file until your phone recognizes it. hope this help.
Aug 25, 2008 | O2 Samsung SGH-E250 Cellular Phone
Unable install games in samsung e250
I also have a samsung e250 and i followed these instruction and it worked...
You must download two programs the SoftickPPP which you can download in this link: (if this link is not working try google you can find many sources)
http://users.skynet.be/yozy/tutorials/downloads/SoftickPPP234-en.exe
last is the uploader.exe
http://users.skynet.be/yozy/tutorials/downloads/Uploader.exe
Download the 2 programs and install the first program configure its setting on bluetooth/serial and choose the general serial port you are using for example: \device\mdm0 then press OK
Your fone must be connected to the pc via bluetooth or usb cable.
open uploader.exe and add the jad file of the game you want to install... then activate softick, which you can see in the taskbar right click the green icon and select activate softick.
type *#52828378# on your telefone
OTA type setting
then
Serial bearer OTA
then save
activate SoftickPPP which you can see in the taskbar right click the green icon and select activate softick.
type #*5737425# on telephone
then
PPP UP
then
choose usb port (if you are connected via usb cable) or bluetooth
then
Serial Download
(sometimes the fone restarts during this procedure, just inactivate your softick while the fone restarts and activate it again...
you can see java screen when the game is being uploaded...
if you still have questions email me at [email protected]
goodluck...
Aug 20, 2008 | Samsung SGH-E370 Cellular Phone
Application intaller on samsung E250
انا عايز ثيمات لتليفونى samsung e250
Feb 08, 2008 | Samsung SGH-U600
I'm trying to put a video/picture slideshow on my sansa e250 player and it won't work
what you need to do is make sure that the file is correctly in the folder like drag the file from the media player and have the folder already open then drag the file to the folder that is already open and when you have it on your PC make sure you change the file to what ever type of PC or programming (like media player or real player etc.) then you should use .mp3,wma(if you have windows media player), or mpeg-4/mp4. this should work. if not then post a problem up again and i'll find an answer for you
Jan 31, 2008 | SanDisk Sansa e250 MP3 Player
Samsung SGH-E250 Video Problem
yeah there are mp4 files that cant be played in this mobile. SGH E250 that is...
Solutions...
1. Try to lower that resolution to 176x144 still in mp4 format
2. Try to lower the kbps to below 100 still in mp4 format
3. convert mp4 to 3gp with solution 1 & 2 as your options output format
there are alot of free mp4, media converters available in the i-net
I hope this helps to you...because I have the same problems like you guys before the solutions suggested above are the ones I did to solve my problems with video not playing in this unit model. ok
Sep 09, 2007 | Samsung SGH-E900 Cellular Phone
Aug 04, 2007 | Samsung SGH-E900 Cellular Phone
E250 sansa videos
you must upload sansa media converter from the cd that came with the mp3 player. once you completely upload it you open it and click "ADD MEDIA" and select the videos, then hit "CONVERT" and it will convert them to a *.mov* format
Jan 10, 2007 | SanDisk Sansa e250 MP3 Player
Samsung SGH-E900 Cellular Phone Logo
88 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
