Question about Sony KDF-E60A20 60 in. LCD HDTV
KDF-60x955 When I turn on the TV I get a flashing green light that turns red and the TV turns back off. I get a 5 flash strobe effect with the red standby light. I can't get any sound either. I have disconnected everything, cable, sat. receiver, and vidoe game and tried to reset to no avail.
  • 43 Answers
SOURCE: Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Posted on Jan 06, 2008
  • 203 Answers
SOURCE: Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Posted on Sep 11, 2008
  • 320 Answers
SOURCE: standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
Posted on Oct 20, 2008
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Posted on Jun 24, 2009
  • 73 Answers
SOURCE: Sony KDF-E42A10 rear projection TV. Won't turn on.
Start by changing the lamp. If you got 5 years out of the old one, count your blessings, most folks only get three. The lamp is designed to be replaced by the consumer. Ebay will carry a replacement for you or you can get it directly from They've got good prices. The lamp door is on the back. Its really easy, give it a shot.
Posted on Sep 17, 2009
SOURCE: 55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Posted on Sep 28, 2009
0 characters
1 Points
Kdf-e55a20 red blinking light
Altho you do not say which light is flashing red , you have a light on the front that is for the lamp ONLY...
If you do not have the user manual , get it here & start on page 11.:=>...
Jul 06, 2015 | Sony KDF-E55A20 55 in. LCD Television
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Heard a pop. Checked and had to replace the lamp. Now when turned on the power-standby flashes green, then flashes red, but TV never comes on.
How many times red light flashing?
This is an error code and red flashing count indicates a particular problem in specific section of tv, please count how many times red light flashing after 3 seconds long pause and post here to suggest a solution.
May 28, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
Probable lamp failure, lamp won't turn on leading to red light to come on. How many times does it flash? 3 means safety switch bad, 5 flashes means lamp or lamp ballast failing.
Sep 30, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
The tv Sony kdf-42we655 will not turn on, the light will flash green and make a humming sound but thats it, the light below that labeled "lamp" flashes red? Why is the tv not working properly and why is...
Your tv is a projection one - it uses a very powerful lamp/bulb to generate the light that used for the image. In your tv that bulb has died and must be replaced - it will cost about $200.
Jul 05, 2010 | Sony KDF-42WE655 Television
I try to turn it on but it just blinks on stand by
Probable Lamp. If lamp hasn't bown the red Lamp Lite won't flash but other lamp issues cause stby timer light to continue flashing. If stby red lite is flashing, count the no. of times flashing - could open thermal fuse (6X flashing)
Nov 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
The tv will turn on but no the screen wont. and
Replace the lamp would be the first thing to try. Lamp door switch on this model is notorious for going bad. If you replace lamp and still won't turn on jumper door switch. If you take off back you can see switch board.
Nov 21, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
A three flash means you have not seated the lamp cover correctly. Try recolsing and relatching the lamp cover
Dec 21, 2008 | Sony KDF-42WE655 Television
Lamp light flashes red
if lamp LED is blinking then replace lamp ..
Nov 25, 2007 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E60A20 60 in. LCD HDTV Logo
189 people viewed this question
Top Sony Flat Panel Televisions Experts
Mando Mojica
Mando Mojica
Brian Sullivan
Brian Sullivan
Are you a Sony Flat Panel Television Expert? Answer questions, earn points and help others
